![]() ![]() Drives: Yaris Liftback Join Date: Oct 2008
Cutting bumpstops on Tein springs...
I bought a set of used Tein springs for my liftback. But I don't have the instructions and was wondering if anyone here has installed them and knows how much to cut the bumpstops.
![]() Thanks in advance. |
I swear there has been 4 posts about this in just the last week. Cut them around 2 inches.
This is the max you can cut them. Any more and you risk bottoming out the strut and causing damage to it. It is recommended that you trim off the same amount as the drop. So, 2 inch drop, cut 2 inches off. 1.5 inch drop, cut 1.5 inches off. Just don't go past what the picture shows...
![]() See here- http://www.yarisworld.com/forums/sho...503#post154503 |
Super Newbie
Drives: 2007 Yaris Liftback White Join Date: Jul 2007
Cut off about ~25MM or 1inch. You really don't need to cut off the same amount as the drop. Lowering springs are stiffer then stock so the shocks travel through shorter cycles which means they don't need that much travel between the bumpstop and shock body. 1 inch of travel is sufficient for a comfortable ride.
If you cut it shorter then that like in the picture, you run the risk of rubbing in the front. Too much upward travel will allow the wheel to travel to far up into the wheel well. Also less bumpstop means less absorption for hard bumps and dips. |
![]() ![]() Drives: 5spd 2007 Yaris LB Join Date: Jul 2007
actually you want to cut it exactly where the picture shows. I have DF210s and i've had 17"s and 15"s and bumpstops at the length petersredyaris posted. I've yet to actually experience some rubbing
see post http://www.yarisworld.com/forums/showthread.php?t=9831
99.9% of what goes on in my mind at work/school/home ![]() [Debadged] [Tanabe DF210] [Limo Tint][17" Fondmetal Wheels] [Pioneer HU] --:: Wishlist, PM me ::-- [SSK (WTB)] [Black Sand Pearl Eyelids (WTB)] |
I would actually recommend leaving about 1/4 inch more that what is shown. This is especially important if you run wheels that have an offset of 38-40mm. To short of bumpstop and you will rub the fender liner because of the extra uptravel. If your offset is 42-45mm, you can cut them as shown and most likely have no rubbing.
FunctionSpec makes a good point too, that suspension travel with stiffer springs will be less. (see above) Just don't go shorter than shown or you can and will ruin your struts. All this only applies to using drop springs on the OEM front struts. I don't have any knowledge on the TRD struts or others... |
#7 | |
Party like a Barack star
Drives: '08 LB MT Join Date: Oct 2008
ddongbap-
I'm off topic here, but it was nice meeting you and all the other Yaris peeps the other night...by the way, how many zeros are in a BAJILLION??????
i don't feel like creating another signature, yet. Give it another week... |
More than what anyone types. Since its progressive, no matter how many zeros you put down, there'll be about 14 more than you.
Ha!
Or buy the FatCatMotorsports bumpstop kit with spacers and have a bottoming free ride.
http://fatcatmotorsports.com/FCMstops_Yaris.htm Works like a charm in my TRD suspended sedan.
Has anyone actually installed Tein S-Techs and knows what the instructions say?
i normally just cut them in half
08 junction produce belta almost done and ready for paint 06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp 90 crx sir ls vtec turbo 755 hp mecp masters certified |
SOLUTION:
OK, I got the official word from Tein on this issue.
The S-Techs require that 1.4 inches be cut off the end using their "A" cut method. They have 4 different ways to cut bumpstops, the different methods can be found in the tech section of their website.
Can't believe I'm modding a Yaris, I must really miss my STi...
toyota
im curious what happen if you dont cut the bump stop on the trd i think its 1.2-1.5 drop..
| Tein Lowering Springs SKC10-AUBOO | c-one yaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 09-10-2007 01:58 AM |
| Tein Springs | nickhjort | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 08-15-2007 12:33 AM |
| Springs - Tanabe DF210 or Tein S Tech | andylai2k | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 06-10-2007 09:22 PM |
| Tein Basic Damper Coliey's Vs. Tein S. Tech Springs | ToTo | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 35 | 05-07-2007 05:08 PM |
| TEIN S-Tech Springs *NOW AVAILABLE* | EnduroMTS | Sponsors Classifieds Area | 1 | 10-12-2006 02:08 PM |
