Old 11-21-2008, 12:51 PM   #1
mrbond
mrbond's Avatar
Anyone installed shocks?
Hi y'all. I've got a set of TRD shocks and springs but the included instructions don't really explain a whole lot for the shocks. Anyone done an installation of any brand of shocks and have pictures? Would help out a lot!
Old 11-21-2008, 12:58 PM   #2
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
http://www.yarisworld.com/forums/showthread.php?t=1096
Old 11-21-2008, 01:01 PM   #3
cm07yaris
Drives: 2007 Toyota Yaris Blazing Blue
Send a message via AIM to cm07yaris
Drive up to Wisco, I'll do it for you!
cm07yaris is offline   Reply With Quote
Old 11-21-2008, 01:04 PM   #4
mrbond
mrbond's Avatar
Originally Posted by Loren View Post
Yeah, this showed how to remove the front strut, but the rear strut wasn't covered. That's the one thing I'm having trouble with. Oh well, because of school and my new 3am to 8am job at UPS, it's going to be a a while before I can put these in.
But cm07yaris, I just might take you up on that! I'm going to be going up in wisconsin to look at Northland College when I have some available time. Where in Wisconsin are you?
Old 11-21-2008, 01:08 PM   #5
the rears are really easy, the top bolt is under the plastic cover in your trunk, and the
bottom is easy to see once you jack up the car and remove the wheel.
If you have instructions for the springs, you're all set.
Old 11-21-2008, 06:07 PM   #6
bdc87
HISTORY REPEATED 11/04/08
bdc87's Avatar
Drives: 07' MM Vitz LB
Send a message via AIM to bdc87
Rears are easy theres two nuts on each post under the plastic caps, I needed an impact wrench for these. And one bolt on each strut underneath connecting it to the frame.
Fronts are the hardest part and something I'm having a little trouble with but I have one on and working and the other tomorrow. If the sway bar end doesn't reach the top to install then you'll need to jack up the arm.
Also a word of advice is use blocks and as many jack stands as you have.
bdc87 is offline   Reply With Quote
Old 11-21-2008, 06:13 PM   #7
mrbond
mrbond's Avatar
Yikes, well, good thing I still have a bit of time to research!
Old 11-22-2008, 02:25 AM   #8
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
get over it. moderator's pet.
Old 11-22-2008, 02:38 AM   #9
richardholdener
Drives: 2008 Yaris hatch
I wrote the story for Siphon magazine on the install of the TRD components on the yaris with photos if that will help.
richardholdener is offline   Reply With Quote
Old 11-22-2008, 06:55 AM   #10
mrbond
mrbond's Avatar
Wow, really? That would be pretty helpful, actually. Whatever happened to that magazine? I've been looking around everywhere for it for the past nine months, but I haven't seen any
Old 11-22-2008, 08:31 AM   #11
Klink10
Klink10's Avatar
If you visit NC bring em......I'll do it for nothing also. Well steak dinner would be nice.
Old 11-22-2008, 04:46 PM   #12
bdc87
bdc87's Avatar
Magazine was cancled, Got the other side done today, yeah all 4 sides are done. Just wnet for a drive and it's totally different now, much more sure footed and stable, no more dips and the backroads are fun again. Will test highway soon.
Installed the Tanabe Strut bar but had to remove my ground wire kit.. vacantj Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 10-01-2007 01:56 PM
Which options are dealer installed? grampi New YARIS Purchase Forum 4 07-30-2007 01:23 AM
Questions on Shocks whooppee777 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 06-29-2007 06:19 PM
Tanabe NF210's installed...got a question though Terrorize Wheels, Tires and Suspension Forum sponsored by The Tire Rack 32 09-29-2006 07:45 AM
