![]() ![]() Drives: 2007 toyota yaris Join Date: Mar 2009
okay, so this is still regarding the issue i posted before. disel into engine. that fuel drained, put in autolite plugs, got car running. car seems perfect. was told its the plugs that are causing light to be on. denso plugs installed, light off, then back on. i buy code reader. it tells me code p0420. i call mechanic and tell him light is back on and he says okay, then it must be the coil. i ask, what do you mean. says coil 1 needs to be swapped with #4 and #4 needs to be swapped with #1. why is it that from the amount of EXACT DETAIL that i had in my previous posts about the car. not ONE person has said anything about any sort of coil. i even did a search on here for the word COIL. Wow, nothing in search results. I have seen from reading many posts on here way before i was ever a member. the amount of people on here saying, wow, thanks guys. you were all right. my mechanic or dealership, etc tells me this yet you guys have the real answers. so to me, someone that is not too good with this type of stuff. it tells me to go with what your all saying and not trust the local mechanic.
So would putting diesel into yaris have fouled coil or coils? how about would cheap autolite spark plugs have fouled coils? both combined? yes? no? maybe? no way in hell? |
ive seen incorrect spark plugs damage coils before. which is why i always use oes plugs
If the Autolite plugs installed in your car were the XP3924 you mentioned in one of your other threads, then you had the correct replacement plug specified for your vehicle. Not the OEM brand, but they should have worked just fine, without damaging other components of the vehicle.
And the diesel could not have fried a coil. |
#5 | |
SCORE MECHANIC - 1 ME - 1 |
Super Newbie
Drives: 2007 Yaris Liftback White Join Date: Jul 2007
A bad coil will cause drivability problems but if the cars running fine then the coils should be fine.
Well if you look one spark plug cost 5.95 and another spark plug cost 20-28 dollars depending where you purchase them there has to be a difference. One is designed by a oe manufacture for ford and one is a oe manufacture for toyota. Me personally i would rather get the part from toyota. From my experience autolite starters, and autolight altenators and batterys are pieces of junk. My friend works at kragens and he says he gets a rediculiouse amount of warrenty returns on them. So i would not use a spark plug made by that particular brand in my vehicle. Either denso or ngk is all i would use. All we know is many users have had no problems with coil failures and users that have had coil failures reported using a alternative plug. Search all the posts for coil failures you will find what i am saying has some sense to it. I remember last month if orget the brand but it was suposily some high performance plug some user had problems with failed coil as well.
From my own personally experience the only coils i have changed on cars when i removed the plug it was either extremely worn out or a different type of plug. |
#8 | |
Can't argue with Autozone Dude. Good Luck!
Learn to Relax
Drives: 2007, Meteorite, LB Join Date: Dec 2008
The Denso plugs have an Iridium tip which can last for 100,000 miles. That is why they cost so much. So long as the tips aren't broken or damaged, they should be usable with the proper gap. You need to find a mechanic that will diagnose your problem.
Okay ill try to help you best i can. P0420 id say 75 percent of the time this code is on for any car that comes into my shop it means the catalitic converter is bad. other 25 percent it is a o2 sensor. If you want to try to diagnose this yourself you would need a scanner even a cheap generic scanner that shows live data. You should be able to see o2 sensor voltage before the cat and o2 sensor voltage behind the cat. If the voltage is the same than more than likely the cat is to blame.
If you want to test the o2 response you can introduce fuel into the system and see if the o2 responds by spiking the voltage. You can do this with propane gas entering the intake you should see the mixture go rich and the fuel trim start to max out. Or if not available you can try carb cleaner. If the o2s respond properly then the cat is the problem. Anotherway to test the cat is purchase a pyrometer. It shoots a beam and measures the temperature of whatever it is aimed upon. Measure the temperature before the cat and after. The exhaust gas as it enters the cat gets heated up to burn off any unburned fuel in the combustion chamber. Usually the temperature is 100 degrees hotter exiting the cat. If the temperature is the same both inlet and outlet or is even cooler in the outlet then you know for sure the cat is bad. A cheapo pyrometer could run you around 40-50 bucks same as a generic obd2 scanner. If you find out the case the cat is bad which it probally is after thourouly reading your post then i would say take it to a muffler shop and make sur eyou get a OBD2 CALIFORNIA APPROVED catalitic converter. I would try replacing the main cat first and leaving the precat alone. Then clearing the code and see if the light stays off. After reading your othe rposts. I dont know why your mechanic would suggest a coil. Unless your car is missfiring with a blinking check engine light. You have no coil problems. Plus any decent mechanic should know how to test coil winding resistance to verifiy if it needs to be replaced or not. What i would reccomend is putting a can of seafoam in the gas tank. As well as running a can through a vaccum line through the intake. It has cleaning properties which will clean the tips of the o2 sensors as well as clean the cat of debri. |
#12 | |
![]() ![]() ![]() ![]() Drives: 08 3DR 5M Bayou Blue; 09 Fos Join Date: Oct 2008
As long as the car seems to be running rel good, just drive it. It will take a while to clean out the cats after being loaded with oil. Take it out on the highway and run it full throttle third gear 3-5000 rpm 5 sec, then give it 1 min rest then another five second burst. Do this about 5 times. This should burn off whatever is in the cat and heat up and burn off whatever is on the 02 sensor. Fuel oil is not as nasty as motor oil afa killing the catalyst or the sensor since it doesnt have nearly as much metalsalts in it ( ash). If this doesnt work and the car drives good and gets good gas mileage (>35mpg) then just drive w/o fixing it until its time to get an emissions inspection.
#14 | |
I agree with you that the OP needs a good mech to diagnose his probs. Now where can he find a good mech .... Any recs from guys around where the OP dwells? |
#15 | |
Hmmm the scanner i use the most is the craftsman one just because its so fast and has live data capability with emission monitors. And go back to the shops snapon one if i need to do abs or some manufacture specific testing. this is what you need..... http://cgi.ebay.com/U381-LIVE-DATA-S...3A1%7C294%3A50 56 bucks and can do nearly everything a professional scanner can do. |
#16 |
Just BTW if the cat is deteriorated i wouldnt drive the car too long that way before fixing it. Cause what happens now the remanining active catalist will have to work on overdrive cause probally the precat is toast as well as the front portion of the main cat. Eventually it can get so plugged that it causes a exhaust restriction.
Its rare but long term driving on plugged cat can cause head gasket failure. All that exhaust gasses and pressure has to go somewhere. I have seen for the first time in my life 2 weeks ago a car that had a exhaust leak by the exhaust manifold that was not the manifold gasket or manifold cracked. But leaking from the cylinder head. We changed the exhaust gasket thinking thats where the exhaust leak was from cause you could feel the air if you put your hand there. And were like wtf its still making a exhaust leak. Sure enough pulled the head and the gasket was blown in that area. |
#17 |
Okay, so if you guys remember me posting on here about mechanic telling me to bring car in saying that he needs to switch coil 1 with coil 4 and coil 4 with coil 1. well i did it last night. just for fun. heres what i came up with. the check engine light was on immediately. i then put back to normal (or how it was b4 i touched it) then i reset light. and so now i will wait again and see when light comes on again. this is fun.
Report#: 7 Report Date: 4-9-2009 (12:18 AM) Vehicle Year: 2007 Vehicle Make: Toyota Vehicle Model: YARIS Stored: P0354 Ignition Coil D Primary/Secondary Circuit Pending: P0304 Cylinder 4 Misfire Detected MIL ON MisFire Monitor Complete Fuel System Monitor Complete Comprehensive Component Monitor Complete Catalyst Monitor Not Complete Heated Catalyst Monitor Not Supported Evaporative System Monitor Not Complete Secondary Air System Monitor Not Supported A/C System Refrigerant Monitor Not Supported Oxygen Sensor Monitor Not Complete Oxygen Sensor Heater Monitor Complete EGR System Monitor Not Supported DTC for which Freeze Frame was Stored P0354 Fuel System 1 Status Open Loop Fuel System 2 Status Not Supported Calculated LOAD Value 41.18 % Engine Coolant Temp 123.80 °F Short Term Fuel Trim - Bank 1 0.00 % Long Term Fuel Trim - Bank 1 -4.69 % Engine RPM 1363 rpm Vehicle Speed Sensor 0.00 mph Ignition Timing Advance #1 Cylinder 8.50 ° Intake Air Temperature 71.60 °F Air Flow Rate Mass Air Flow Sensor 0.56 lb/min Absolute Throttle Position 19.22 % Time Since Engine Start 0 sec Bank 1 - Sensor 1 Equivalence Ratio 1.00 Bank 1 - Sensor 1 O2S Voltage 3.30 V Commanded Evaporative Purge 0.00 % # Warm-ups since DTC Cleared 0 Distance since DTC Cleared 1.86 mi Barometric Pressure 28.64 inHg Bank 1 - Sensor 1 Equivalence Ratio 1.00 Bank 1 - Sensor 1 O2S Current 0.00 mA Catalyst Temperature Bank 1 - Sensor 1 914.90 °F Catalyst Temperature Bank 1 - Sensor 2 661.46 °F Control Module Voltage 13.89 V Absolute Load Value 20.78 % Commanded Equivalence Ratio 0.87 Relative Throttle Position 0.00 % Absolute Throttle Position B 51.76 % Accelerator Pedal Position D 16.08 % Accelerator Pedal Position E 31.76 % Commanded Throttle Actuator 18.82 % Time since DTC Cleared 0 hr 19 min |
#18 |
Okay so before it had a code for a coil problem but not a missfire. Now you have a code for a missfire but not a coil. 3 things can cause a missfire. mechanical, electrical, or fuel related. We can probally rule out mechanical as compression is most likely good. So you are left with 2 other options electrical or fuel. Again you probally do not have a clogged fuel injector so your missfire is now probally caused by electrical problem. Either a faulty spark plug or ignition coil.
OBD 2 systems go by trip cycles. You have to fail 2 trip cycles before a code will trip the check engine light. So within 2 trips you have had 2 consecutive missfires. But you havent had 2 trips of detected coil problems. Unlike before you had 2 trips of coil related problems but not 2 missfires detected yet. So what you would have to do is drive the vehicle until it shows coil problem cylinder 4. I do not know the resistance specs for the coil. But i think you can test the coil windings with a ohm meter. You can purchase one for as cheap as 10 dollars. You can test the resistance of the suspected faulty one. And compare it to the readings of the other ones. If the reading is drasticly different on one you have found your culprit. Otherwise you could try swapping the plugs and see if the missfire follows the plug. Or simply just replace them all. If the missfire dosnt follow the coil or plug. Put your ohm meter on the connector that goes to the coil. Rare but its possibly to have a open or short in the harness. But if that were the case the car would be running like crap with a blinking check engine light severely missfiring. |
| Where do I buy ngk iridium tip 7 heat spark plugs? | PETERPOOP | Performance Modifications | 23 | 03-08-2009 08:34 PM |
| Upgraded Spark Plugs For Boost | whooppee777 | Forced Induction Forum | 9 | 02-14-2009 01:53 PM |
| Dual ground electrode spark plugs | Kitt | DIY / Maintenance / Service | 15 | 02-09-2009 11:08 AM |
| FS: OEM NGK Spark Plugs | mikenacarato | Items for Sale by private party | 13 | 01-23-2009 04:05 PM |
| Spark Plugs | YamilR | DIY / Maintenance / Service | 2 | 09-28-2007 08:38 PM |
