![]() ![]() Drives: '07 blazing blue hatch Join Date: Oct 2008
Trailer and Springs
Hello all :)
Thanks for all your past help. I have a, hopefully, quick question. I have a set of Megan springs waiting for spring to get installed. I plan on getting a hidden hitch and small trailer. Will the hitch/trailer work with the springs? I am concerned about bumper clearance. -- John
2007 HB Blazing Blue |
Not sure I understand why you're concerned about bumper clearance just because your car will be sitting 1.5 inches lower.
What I would recommend is this. If your source for the Hidden Hitch sells the receiver with or without the draw bar, opt for without. The provided draw bar will not place the ball at the correct height. Install the receiver, then buy the draw bar seperately once you determine how much lift you will need to have the ball positioned properly relative to the trailer tongue.
I am worried the bumper will be to low for the hitch to be usable.
Though, I dig your idea and will run with it. I will just get the hidden hitch first. If all is a fail, it is still a rear connecting sway bar. :)
I'm running a Curt hitch with Megan springs. No issues. Since a hitch is mounted to the frame, springs do not affect its location relative to the bumper.
A little bit of real world advice helps qualm the worries.
advocatus diaboli
Drives: 07 Yaris hatch Join Date: Mar 2011
*If* for some reason you find the hitch sits too low, pointing the nose of the trailer too steeply towards the ground, you can always remove the ball and flip the bar over and re-install the ball. It will elevate the ball to compensate for the lower vehicle.
From this: ![]() To this:
-Type 07 FFL- ![]() My odometer 03/11 http://i205.photobucket.com/albums/b...a/2843ed85.jpg |
Yes you can. However, in my case, the drop bar that shipped with my hitch receiver is too low in normal position, too high flipped. With the lowering springs, and my trailer (they differ slightly from one to another) a zero drop bar worked best.
![]() ![]() ![]() ![]() ![]() Drives: it is kinda stock Join Date: Oct 2010
i have a question to (rather than make a new thread) sorry
but would something like this (tow basket) fit on a sedan or is there no connection under the read bumper ? ![]() (i know this one is on an suv) thanks |
![]() ![]() ![]() ![]() ![]() Drives: Scion FRS RS2, ‘21 Crosstrek Join Date: Oct 2008
A basket would work with a sedan and aftermarket receiver (discussed above) however I've yet to see a basket for a 1 1/4" receiver. All I've seen are 2". An adapter might be available???
TRD Upgrades: 18" Wheels wrapped in 215/35/18 PZero's, Sportivo Shocks/Struts, Lowering Springs, Swaybar, Axle-Back Exhaust, Oil Cap, Rad Cap, Signage. Aftermarket Goodies: Piggies SS, K&N Drop-In, Blitz S/C, DC Header, NST Pulley) Toyota Options/Accessories: Sport Pedal Covers, Sport Shift Knob, Ipod Interface, Summer Mats, Winter Mats, Cruise Control, Auto-Dim Mirror, Echo steelies with winter boots.
#10 | |
http://www.etrailer.com/dept-pg-Hitc...nch_Hitch.aspx
advocatus diaboli
This is the basket my IT guy rocks on his LB...he also has a trailer he uses to haul small stuff, office chairs, etc.
Sorry for the thumb... :) ![]()
| Towing with my Yaris | Cortland Yaris User | Photo-Video-Media Gallery | 12 | 07-06-2010 01:07 PM |
