Old 05-10-2009, 11:14 PM   #1
Liu997
Drives: 2008 Red Yaris LB
Dome Light Wire
I am going to add some LED bars for interior lighting and don't know which wire is the dome light so that the bars will light up when the doors are open.
And can the circuit handle 4 led bars? Thanks
Liu997 is offline   Reply With Quote
Old 05-17-2009, 11:47 AM   #2
Liu997
no one has hook up lights to the dome wire? Its really that bad?
Old 05-17-2009, 11:54 AM   #3
staticorex
staticorex's Avatar
Drives: Sc'd Yaris Sedan.
While I can't speak for this exact situation, every time I've added light bars I ran them directly to a separate fuse box I attached directly to the battery. You can pick one up for a few bucks and you can set any fuse and any number of lights to it. I know that won't help your lights on with the door open idea but you could still rig something up for that afterward.
Old 05-17-2009, 09:48 PM   #4
The feed is via a 15A fuse, so you should be fine. That circuit drives the dome, map, and hatch lights.
Old 05-18-2009, 02:04 PM   #5
Stiv
Drives: Yaris TS 1,8L
I think I have an idea.
I looked at the lightning diagram, and there is a connector called 4K left of the steering wheel. Wire 4K-2 is ECU controlled ground that controls the dome light dimming effect. It goes from 0V (dome light is on) to 12V (dome light is off).
The idea is to hook + connector of the LED or cold cathode neon light to let's say cigarette lighter + wire (or any other available constant 12V wire), and - or ground to the 4K-2 wire.
In theory that works. Please look at http://www.etimago.com/yaris/repairmanual/Lighting.pdf pages 19, 83 and 84.
Stiv is offline   Reply With Quote
Old 05-18-2009, 02:11 PM   #6
That would be fine. Depending on the power supply of the cold cathodes, you may not see the dimming effect, but rather just on and off.
Old 05-18-2009, 02:20 PM   #7
Stiv
Last time I used these http://www.sharkoon.com/html/produkt.../index_en.html
It was done in Renault Laguna which has a dimmer.
They dimmed as expected and they're still working like a charm
Old 05-18-2009, 02:37 PM   #8
That works. Another option that I like better than CCFL lamps is EL wire. It is flexible, won't break if you bump it, and extremely power efficient.
http://www.lightnwire.com/raw.html
Old 05-18-2009, 05:33 PM   #9
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
I actually had some under dash lights hooked up to the dome circuit and I'd tell you which wire on the junction box it was if I hadn't disconnected it. I seem to recall it was a pink-ish wire. I know this doesn't help much but just know that it is possible and easy to wire into the circuit. The under dash lights even faded in and out like the dome light.
Old 05-18-2009, 05:53 PM   #10
Stiv
4K-2 actually is pinkish
It look's like I'm on the right track
DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 goku87 DIY / Maintenance / Service 127 02-19-2023 08:01 PM
12 LED Dome Light Festoon bigsky2 Cosmetic Modifications (Exterior/Interior) 26 04-18-2010 11:38 AM
aveo dome light trouble TickleTimeTim Off-topic / Other Cars / Everything else Discussions 10 03-18-2009 02:08 AM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 11:42 AM
Festoon (dome light) led bulb fit?? ||)) (o) ||\|| Cosmetic Modifications (Exterior/Interior) 5 03-22-2007 03:22 PM
