100K check up question
So recently my Yaris just got 100K. I was wondering what are some of the things I should check on. I am going to change the spark plugs, cabin filter. The intake is new and I changed the oil and oil filter. Is there anything major I should check.
Also, I went 30 miles on 1 bar of gas |
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
replace coolant? I hope you've changed gear oil before; every 30k miles with MT-90 redline. spray some MAF sensor cleaner.
#3 | |
![]() ![]() ![]() Drives: Yaris sedan Join Date: Apr 2011
Replace the filter gas in a tank of . |
![]() ![]() ![]() Drives: US 2007 Yaris Liftback 5MT Join Date: Aug 2006
2007 does not have a cabin filter...
2007 Toyota Yaris Liftback Base 5 Speed. Mods: Netz/Vitz/RS badging, RS style spoiler, RS replica tails, Tenabe NT210 Springs, Tokico Blue Struts, Team Dynamics 14", fogs(Arrived), JDM HKS Exhaust. |
Did you do the valve clearance check at 60,000?
Its involved and since almost no other car has shimmed valves like the ECHO and Yaris, I question whether there are any mechanics qualified to do it. I suspect they take your car, dont do the work, then say "It was good!" Needs new plugs at 100k also. |
![]() ![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Jan 2010
![]() ![]() ![]() Drives: 2008 Yaris sedan A/T Join Date: Oct 2008
some1 make a diy to replace the gasfilter
#9 | |
- Jason
#10 | |
![]() ![]() ![]() Drives: '08 LB, '07 WRX Join Date: Jan 2009
All good stuff guys. But what about the transmission fluid. I have an automatic, so I wasn't sure when that should be changed?
Modded Moderator
Yes do that as well. I'm at 99,873 miles and will be at 100k in a day or so. Make sure to get the GENUINE AFT fluid from toyota. The automatic yaris can't use the stuff you get at autozone. Also replace the transmission filter. Don't get that from the dealer (It's about $85), I got mine at autozone for less than $19. Make sure with plugs to get the iridium plugs. No need to replace the fuel filter unless you have a problem. Reason is that it's located in the gas tank and part of the pump. My mechanic looked it up and its pretty spendy. He said I didn't need to replace it unless I was having problems.
#13 | |
A home mechanic can CHECK the clearances themselves . Its not hard. Its ADJUSTING them where the problems come in. Usually checking is all thats needed. But if tight exhaust valves are found that is motivation to find a mechanic to do the work... |
the yaris calls for toyota WS (world standard) ATF. The only non-toyota fluid that I know of that isw compatible is BG's universal synthetic. It meets the spec
Modded Moderator
It does need replacing.
| Transmission Question | CMR | General Yaris / Vitz Discussion | 42 | 04-14-2010 01:38 PM |
| So question here abt hatchs in general | Jem_hadar | General Yaris / Vitz Discussion | 12 | 01-06-2009 04:06 AM |
| Amplifier Watt Question....noob question | hasher22 | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 09-27-2007 04:59 PM |
| Paying for the Yaris with a check? | YotaYarisUSA | New YARIS Purchase Forum | 15 | 07-11-2007 04:31 PM |
| Question about 2 kinds of TRD springs & rear strut bar | Astroman | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 06-18-2007 06:44 PM |
