Old 07-18-2010, 11:38 PM   #1
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
Spring Question
I am looking for an aftermarket spring with the least drop, I don't want to put stock springs back... No control with stock springs ;d, I am thinking of putting NF210s? ARe there any that have less drop? Thanks.
Its a Chao!!!
Old 07-18-2010, 11:48 PM   #2
Astroman
Modded Moderator
Astroman's Avatar
Eibatch is only 1" drop.
Old 07-19-2010, 01:08 AM   #3
beZzZ
Learning & Upgrading
beZzZ's Avatar
Drives: 2006 Yaris 5 Dr HB Black
U can do some research about TRD, 1.2' drop, gd enough for me. Mine run on stock shocks, still comfy enough.
beZzZ is offline   Reply With Quote
Old 07-19-2010, 01:22 AM   #4
toy_toronto
always toyin'
toy_toronto's Avatar
Drives: 2010 5-Dr
see link for ideas and pictures: "Need a "Mild" Drop"
-toy
Old 07-19-2010, 02:11 AM   #5
NF210's are 1.1/1.2, that is less than the TRD springs, which are closer to a 1.5" drop.
The NF210's are less stiff, only 10% over stock (just to compensate for the shortened spring length)
Old 07-21-2010, 06:17 PM   #6
yarr_is
Drives: yaris
^^ what he says...
http://www.tanabe-usa.com/nf210.asp?id=2
If you want something higher than that.. the why not just stay stock?
Partially Sponsored by:
Tanabe USA
yarr_is is offline   Reply With Quote
Old 07-21-2010, 06:25 PM   #7
tomato
tomato's Avatar
dude, where have you been. PM me.
Old 07-22-2010, 02:52 PM   #8
yaris4062007
Drives: 07 BB yaris / 06 Mustang Gt
how much is it nf210 ? where can I get them .
yaris4062007 is offline   Reply With Quote
Old 07-22-2010, 04:37 PM   #9
ddongbap
You all should see the under of my car. Its so low, the frame is kinda bashed in. I have a Carbing front control arm bar that was hella bent after hitting a pot hole.
The bottom side of my car looks like that.
Old 07-23-2010, 11:08 AM   #10
Yaris_PR
Yaris_PR's Avatar
Drives: Red Yaris Hatchback on 18's
Send a message via MSN to Yaris_PR
Megan Racing are just 1.5 and cheaper than the others. Check them on ebay...
Yaris_PR is offline   Reply With Quote
Old 07-26-2010, 06:19 PM   #11
yarr_is
Drives: yaris
Too bad that r8 is in europe... and you're in socal... u mad brah?
Tanabe USA
Old 07-23-2010, 11:37 AM   #12
i had eibach prokits on the car last winter....loved them, but not low enough for my taste...
with 205-55-15
on winter 185-60-14's
Old 07-23-2010, 01:28 PM   #13
in my store, here:
http://www.shop.microimageonline.com...ris-TNF210.htm
Old 07-23-2010, 03:57 PM   #14
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
Don't mean to go slightly off-topic, but if you're looking for the best control without a big drop, you could just save a big buck and run stock springs with a rear sway bar. It's all it really needs.
Old 07-24-2010, 02:46 AM   #15
yaris4062007
trd rear sway bar ?
Old 07-24-2010, 03:52 AM   #16
Ultra Racing, 19mm same as TRD but less expensive, .or
23mm only from Ultra Racing
Both in stock!
Old 07-24-2010, 05:42 AM   #17
yaris4062007
Both in stock!
what's the difference from 19mm and 23mm..
does 23mm handles better then 19mm.
is it easy to install. thanx
Old 07-24-2010, 10:28 AM   #18
detroiter
detroiter's Avatar
Easiest performance mod you could do to your Yaris. The 23mm is a bit thicker so it's going to tighten up things a bit more as far as handling goes (keeping the body roll flat). I'd say with the 23mm that while possible to do, have a friend on hand to help fit it on one side while you get the other. Mine anyways, was a very close fit for where you install it, so it helps to have another hand to line it up.
It's not hard to put on at all though. 4 bolts and your done! The difference it makes is quite surprising, especially the 23mm.
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 06:02 PM
Question about Spring rate window_lee Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 10-20-2009 05:22 PM
Spring question? jekqmb Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 08-19-2009 07:54 PM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 11:11 AM
spring rates question botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 05-11-2009 01:33 PM
