Dash rattle TSB needed !
I suffer a dash rattle inside the instrument cluster.
This only occurs with a cold interior. (e.g. when i leave in the morning) After a few km's it's gone. My local dealer "can't find" a TSB, but i've heard about a padding kit somewhere in one of the posts here. Can anyone post the TSB or the Toyota-number of that kit ? Thanks up front ! |
It would be great if all TSB's were located in a specially dedicated section on our forum.
Do you think it's a good idea? Can anybody help with this? Who can make it happen? |
![]() ![]() ![]() Drives: 2007 Toyota Yaris sedan Join Date: Aug 2006
It happened to me. The dealership threw foam strips behind the gauge cluster bezel.
![]() ![]() ![]() Drives: 07 yaris liftback Join Date: Mar 2007
mine did for about 1k miles - then it stopped, but now my drivers side mirror is making a buzzing sound at higher rpms - i've just about given up, seems like you'll always be chasing rattles in this car...
Car forums are kinda like the public library - somepeople are just checking stuff out, and plenty of other people are just telling stories... |
![]() ![]() ![]() Drives: 07 yaris sedan (silver) STICK Join Date: Aug 2006
take the dash apart.. its a pull type. no need to worry. some areas you need to pull harder since its clip on.. but in the end get electrical tape and put it on the ends of these prongs right behind the dash cluster.. only the prongs.. they have NO padding whatsoever.. since then no rattle.. it's been a year and no problems :)
![]() ![]() ![]() ![]() Drives: 2007 Yaris manual dark silver Join Date: May 2006
it could be your air box if you don't have a CAI if you tighten it to much or not enough it rattles squeast
7 Color Tach Fujita Intake Momo pedals Shift knob and boot. Full TRD SSK. Blitz exhaust Megan Lowering Springs (Next is DC Header) |
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
It would be very hard to mistake a dash gauge cluster rattle for an air box rattle. The issue here is the dash gauge cluster.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
![]() Drives: yaris sedan Join Date: Dec 2008
T-SB-0304-08 is the TSB For dash rattle
There's a TSB for early 07 camry's dash rattle. My toyota dealer did that TSB on my yaris.... it went away for couple days, but came back after... then i found out the noise came directly between the cluster and the cluster cover....
![]() ![]() ![]() ![]() Drives: '08 Yaris sedan , '08 Liftback Join Date: Oct 2008
welcome to the club
. This is what you get with cheap plastics . Done the instrument cluster fix for the '08 sedan . Got to the point where it's best to turn up the stereo or keep window down during warm weather so wind road /noise drowns out the rattles . Seems like the more rattles I repair the more pop up that were in unison with other noises or covered by the louder squeaks / rattles .
Audio Junky
thread is a year old boys.
![]() ![]() Drives: Yaris 2009 automatic Join Date: May 2009
is it happen when the rpm is low? Mine also has a problem of rattle noice and the dealer said it's from the dash board. However, they reinstall the foam and said it's gone. It actually didn't gone. I just drive it and it happen again. I am gonna take my car to them to have one more time fix....it's the fourth time I am gonna be there for my car...
I want to make sure if my case is really a dash board problem .... |
![]() ![]() Drives: 2008 White Yaris Sedan 5 speed Join Date: Oct 2008
I just had my dash rattle fixed today per the above mentioned TSB. My rattle occurred in warm temperatures particularly when I first start out in 1st gear.
The funny thing is that the dealer originally told me that it would take 1 or 2 days to fix the rattle and that I would have to leave the car for that period. It turns out that the repair took 1 hour. The rattle is gone. |
#14 | |
![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Dec 2008
#15 |
Compilation of Yaris TSB's: http://www.yarisworld.com/forums/showthread.php?t=9753
--[ FORUM RULES ]--[ SEARCHING TIPS ]--[ EYELIDS PICS ]--[ RBK SPOILER ]--[ BEST/WORST INVESTMENTS ]--
| Rattle TSB I found the other day. | ToyotaTEch21 | DIY / Maintenance / Service | 37 | 05-29-2018 11:17 AM |
| replacing dash | whooppee777 | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 06-26-2007 03:23 PM |
| TSB for steering pull? | vst | DIY / Maintenance / Service | 12 | 06-09-2007 02:40 PM |
| Rattle fixed! | Bretsuaz | DIY / Maintenance / Service | 32 | 03-30-2007 08:39 PM |
| dash problems...help needed | foggy08 | DIY / Maintenance / Service | 1 | 01-25-2007 08:04 PM |
