Old 02-04-2010, 03:09 AM   #1
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
Which clutch to use for daily driver and track days?
hey guys
after my track day sunday i really need to uprate my clutch before i attempt another track day , these are the options i have , what do you guys recon
1 - Exedy stage 1
2 - SPEC clutch USA
also note , i planning to do the turbo conversion in the future , but for now im going NA until i can afford the turbo kit.
thanks guys !!
PS: will the 1.5 1NZFE clutch work on my 2NZFE motor ? i recon it will seing as the gearbox should be the same ?
JDMtuner
Import Performance Tuning
www.jdmtuner.co.za
Old 02-04-2010, 09:31 AM   #2
kngrsll
Apexing Egg!!
kngrsll's Avatar
i have heard terrible things about spec clutches. i would go with Exedy if you get a chance to.
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 02-04-2010, 09:55 AM   #3
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
yeah , i was thinking Exedy aswell
JDMtuner
www.jdmtuner.co.za
Old 02-04-2010, 01:15 PM   #4
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
spec stage 3..
i broke it with 150whp.
Originally Posted by xnamerxx
you nailed it sir.
Tamago is online now   Reply With Quote
Old 02-04-2010, 01:34 PM   #5
Exedy, ACT or does Clutchmasters make one for us now?
I have Exedy, it's stiff and twitchy, and the Stage 1 is holding my power (for now).
Old 02-04-2010, 02:40 PM   #6
Lazerdot
Lazerdot's Avatar
Drives: Blazing Blue 08 liftback
Any idea about the TRD clutch?
One Year One Oil-AMSOIL at www.Trulube.com TRD Exhaust, Springs and Struts. TRD SSK. NST Underdrive Crank Pulley. Amsoil Dominator 10w-30 Racing Oil, Amsoil DOT4 brake fluid, Amsoil Severe Gear 75w-90 transmission oil, Ultra Racing 23mm Sway Bar, Camber Bolts, R1 Drilled Slotted front Brakes and SS Brake cables from Micro-Image. Orange Konig Daylight 17s, Kumo MXs. Greg@TruLube.com
Lazerdot is offline   Reply With Quote
Old 02-04-2010, 04:48 PM   #7
Competition Clutch also has several listed for the Yaris now.
Old 02-04-2010, 10:42 PM   #8
severous01
zoom. it's about the only clutch i'd put on any of my cars other than OEM high performance such as a TRD or GM high performance parts.
Old 02-05-2010, 01:50 AM   #9
2006-2007 16107-0420 1.5L PERFORMANCE CLUTCH KIT - SCC Stage 5 - 4 Pad Rigid Ceramic $395
2006-2007 16107-0620 1.5L PERFORMANCE CLUTCH KIT - SCC Stage 4 - 6 Pad Rigid Ceramic $395
2006-2007 16107-1420 1.5L PERFORMANCE CLUTCH KIT - SCC Stage 5 - 4 Pad Ceramic $395
2006-2007 16107-1620 1.5L PERFORMANCE CLUTCH KIT - SCC Stage 4 - 6 Pad Ceramic $395
2006-2007 16107-1680 1.5L PERFORMANCE CLUTCH KIT - SCC Ironman - 6 Pad Iron $495
2006-2007 16107-2100 1.5L PERFORMANCE CLUTCH KIT - SCC Stage 2 - Carbon Kevlar $395
2006-2007 16107-2300 1.5L PERFORMANCE CLUTCH KIT - SCC Stage 3 - Segmented Kevlar $495
Old 02-05-2010, 01:50 AM   #10
^ From www.competitionclutch.com
Old 02-05-2010, 05:13 AM   #11
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
going with Exedy stage 1 with the flywheel , cant wait to get it in :-)
JDMtuner
www.jdmtuner.co.za
Old 02-05-2010, 12:06 PM   #12
cheaper clutches can be found if you buy ones for a 1zzfe and 2zzge.....same clutch, different flywheel
Old 02-08-2010, 06:12 AM   #13
sujonol78
Drives: 1nz-fe / MT
Send a message via Yahoo to sujonol78
if you are still using it as your daily transport, i would suggest TRD clutch ( sport type, not the metal facing ) because TRD clutch does not increase the pedal preasure
sujonol78 is offline   Reply With Quote
Old 02-10-2010, 11:05 AM   #14
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
I have an OEM 2ZZ-GE clutch in my Echo. Slightly stiffer pedal, but is 100% streetable and I can't slip it. I've got nearly every type of performance bolt on except for a SC or Turbo.
Or you can just order the pressure plate as it's the only real difference.
Old 02-10-2010, 01:54 PM   #15
NonStopTuning
We've been using SPEC clutches on a number of cars here over the past few years, always with great success.
I have tried a number of different clutch companies over the past decade or so, and the only one I sell is SPEC.
MIKE @ NST
www.NonStopTuning.com
Old 02-10-2010, 04:08 PM   #16
Tamago
Tamago's Avatar
Drives: ZZW30
a picture's worth a thousand words
you nailed it sir.
Old 02-10-2010, 04:11 PM   #17
tk-421
tk-421's Avatar
Drives: 5D-07-LB
ACT Stage 1 FTW
Old 02-10-2010, 05:16 PM   #18
Art recommends ACT, he's got that one on his 280 whp xB, works great.
Making YarisWorld Proud- Yaris at Thunderhill in Nor Cal Vanderkitten Tracking, Racing, Auto-X Forum 23 10-24-2008 11:03 PM
