Old 09-17-2007, 03:14 PM   #1
drecian
drecian's Avatar
Drives: '07 YR 3dr
Speed signal wire
Anyone know which wire leading to the OBDII connector/port is the speed signal wire?
Cheers
"I drive a silver egg"
"Huh?"
"An egg... You know; pretty much round, but with a pointy end; jeez..."
drecian is offline   Reply With Quote
Old 09-17-2007, 05:47 PM   #2
joey1320
joey1320's Avatar
Drives: Yaris LB
you mean car speed or engine speed?
if you are looking for vehicle speed the only one i was able to find was the signal to the speedometer, heres the link for the repair manual, is on pages 226 and 227.
http://www.etimago.com/yaris/repairmanual/EWD.pdf
and heres the pic for the tach/engine speed.
joey1320 is offline   Reply With Quote
Old 09-17-2007, 10:45 PM   #3
project y
Drives: yaris
trying to bypass the speed cutout?
project y is offline   Reply With Quote
Old 09-18-2007, 12:53 AM   #4
drecian
drecian's Avatar
Drives: '07 YR 3dr
Heh not really. I have an APEXi Rev/Speed meter that I've currently got hooked up to display revs and g-forces (front/back and lateral), and was just thought if it was easy enough I may as well give it a speed input so I can record and replay laps at the track...
"Huh?"
Old 09-18-2007, 07:08 AM   #5
gonzo452001
gonzo452001's Avatar
Drives: 3-door liftback blazing blue
this will tell you where the vss wire ishttp://www.thecruisecontrolstore.com/newyarisinst.pdf
07 yaris LB 5-speed blazing Blue
07 yaris LB Auto Bayou Blue
rostra cruise control
oem style foglights
96tacoma 4x4 xcab I4auto
Weathertech vent visors
Scan GaugeII
gonzo452001 is offline   Reply With Quote
Old 02-03-2009, 07:52 AM   #6
lunjiaow
lunjiaow's Avatar
Drives: Yaris
i just got an RSM. Hooked it up, but the RSM isn't getting any signal. Spliced into PIN 26 (Purple) which is supposed to be the VSS. Can anyone confirm if its the right wire? Maybe i have to change settings on the RSM itself.
lunjiaow is offline   Reply With Quote
Old 02-07-2009, 02:59 AM   #7
lunjiaow
lunjiaow's Avatar
Drives: Yaris
Anyway. Had a look into the Manual. Found a working speed sensor wire which connects to the instrument cluster 24pin plug. Its pin 17 (pink).
Old 09-08-2009, 08:10 AM   #8
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
where on the OBD2 port connector can i find the speed signal wire ?
JDMtuner
Import Performance Tuning
www.jdmtuner.co.za
Old 09-08-2009, 08:21 AM   #9
Kiz
Kiz's Avatar
Drives: '06 Yaris Hatch and TT 300ZX
It's not on the OBD2 port connector. The OBD interface sends serial data, there aren't individual wires for different sensors. You'll need to get the speed signal from the cluster loom or ECU loom.
'06 LB 2NZ-FE w/ NST crank pulley "No RWKW" | '89 2+2 VG30DETT Z32 300ZX "Lots RWKW" ;)
Kiz is offline   Reply With Quote
Old 09-08-2009, 09:04 AM   #10
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
ahhh. i thought maybe where i got the Tach wire signal from , there might be a wire i can piggback off. then how does the Scangauge get speed data from the OBD2 port ? must be one of those wires sending speed info ?
JDMtuner
www.jdmtuner.co.za
Old 09-08-2009, 09:16 AM   #11
Kiz
Kiz's Avatar
As mentioned in lunjiaow's post, he got the speed signal from the pink wire going to the gauge cluster. You'll need to find the wire going to the gauge cluster with the tach signal for your application.
For reference, the common wires in the OBDII connector are simply 2xData, 1xground and 1xpower. The scanguage reads the serial data and processes it for it to display to you.
Old 09-09-2009, 02:44 AM   #12
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
ahh ok cool !! thanks alot buddy !! appreciate the help ! will have a look for that illusive pink wire , hehe !!
JDMtuner
www.jdmtuner.co.za
Old 06-14-2010, 08:19 PM   #13
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
Hooked up Avic D3 today in 2008HB and the pink wire in the speedo harness,is indeed a god wire to hook to for speed pulse,navi is now learning....hope this confirmation helps other looking for the VSS wire in an easy place.
DIY: Replacing Stock Mirrors redyaris DIY / Maintenance / Service 30 04-20-2016 04:03 PM
ICE Navigation Wire Question? duck In Car Entertainment + Electronics (audio / video / alarm) 11 10-25-2008 01:20 AM
Speed Wire? R0ME0 General Yaris / Vitz Discussion 2 04-26-2007 02:44 PM
Signal electrical questions Blenjar In Car Entertainment + Electronics (audio / video / alarm) 3 01-19-2007 02:06 PM
Harman Kardon Drive + Play for IPOD sroberts In Car Entertainment + Electronics (audio / video / alarm) 5 07-01-2006 02:05 PM
