Old 05-10-2009, 08:36 PM   #1
808_Yaris
Where is Oahu?
808_Yaris's Avatar
Drives: 5-door meteorite metallic
Post Blitz throttle controller
I bought the blitz throttle controller because I wanted a more sensitive acceleration when the pedal was pressed.
Some info off the blitz web site: Recent trend of automobile equipped with Electric Controlled Throttle Valve replaced from Mechanical Throttle Valve (Cable type). The electrically controlled throttle valve is one of updated technology in automobile industry and the technology brings a precise throttle valve control enable to adjust acceleration characteristic for much more fuel conservative yet causing gap in acceleration response in the other end.
BLITZ Throttle Controller eliminates acceleration gap as much as possible by converting electric signal by the use of pre-programmed characters (modes). Throttle Controller is an item which improves acceleration response.
The unit includes Vehicle Specific Wire Harness, which makes Plug & Play easy installation (some vehicle may require 12v power wiring). Most application simply plugs in Vehicle Specific Wire Harness in between a accelerator-pedal position sensor and a factory stock wiring which is most of time located close to accelerator pedal. Display Units and Control Box are separated individually made display unit light and compact enough to place easy on dashboard area.
BLITZ Throttle Controller is a most reliable unit among in the market as well as an easiest solution to improve accelerator response.
Picture of Blitz throttle controller
Plug on top of the acceleration pedal that I'm connecting to. I put a mirror on the side of the plug so you can see how to take the plug off.
Plug off. Took it off with my hand, it was a little hard to take off, but I eventually unplugged it.
Blitz plug connected to the top of acceleration pedal
Other Blitz plug connecting to the other plug that comes from the car engine. Sorry, I don't know what to call the plugs, but it's pretty self explanatory.
Installed
From there, plug the plugs into the blitz module. I positioned the module behind my AC contols.
*******IF INSTALLING THE REVERSE CANCEL HARNESS*********
Reverse cancel harness comes with a pink wire about 10 feet long. It's optional, but I'd highly recommend it because I did not want my acceleration pedal to be jumpy when reversing. I basically connected the pink wire to the module, the manual shows which pin to input the wire. I then ran the wire to my positive side of the back left reverse light. I tried to locate where the reverse wire was in the car, since I was lazy, but played it safe and ran the pink wire to the reverse light in the back. Pics are below
Driver's Side front door
Driver's Side back door
Trunk
I tapped into the reverse light in the back, but forgot to take a pic. Position the controller wherever is most convenient for you, and enjoy!!
Modes for Controller
eco-better to use this for daily driving
sp1-feel the acceleration at startoff-good for regular driving
sp2-medium acceleration at startoff-good for medium driving
sp3-jumpy acceleration at startoff-good for highway use
808_Yaris is offline   Reply With Quote
Question about Blitz Throttle Controller AlainMikli Performance Modifications 20 12-10-2010 04:00 PM
blitz throttle controller does it work.. marcus Performance Modifications 39 06-21-2009 08:40 PM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 09:52 PM
For those with Blitz Throttle controller... mastaofdisasta Performance Modifications 0 12-28-2008 09:26 AM
toyotafest 2007 esquiva Photo-Video-Media Gallery 36 05-15-2007 01:03 PM
