![]() ![]() ![]() Drives: 08 Yaris HB Join Date: Nov 2009
The purpose of camber bolts to fix any camber issues correct? is there any camber bolts for the rear? and Also are camber bolts necessary if I plan to run negative camber? Thanks everyone!
There is no adjustment for the rear.
The bolts you speak of replace the bolts holding the struts to the hub. They allow you to change front camber. |
Shims (ie stainless steel washers) placed between the axle and brake drum on the lower two bolts.
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
hunter makes a shim kit also. it's much easier and a more direct use for hunter aligners. if you're rear alignment is out and they say that they can't do the rear cuz there's no adjustment...buy a shim kit for 10 bucks and have them install it. specially if they're using hunter machines.
you can buy shims from hunter.com. |
microimageonline.com also sells rear camber shims
| New to Forum -suspension question!! | SparkyTheYaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 09-09-2010 04:11 PM |
| Noobie suspension question?? | Richie76 | Australia | 6 | 12-27-2009 09:27 PM |
| Yet another suspension question | mastaofdisasta | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 04-16-2009 02:19 PM |
| n00b suspension install question | The Stig | DIY / Maintenance / Service | 25 | 07-12-2007 08:58 AM |
| Technical Question for the Suspension Gurus | KwonSau | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 06-21-2007 11:31 PM |
