Old 01-23-2011, 10:23 PM   #1
zuberio
Joined 3/08 ... really
zuberio's Avatar
Drives: '07 Sedan
Lightbulb Relay Wiring for DIY LED Daytime Running Lights (DRL)
So we all know how to easily disable the DRLs if we have them. But I actually want to add some LED DRLs and all I've been able to find so far is the DRL-1 product from Webelectric.
So my question to Yarisworld (& CTScott) is - if I hook up two SPDT relays in series per the attached drawing ... will it work?
And if it will work ... do I need to be concerned that I'm running a coil off the same line that's power my headlights?
Basically, I'm running the power to the DRLs through the series connected relays - and if either Hi or Lo beam is active, the energized coil will break the circuit supplying power to said DRLs.
zuberio is offline   Reply With Quote
Old 01-24-2011, 10:56 AM   #2
Here's a one relay method - My headlights off with the ignition switch DIY. With it you can just leave your headlight switch on all of the time:
http://www.yarisworld.com/forums/showthread.php?t=14427
If you want the LEDs instead of the headlights as DRLs, your method is fine. Just use the ignition switched power from my DIY for the 12V feed for yours.
Old 01-25-2011, 12:40 AM   #3
zuberio
zuberio's Avatar
Drives: '07 Sedan
THANKS!!
Old 02-13-2011, 06:37 PM   #4
zuberio
zuberio's Avatar
Drives: '07 Sedan
So I went out to the car with a multimeter and the electrical wiring diagram for the '07 Yaris and I think I figured out where I need to tie in with splices.
Please take a look and tell me what you think.
Old 02-13-2011, 09:45 PM   #5
Perfect!
Old 02-13-2011, 10:33 PM   #6
Lil Abner
Drives: 2009 3dr LB Manual
zuberio, you could also use a single relay in that setup with 2 diodes. If you put a diode on each "low" and "high" signal wire, then both into the #86 terminal on the relay. But I think it would come down to what parts you have or want to purchase.
Either way, I'll be watching to see what you use for your LED DRLs!
Old 02-14-2011, 12:51 AM   #7
zuberio
zuberio's Avatar
Drives: '07 Sedan
Good catch - why didn't I think of that!?
And to answer your question, here's what I'm using for the LED DRLs.
I'm about 50% done with the wiring .... I just discovered Scotchlok connectors and ordered some off Amazon to make my life easier. I'll post pictures when everything is installed and running :)
Old 02-14-2011, 11:40 AM   #8
Lil Abner
Nice looking DRL's.
Yeah, the Scotchlocks or T-Taps are amazing. I switched over to the T-Taps for this car. Makes life so much easier!
Old 02-14-2011, 02:08 PM   #9
big lo
big lo's Avatar
Drives: 2007 VIOS
I really need to see the out come to this project,
Old 02-15-2011, 02:33 AM   #10
zuberio
zuberio's Avatar
Drives: '07 Sedan
Nice looking DRL's.
Ooooo, T-Taps - just Googled them, very cool. Someone should have a beginner wiring FAQ on this forum ... Unless it already exists.
Me too! lol.
Old 02-18-2011, 03:47 AM   #11
zuberio
zuberio's Avatar
Drives: '07 Sedan
DONE! :D
Woho! I should really be asleep right now ... but I'm posting the finished product instead :D
Old 02-21-2011, 02:54 PM   #12
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
If I want only Lo Beams to turn off DRL, would I just wire the relay like as pictured in (Lo)?
Check out my Build thread:
Old 02-27-2011, 11:42 AM   #13
Lil Abner
zuberio, that looks sweet dude! How does it look from really far away (like an oncoming car)?
Old 03-06-2011, 05:22 PM   #14
zuberio
zuberio's Avatar
Drives: '07 Sedan
Yes - you'd only need one relay as well.
Honestly ... I don't know. I'm always the one driving the car. Sorry.
Old 03-09-2011, 01:43 AM   #15
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Cool man! but how did you mount the DRLs on your bumper? Any pic or a DIY on them?
rye7jen is offline   Reply With Quote
Old 03-09-2011, 10:54 AM   #16
zuberio
zuberio's Avatar
Drives: '07 Sedan
They're peel-n-stick :) Just had to drill a small 1/8" hole at one end of each strip for the wire and then just stuck them on.
Old 05-19-2011, 12:49 AM   #17
toy_toronto
always toyin'
toy_toronto's Avatar
Drives: 2010 5-Dr
Thanks for the idea zuberio -- nice work!
I recently installed an HID kit but now missing the DRLs since I had to disconnect the relay underneath the dash. I'd like to get the DRLs back therefore I plan to do this relay DIY to my hatchback, but the difference is I just want to use the existing parking lights inside the headlights as the DRL lights (see pic below).
I'm going to be replacing the bulbs with the brightest/white 194's LED that I can find to make them more visible in daytime.
I've searched the forums but had difficulties finding the info... Do you have a link where I can find the hatchback headlights wiring diagram so I can splice the hi/lo signal source to the relay?
thanks!
-toy
Old 05-19-2011, 12:56 AM   #18
jonathankoji
jonathankoji's Avatar
Drives: 08 Yaris S Sedan
Pics look great man! Can we please have some more
Did you photoshop those photos, was it just the camera, or are they actually that bright in person ?
jonathankoji is offline   Reply With Quote
drl, headlights, led, relays, wiring
our DRL is running in pulse............. marcus Cosmetic Modifications (Exterior/Interior) 14 06-21-2010 10:49 AM
Daytime Running Lights Module amtoro Willing to Buy by private party 1 11-13-2009 11:32 AM
DayTime Running Lights ISSUE!!!??!?!?!?!2009 5-door-hatch powermicro In Car Entertainment + Electronics (audio / video / alarm) 1 05-14-2009 01:12 AM
Need Help Wiring Fog Lights MadMax Cosmetic Modifications (Exterior/Interior) 29 11-29-2008 07:31 PM
Daytime Lights NimbleYarisOwner General Yaris / Vitz Discussion 17 08-24-2007 10:07 AM
