Old 02-13-2011, 11:51 PM   #7
zuberio
Joined 3/08 ... really
zuberio's Avatar
Drives: '07 Sedan
Originally Posted by Lil Abner View Post
zuberio, you could also use a single relay in that setup with 2 diodes. If you put a diode on each "low" and "high" signal wire, then both into the #86 terminal on the relay. But I think it would come down to what parts you have or want to purchase.
Either way, I'll be watching to see what you use for your LED DRLs!
Good catch - why didn't I think of that!?
And to answer your question, here's what I'm using for the LED DRLs.
I'm about 50% done with the wiring .... I just discovered Scotchlok connectors and ordered some off Amazon to make my life easier. I'll post pictures when everything is installed and running :)
zuberio is offline   Reply With Quote
Tags
drl, headlights, led, relays, wiring
our DRL is running in pulse............. marcus Cosmetic Modifications (Exterior/Interior) 14 06-21-2010 09:49 AM
Daytime Running Lights Module amtoro Willing to Buy by private party 1 11-13-2009 10:32 AM
DayTime Running Lights ISSUE!!!??!?!?!?!2009 5-door-hatch powermicro In Car Entertainment + Electronics (audio / video / alarm) 1 05-14-2009 12:12 AM
Need Help Wiring Fog Lights MadMax Cosmetic Modifications (Exterior/Interior) 29 11-29-2008 06:31 PM
Daytime Lights NimbleYarisOwner General Yaris / Vitz Discussion 17 08-24-2007 09:07 AM
