Old 05-03-2013, 04:53 PM   #1
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
Is the cutoff RPM or Speed?
simple question as that. I noticed that at 113 MPH the car loses power but i have been 117 MPH before. so was it supposed ot cut off at an RPM or at a speed?
Rev-limiter or Speed-Limiter?
Old 05-03-2013, 05:27 PM   #2
Both.
Rev limiter is 6250, speed limiter is approximately 115. It's possible to "cheat" either one a little depending on driving conditions, as shown by varying reports.
Old 05-03-2013, 08:38 PM   #3
Mittelklasse
Problem, officer?
Mittelklasse's Avatar
Drives: '06 Yaris 5DLB 1.5
Both.
Mine (1.5L) revs up to 6,400 RPM.
I heard that pulling the parking brake just 1 click will override the speed limiter.
But I really didn't notice the effect. Maybe that was the fastest my Yaris will go .
Mittelklasse is offline   Reply With Quote
Old 05-04-2013, 10:43 AM   #4
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Both.
^ He is right to a point. It is actually 118 which is programmed into the stock ECU. The major catch here is how Toyota actually performs both limiters which is probably the easiest way for them to do it and and that force the fuel system to go stupid lean which really isn't good for the engine. Not saying that you will blow up a totally stock motor after hitting the limit too much, but it will increase wear/tear on it. Just something to be aware of. I honestly have no idea how other manufacturers do it, perhaps it is the same
Old 01-01-2014, 05:59 AM   #5
sniper05
Drives: Yari
Hello guys,
can anyone help me..I just did an engine swap using 1nz-fe 1.5L. unfortunately, I experienced the engine cut off at around 2500-3000 rpm.
Thanks in advance.
sniper05 is offline   Reply With Quote
Old 01-01-2014, 06:12 AM   #6
junorico24
junorico24's Avatar
Drives: toyota yaris yrs
Originally Posted by sniper05 View Post
Hello guys,
Thanks in advance.
It's normal mate.
1st to 2nd gear : 2500 to 3000 rpm
3rd to 4th : probably the same.
Old 01-01-2014, 10:26 AM   #7
JustPassinThru
Drives: No more Yaris
Okay...so there IS a engine-speed limiter in the computerized fuel-injection/emissions system?
I didn't know that.
JustPassinThru is offline   Reply With Quote
Old 01-01-2014, 03:53 PM   #8
fnkngrv
fnkngrv's Avatar
Yes....the way the ECM handles via the speed sensor and cluster is that once the speedometer returns that 118 has been reached then the ECM leans out your fuel drastically to "force" you to reduce speed. I found that it would drop me depending on the suspension setup (for example wheel/tire combo) I could lose between 8 on the high end and 4 on the low end of mph lost. I found this out over 20+ land speed runs which gave a great way to figure it out. Essentially riding off the speed limit cut is a bad thing.
Old 01-01-2014, 05:57 PM   #9
JustPassinThru
Okay. But is it also linked to engine RPMs?
I have an automatic and no tachometer. From time to time, once every couple of years or thereabouts, I have cause to be in the Rockies. I don't like to ride the brakes down long downgrades; with a manual and tach it's of course easy to monitor RPMs. And shift.
With an auto, if 3 doesn't give enough engine braking, I might want to use 2 - but shifting in and out of it is gonna be hard on the motor mounts. I don't want to over-rev when climbing short upgrades.
...as well, once I got my floor mat lodged on the accelerator pedal with my manual - as I was running up the gears. Engine ran away when I got on the clutch. It was my 2009 and brand new at the time; and I'd always wondered if I'd over-revved it (of course I was too busy trying to figure out what was going ON at the time to be staring at the tach).
So...speed only? Or RPMs, also?
Old 01-01-2014, 08:00 PM   #10
fnkngrv
fnkngrv's Avatar
According to what we saw during the dyno pulls the rpm limiter was forcing into lean conditions as well however the behavior was different as you don't necessarily lose power as you do when you hit the speed limiter.
IL: Chicago - Haunted RPM Car/Bike Show - October 20th, 2012 RPM JEFF Great Lakes 0 09-24-2012 05:40 PM
IL: Chicago - Haunted RPM Car/Bike Show - October 20th, 2012 RPM JEFF Mid-Atlantic 0 09-24-2012 04:10 PM
LOW RPM @Idle speed = Bad Volt Generation? jp_costarica General Yaris / Vitz Discussion 4 06-14-2012 05:56 PM
The most economical speed for the Yaris. Ilovemyyaris Fuel Economy Forum 3 03-19-2012 12:33 PM
RPM at 60 mph 5 speed manual mark schofield DIY / Maintenance / Service 13 10-08-2011 01:14 AM
