Joey
Drives: '14 Scion xD 5-speed Join Date: Oct 2008
All maintenance requirements based on mileage intervals
Here's an invaluable link for each 5K service requirement up to 120K:
http://www.toyotaownersonline.com/pa...rvice/diy.html Mods: please sticky this
Formerly owned Met-Met. '07 Yaris LB 5-speed. A forum post should be like a skirt: Long enough to cover the subject but short enough to keep things interesting. "I don't have an anger problem. I have an idiot problem." -Hank Hill |
Drives: Yaris 2DR LB 07, MT, Abs. Red Join Date: Feb 2009
Totally. Thank you!
Joey
You're welcome
![]() ![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Jan 2010
I checked every service interval and none said to change manual transmission fluid or coolant.How caan that be?
#5 | |
![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris S Sedan 5-Speed Join Date: Oct 2008
It does mention coolant at 100K and then every 50K thereafter. Spark plugs at 120K. Other than that, nothing else is listed to be replaced or changed other than oil, tire rotations, and air filters except for inspecting things. |
![]() Drives: yaris CE 2007 Join Date: Jan 2010
howdy all
anyone in Canada have the Data Tester available to be used for Diagnostics ..... if so pls write to Cowboy thanks |
![]() ![]() ![]() ![]() Drives: Copper Orange Mica Yaris Join Date: Feb 2006
http://www.toyota.ca/cgi-bin/WebObje...110000e%2ehtml
There you can check all your maintenance interval. Auto transmission is to be changed 96000km >>192,000km >> 288,000km >>384,000km
![]() My Copper Orange Mica Yaris with 9.3lb Kosei K1 TS http://www.yarisworld.com/forums/showthread.php?t=10951 http://www.yarisworld.com/forums/showthread.php?t=13882 http://www.yarisworld.com/forums/sho...180#post472180 |
DAT'S RIGHT I GOTz 2
toyota
wow spark plug change at almost 200k
![]() Drives: 2010 Toyota Yaris Join Date: Oct 2010
Thank you guys for the links.
Here in Manila we do a 5000 km interval. The service advisers are insistent on this schedule. Since you use miles, you get 3000kms more between service schedules. You get to save more. |
![]() ![]() Drives: 2008 5 Speed Sedan Join Date: Jan 2011
do you need to complete everything they say?
I probably drive my Yaris alot more than most people, and i'm approaching the 128,000km service (approx 80,000 miles) it's a 2008 so really I shouldn't be at this servicing for another 1.5 - 2 years according to the dealer.
it's getting quite expensive, this service i've got: Maintenance Service (104.99) - Inc oil filter and change Cabin air filter - don't care, i clean it myself Manual transmission fluid (37.95) - Drain and fill - not a flush Super long life coolant (65.95) - Drain and fill - not a flush 208 + tax and thats assuming I don't need brake pads or anything else. I've followed every service so far in the manual, always on time, never missed anything - no warranties left on the car except maybe major emissions. do I really need to keep doing all this or can I just go with oil changes? No problems, love the car works great. thanks for any advice |
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
Jee. Yes, just oil changes.
And take it somewhere cheaper! Oil & Filter: $26 mobile 1 synthetic, $8 some filter, $15 some quick lube to change it for you. Cabin Air filter: as long as its there, it doesn't have to be clean. Manual Trans Fluid: wow, at least you got something cheap! Coolant: $22 for a gallon, and extremely easy to do yourself over a drainage hole. |
![]() ![]() ![]() ![]() Drives: 2009 Meteorite Metallic LB MT Join Date: Oct 2008
Crazy Oil Sniffer
Drives: MM 09 Yaris 5 Dr LB "Click" Join Date: May 2009
I am hopeful swidd was joking.(?) Dumping coolant into the environment is NOT a good idea. Ethylene Glycol is extremely toxic and a relatively small amount can kill a child or small animal who may be attracted by it's sweetness. Who knows where it will end up. Collect it and recycle it. It doesn't take much more effort to be responsible.
#16 | |
Bronze bombshell yaris
Drives: 09 Yaris HB 3door Join Date: Sep 2010
Dead cat.
Now I drive a CARMINE RED METALLIC 09 Yaris 3-door!! I'm Back!!! WooHoo!! Mods done so far: Tinted windows, Viper 211HV Remote Keyless Entry, Atoto Android headunit, backup camera, steering wheel controls Before it was totaled I drove a 2007 Black Sand Pearl 3 Door Lift-Back M/T with 49k miles. Stock Everything except for black tint, all red badges, red dash, and stealth garage door opener. Ultra-Gauge mounted on steering wheel. A1 Electric MES Central Locks and Avital 3100 Alarm system.
![]() Drives: Yaris 2007 3 doors Join Date: Jul 2009
Timing belt
I don't see anywhere the timing belt being mentionned
do we have a timing chain in them little engines , or is that something not mentionned anywhere for interval replacement ???? .. .. found an old subject on the web .. .. "Power is from the 1NZ-FE 1.5-liter four-cylinder engine familiar from the Scions and the Prius. Here is makes 106 horsepower at 6000 rpm, with 103 lb-ft of torque at 4200 rpm, and drives the front wheels through either a five-speed manual or four-speed automatic transmission. Like most current Toyota engines, it is an aluminum alloy unit with dual overhead cams, four valves per cylinder, VVT-i variable valve timing, coil-on-plug direct ignition, and electronic throttle control. There is a timing chain, not a belt, for lower maintenance. " .. I guess that answeres my question , timing chain , HOURRRAAAAA !!! Last edited by Kazimodo; 02-07-2011 at 02:03 AM. |
#18 | |
Saves about $800-$900 every 100K. |
| Performance mods that won't affect/will hardly affect gas mileage?? | Mr.Yaris | Performance Modifications | 15 | 07-30-2007 12:32 AM |
