Old 02-24-2014, 12:00 PM   #1
rexseesyou
Drives: 2009 Toyota Yaris Sedan S
Stock OEM front struts, aftermarket rear shocks?
Does anyone run this type of setup? Or do you have to replace the struts and shocks altogether? Thanks!
rexseesyou is offline   Reply With Quote
Old 02-24-2014, 12:02 PM   #2
rexseesyou
^^^If you have this setup, will the car drive okay? Thinking about getting Tokico blues for the rear, but don't know if I have to change the front struts as well.
Old 02-24-2014, 12:38 PM   #3
With the Yaris having so much of its weight up front (and being front wheel drive), the fronts are really more important for performance than the rears are.
Old 02-24-2014, 12:43 PM   #4
rexseesyou
Thanks, CTScott. I was wondering about that. I'm trying to dampen the rear cause it'll occasionally bottom out on dips on the freeway especially with people (I have a large sub box in the trunk)
Old 02-24-2014, 01:04 PM   #5
I am not sure that rear shocks will completely cure that. The bottoming out is due to the springs fully compressing. Stiffer shocks will slow that process down a bit, but will still allow you to get to that point. I would think that stiffer springs (or something adjustable) back there would be the solution.
Old 02-24-2014, 01:12 PM   #6
rexseesyou
Thanks for the tip!
Old 02-24-2014, 01:17 PM   #7
Thanks for the tip!
I may not be completely correct with my assessment, so hopefully some of the lowered people will weigh in on this.
Old 02-24-2014, 01:27 PM   #8
IllusionX
Drives: 07 Yaris Sedan Aero
stiffer rear will get you more over steer. It could be very dangerous if you are inexperienced driver..
If you do get stiffer springs, be sure to use the same spring front/rear ration than OEM, unless you know what you are doing.
Old 02-24-2014, 01:30 PM   #9
rexseesyou
I'm running Eibach Sportline lowering springs right now.
Old 02-24-2014, 01:36 PM   #10
^ Now he tells us. LOL. So yes, you are lowered and bottoming out, with passengers and an audio system. Sounds about right. Stiffer rear shocks will help, but Tokico HPS blues may not be enough. HTS reds are adjustable, I'd have to check to see if I can get a pair only.
You can also get shock bump stops or spring spacers to prevent the bottoming out, BUT there is a sacrifice in ride quality when they hit the stops.
Old 02-24-2014, 01:42 PM   #11
rexseesyou
Haha, yeah that info probably would have helped. Thanks for the info. And yeah, rear passengers + audio system = bottoming out on dips DUH!
I just won't drive anyone in the back anymore... do you have a 2 seater conversion, cali yaris? hahaha, jk
Old 02-24-2014, 02:47 PM   #12
MyzticZ3r0
It's called removing the backseats ;) It's free!
MyzticZ3r0 is offline   Reply With Quote
Old 02-24-2014, 03:56 PM   #13
rexseesyou
^^^true that
Old 02-24-2014, 04:14 PM   #14
tk-421
tk-421's Avatar
Drives: 5D-07-LB
^^ agreed with Myztic. It's much cheaper to find out if it works, anyway.
Old 02-24-2014, 04:57 PM   #15
Well, actually, yes.... yes I did.
Old 02-24-2014, 05:54 PM   #16
rexseesyou
^^^AWESOME!
Old 02-25-2014, 09:33 AM   #17
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Just put your stock springs back into the rear. Simple and free.
Old 02-25-2014, 12:07 PM   #18
^ But he has Sportlines, that would make the car look horrible.
09 Stock HU - front and rear AUX in? azeeroth In Car Entertainment + Electronics (audio / video / alarm) 1 08-10-2012 10:37 AM
Aoe TigerTec..4k front, 3k rear....Tein Stech 3k front, 3.5k rear? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 10-15-2009 10:44 AM
