Old 08-10-2007, 08:02 PM   #1
Rotorheader
Drives: 07 Yaris Hatchback
New Foglights with Wireless PILOT switch
I did the standard install for my fogs this morning, but used a wireless remote switch by PILOT, rather than the on-off switch by the emergency brake. I had to bring a single wire into the cockpit for power thru an Add-a-Fuse under the driver's dash. I found a ready-made hole behind the styrofoam block under the area where my left heel would rest.
I now have an On-Off switch on a remote fob; and can activate it when the ignition is on. When I turn the ignition Off, the fogs go off, too.
All in all, a rather easy install, took about two hours. I ended up completely taking the plastic nose off the front. Also chaanged out my horn while there; installed a pair of Framms
Rotorheader is offline   Reply With Quote
Old 08-10-2007, 08:56 PM   #2
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Is this the remote switch you're referring to?
http://www.autobarn.net/pirecosw1.html
Also, some pics of the installation would be great, since this seems to be much cleaner.
TIA!
Old 08-11-2007, 11:59 AM   #3
Rotorheader
Here's a link to the PILOT remotes. I toss the lights on the shelve, and just use the remote and the sensor.
http://www.cardomain.com/item/PILNV504W
I've bought the remotes by themselves on eBay for just a little bit.
Old 08-11-2007, 12:03 PM   #4
Rotorheader
http://www.autobarn.net/pm172.html
And here's another option with some possibilities.
replacement fog light switch? yrsdrgn Cosmetic Modifications (Exterior/Interior) 4 07-17-2007 05:11 PM
Question about switch sizes ChinoCharles In Car Entertainment + Electronics (audio / video / alarm) 8 03-17-2007 01:44 PM
When to switch to synthetic oil? jay DIY / Maintenance / Service 65 02-15-2007 09:44 PM
Foglight Switch Yarii Cosmetic Modifications (Exterior/Interior) 12 09-26-2006 05:20 AM
can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. fantabulousbaby Cosmetic Modifications (Exterior/Interior) 22 08-29-2006 02:13 PM
