![]() Drives: 2007 Yaris Liftback Join Date: Apr 2007
Integrated CD Player LED Changeout
Well it's been a busy weekend. I disabled DRL's, replaced the bulbs in the gear shifter and the 3 climate control knobs, and removed the stock stereo and replaced the green LEDs with blue. Everything looks good, but I noticed now that the green display is blue it's harder to read the black digital readout. Has anyone made this mod to the display at least a year ago. I was wondering if over time anyone experienced missing segments on the black digital readout that is backlit by the new blue LED's?
the razzor man
I drive a yarrrris
Drives: 07 Sedan Polar White Join Date: Sep 2006
are you saying that you have a solid black read-out and you cant read any letters/numbers?
if that is the case, you may have to take it all apart again and make sure that you have the metal casing around the LCD tabs bent to create a solid connection to the circuit board. if that not the case, you may want to rotate between white and blue (as too defuse the darkness of the blue), but thats just and idea...
![]() Docotrs say all the drikning has mesesd up my seplilng and radieng will work for parts |
Hey lush, how poor does LCD visibility get when you change the backlighting to blue? Should I consider leaving any panels white for the sake of being able to see them? I know razzorjet already said it gets bad, but the question is how bad. High resolution pics would be sexy, but not necessary.
Lonesome Cowboy
Drives: 2007 WHITE HATCHBACK Join Date: Feb 2007
PICTURES, please
I am planning to do this very soon. I may end up with green and blue. ![]() or orange and blue??? hmmmm?
SPONSORED BY
I drive a yarrrris
here are some change outs:
OgDoggs (All blue): http://www.yarisworld.com/forums/sho...9&postcount=40 Bones (All blue): http://www.yarisworld.com/forums/sho...9&postcount=17 ||)) (o) ||\|| (blue and white): http://www.yarisworld.com/forums/sho...1&postcount=27
#6 | |
Lonesome Cowboy
Thank you Vodka, I've seen these pictures and I think they came out great. I was wondering how this guy's came out since he is having some visability issues. Thing is there are no pictures of a liftback completed.
SPONSORED BY
I drive a yarrrris
not that I know of...
call out to razzorjet2, take some pics and post them up!
![]() ![]() ![]() ![]() ![]() Drives: 2007 Bayou Blue!!!!!!! Join Date: Nov 2006
I agree, maybe the LB is trickier, but one wouldn't think so.
Hey everyone,
Just wanted to clarify a little. When you go to blue since the LEDs are brighter than the green ones, you will notice that the black segments (where the track number, root folder etc) are not as black as they were with the green. You can read them fine, they are just not as deep black as they were with the green. Be careful when you reassemble the LCD to the board, I had some missing segments due to the poor zebra strip alignment inside the LCD housing. That's the danger in removing the LCD from the board, you may have to disassemble then reassemble a time or to to get all of your black segments to be visable. As to the integratated buttons (AM , FM , FM2) that all looks great. I'll try to get some pictures up, but i don't have a digital camera, so I'll have to borrow one.
the razzor man
Lil White her name is ~
Drives: White YRX 5DR Hatchback 2006 Join Date: Dec 2006
Talking about changing LEDs on the stock CD Player ~ I'd like to do it as well ~
Problem is.....I have a totally different player to you guys and I have a liftback ~ Any ideas? http://www.yarisworld.com/forums/sho...5791#post75791 That is my CD player.....it's not lit up cause I didn't turn the lights on ~ Jaspie ~ Last edited by jaspie; 04-16-2007 at 08:45 AM. |
Man I have a different unit then both of those. I will take some pics tonight it is the JVC unit.
Hey all,
Brick and Vodka, I work as an electronic technician, so I'm a little picky when it comes to LCD displays. The average guy probably would'nt be too concerned. The instructions you guys posted are excellent and I don't want to discourage anyone from doing the changeout. Just be prepared that the black isn't going to stand out as well with the blue LED's. And a few tips as to the soldering- use tweezers to place the new LEDs, and don't hold the iron on your new solder joint too long, you will either melt of fry the new LED. Also make sure you use a fine point tip on your iron, you'll probably melt the LED otherwise. I would suggest using a Weller iron. Any other questions send me a message.
the razzor man
Lonesome Cowboy
Thanks Razor,
My Dad is the expert so I am gonna buy him a pizza to do mine. My screen always says AUX so as long as it's blue I'm good. appreciate the tips!
SPONSORED BY
#14 | |
![]() ![]() ![]() ![]() ![]() Drives: LB-Auto-PWR-ABS-Cruise-Springs Join Date: Aug 2006
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime Get YarAss in gear! RIP - Casey Tatum |
Low Level Outputs
Refer to page 223 of the EWD (Electrical Wiring Diagram) of the Repair manual. It does'nt look like there is a milivolt signal output of the stock deck which is what you are looking for. You would need a schematic of the PC Board of the stock deck and hard wire a line in at the appropriate junction point, which I would'nt recommend doing anyway.
the razzor man
#16 | |
I drive a yarrrris
#17 | |
the razzor man
![]() ![]() ![]() Drives: Yaris Hatchback Join Date: Apr 2007
so i just joned yarisworld, why? cause this site is freakin awesome, i have a 3 door yaris hatchback silver colored, and i only have had it for 1 month. what i want to ask is if ya can help me en chaging the lights of my whole inside to blue, i just think silver looks nice with blue lights. heres are the questions, i hope ya can help me out:
How can i change my speedometer lights from green to blue? My stereo lights to blue? My dome lights to blue? My control for the air conditioner to blue? License plate ligth to blue? and whatever light i missed to blue? i also what to smoke my front lights and maybe the tailights and i have some other questions, i hope im not posting in the wrong place, if i am, I am very sorry!!
| Install sedan integrated stereo in hatchback? | atebit | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 05-22-2007 05:25 PM |
| LED Count for 2007 hatchback CD/mp3 Player | razzorjet2 | DIY / Maintenance / Service | 2 | 04-05-2007 12:32 PM |
| Integrated Cd Player | HorrorCosmic | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-20-2007 06:53 AM |
| toyota vip rs3200 alarm system and key with integrated remote | manborn | In Car Entertainment + Electronics (audio / video / alarm) | 0 | 10-16-2006 06:02 PM |
| blinking LED light | kaymm | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 09-14-2006 10:05 PM |
