![]() Drives: Toyota Yaris 1.3SR 2001 Join Date: Sep 2014
Noise from Belt Area
Hello,
New so go easy, have a 2001 Toyota Yaris 1.3SR with what has been a noise for about a year (I'm a novice so thought it was just an aux belt) so we changed that belt and the noise hasn't gone away. An ex Toyota Mechanic suggested it was a bearing on the timing setup. I'm unsure as to whether this is true, as I can't see any videos or forum posts whining about this, the guy suggested it was a common fault. It's a whirring noise from some parts, If I posted a video would someone be able to give us a push in the right direction? Also has anyone heard of this before, from what I'm reading I'm being pushed towards bearing's on the pulleys?
Definitely post a video. On our US 1.5L Yaris, that kind of noise is typically due to a bad water pump.
#3 | |
What would I need to replace, or is it as simple as just the water pump if that appears to the problem? Seems quite cheap the part over here, it's around £30 would it require a ramp to do due to space? |
Procedure for a NA spec 1.5 http://www.yarisworld.com/forums/showthread.php?t=12727
Probably very much the same, or at least give you a general idea about what would be involved for your 1.3
| Belt noise after MI pulley? | Captain Slow | Performance Modifications | 33 | 07-31-2013 03:11 PM |
| Squealing Belt Noise | Toyota3000 | DIY / Maintenance / Service | 3 | 07-23-2013 04:06 PM |
| grinding noise from engine area, bearing maybe?? | trx680 | General Yaris / Vitz Discussion | 10 | 01-31-2013 12:22 AM |
| 2005 Yaris noise in engine area | dwoodpub | General Yaris / Vitz Discussion | 5 | 12-27-2010 07:41 PM |
| Belt noise? | Cutie Pie #2 | DIY / Maintenance / Service | 20 | 05-22-2009 02:51 PM |
