![]() ![]() Drives: 2008 toyota yaris hatchback Join Date: Dec 2012
Megasquirt ECU
Well tomorrow is the big Day. The megasquirt goes into the car for a ful stand alone ECU I feel like a giddy little school girl. I will post pics and results later next week while on vacation.
Nice. I assume you are converting to a drive by cable throttle body?
![]() ![]() ![]() Drives: Vitz RS Join Date: Feb 2009
Good luck with the install and tune. Keep us updated. I am currently having a difficult time with an AEM EMS-4 standalone.
i am and i will
![]() Drives: 2004 Echo 3rd Join Date: Jul 2015
Subscribed:) Good luck with install!
I've found that a throttle controller opens up the DBW throttle mighty quick... I'm not sure it would make a huge difference in the end over DBC, but of course there's only one way to find out... I've been thinking about doing this mod if I ever get my nitrous tank installed...
heres a question i have been throwing through my head.
Would a toyota corolla air intakemanifold and throttle body fit on the the yaris motor? |
#8 | |
2ZR swap. DO IT! Ask how!
Sent from my XT1031 using Tapatalk |
![]() ![]() ![]() Drives: 2009 Yaris Join Date: Jan 2014
Yes they can be fitted the aluminum version from older Corrola or Celica's. Spacing is excellent, bolts holes no. You need to have a flange machined, also a 4 bolt to 3 bolt TB adapter or cut the plenum and weld the new mounting plate. TB from a 1ZZ fits, do a search and you'll find all the info you need. Also Tooter had intakes modified but I don't think he does anymore. Maybe he'll chime in.
| Need Help with 2NZ ECU pinout | Aleil | DIY / Maintenance / Service | 3 | 12-28-2020 09:40 AM |
| I finally cracked the Odometer and SRS ECU code | CTScott | DIY / Maintenance / Service | 22 | 10-27-2016 01:50 AM |
| standalone and stock ecu | Radou | Performance Modifications | 0 | 06-16-2013 04:47 PM |
| MegaSquirt ecu | monchyxb | Forced Induction Forum | 14 | 03-31-2012 10:59 AM |
| Yaris ECU broken??!!!!!! | phb10186 | General Yaris / Vitz Discussion | 30 | 05-26-2010 09:56 AM |
