Old 02-11-2017, 10:20 AM   #1
rabbito
rabbito's Avatar
1zz TB question
i failed to install the 1zz throttle body due to...
1. fu*ken coolant hose being too short and couldnt reach the throttle body..😣
2. i wanted to use stock intake box with plastic hose but couldnt fit over 60mm..lol.. 😥
is anybody using stock airbox for 1zz 60mm tb? i custom ordered stainless steel intake 2.5" from a shop to try to make it possible...(picture below..sorry for sucky drawing..) 😆
if not..how is your car running on normal intake + 1zz throttle body??
im trying to use stock box because i hate losing low end torque..i had hks intake which lost low end and gained hi end
Sent from my SM-N920C using Tapatalk
Cosmetic: Toyota red emblem
1zz Throttle Body Question rabbito Performance Modifications 5 12-09-2015 12:09 AM
1zz or 2zz throttle body swap BoostedTRD Performance Modifications 1 11-25-2014 11:05 AM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 09:52 PM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 04:59 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 08:15 PM
