![]() Drives: Echo RS Join Date: Aug 2006
Check engine code P0138
My check engine light on, error code P0138.
check engine light was off this morning, is it still ok to drive? If need to replace it, is it hard? My car is 2005 Echo Thanks. |
P0138 is an error for the second O2 sensor (the one that is after the catalytic converter). It is not too bad to replace, as long as you can get under the car. The other end plugs into a connector under the center console near the gas pedal.
Angry Bird
^+1
Thanks, CTScott, do I need to remove the passenger seat to remove the second O2 sensor?
No. It comes through the floor right under the center of the dash. You will probably have to pull the AC controls to get to it.
#6 | |
My check engine light was off this two day, do I still need to change the rear O2 sensor? also, my car is only 77,000km. is it too early for the sensor to be failed? Thanks |
You could wait and see if the code comes back. 77k Km does seem early, but there are a few things, including bad fuel that could foul one prematurely.
#8 | |
The code came back again, so finally replaced the second O2 sensor. Just discover the left cv boot cracked, need to replace too.. ~~ |
![]() Drives: Yaris 2007 Join Date: Oct 2013
Going to bump this one old thread and ask: Any harm in driving the car with P0138 for a longer period? My car seem to work fine and MPG is average. Can I wait it out or should I not?
Thanks! |
No real harm in doing so. The purpose of the sensor is to show that the cat is still in place and that its catalyst is still good.
| The Official "Bamboo the Yarisworld Traveler" Thread (v4, part 2) | Darb | Off-topic / Other Cars / Everything else Discussions | 86 | 10-18-2017 09:03 AM |
| Check Engine Light P0455, P0441, P0456 | RedStickHam | DIY / Maintenance / Service | 8 | 12-01-2013 01:41 PM |
| ODB2 Check engine code reader | Arkhangel | Performance Modifications | 11 | 02-25-2009 05:13 AM |
| Anybody know the code? | Driver | New YARIS Purchase Forum | 5 | 08-20-2006 07:56 PM |
