Old 11-25-2006, 01:40 AM   #1
W.A.S.P
I love my Yaris!
W.A.S.P's Avatar
Drives: White Yaris Liftback 2 Dr. AT
Liftback Rear speaker installation tutorial (Pics)
Well, I decided to upgrade my rear speakers since I got a couple of Sony for the front and needed to match the power but add a little more bass.
First, look at the tabs' diagram so you will know what you will encounter when pulling the panel away from the car's body. You don' need to remove the rear seat or the weatherproof trim to pull the panel apart, just use patience, common sense and have a beer next to you and the process will be painless.
Keep this in mind, in the middle of the panel there is a pressure tab blue in color that is not pictured in the diagram; be careful not to break it. Place one hand on the inside of the panel to feel the tabs that you can't see; don't just yank the panel off. Once the panel is off you will see that there is a lot of room for even a sub woofer in that space, you can use several sizes of speakers on the stock location, as long as you have the appropriate brackets, you might have to drill new holes for some applications. I used the brackets provided with my Alpine speakers and had to drill three new holes for the new brackets. Since the stock speakers have a special connector you might have to cut the wires. No biggie; once you see what the stock speakers are made of you will know you'll not use them again!
Do this process in reverse to reinstall the panel and there you go! Enjoy the new sound!!!!
W.A.S.P is offline   Reply With Quote
Old 11-25-2006, 02:29 AM   #2
hasher22
Look mum no stars!!
hasher22's Avatar
Drives: Toyota Yaris 06
Very nice
Question : do u get rattling sounds from the plastic panel when the bass is up?....
Old 11-25-2006, 02:32 AM   #3
W.A.S.P
I love my Yaris!
W.A.S.P's Avatar
Originally Posted by hasher22
Very nice
Hasher. There is no vibration whatsoever on the panel with this set up. I ran a few tests with several Cds from Classic to Heavy metal and I'm very pleased with the sound.
Old 11-25-2006, 02:37 AM   #4
hasher22
Look mum no stars!!
hasher22's Avatar
I think i have to dynamat my plastic panels........
My speakers are fully secure with no loose gaps or loose for the matter. Damn plastic panel rattles for some odd reason.
Thanks!
Old 11-25-2006, 04:12 AM   #5
twixt
Drives: 07 LB,04&06 ninja 636
Send a message via AIM to twixt
mine rattle hardcore. but after looking at different dynamat types i find b-quiet to be a good cheaper substitute. im just too lazy to install it.
twixt is offline   Reply With Quote
Old 11-25-2006, 04:51 AM   #6
hasher22
Look mum no stars!!
hasher22's Avatar
lol did u buy the one that you have to apply glue to the sound deadening material?.....
I have this silver ahesive version......best sound deadening material i ever baught!....
Old 11-25-2006, 11:21 PM   #7
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
very nice thanks for the work
will work for parts
vodkalush is offline   Reply With Quote
Old 03-09-2007, 08:44 PM   #8
mygrnthmb
swappin cogs
Drives: 07 Yaris l/b 5spd
Send a message via Yahoo to mygrnthmb
excellent post. thanks
mygrnthmb is offline   Reply With Quote
Old 03-17-2007, 07:04 PM   #9
HorrorCosmic
Speed+Metal=Life
HorrorCosmic's Avatar
Drives: 07 Red Yaris Sedan
HAH those are the same exact speakers i'm putting in my front doors today.
HorrorCosmic is offline   Reply With Quote
Old 05-17-2007, 10:40 AM   #10
FreightShaker
Drives: 07 Yaris CE, Bayou Blue
I have searched everywhere but no answer to be found.
On a Base Model CE 3dr...did Toyota run the wires towards the rear speakers even though there are only front speakers, or will I have to run some wires to install rear speakers ??
Nice Post by the way, it'll come in handy when I decide to do my install. Thanx
FreightShaker is offline   Reply With Quote
Old 05-17-2007, 08:11 PM   #11
uncleyaris
wire are there.
Old 09-23-2009, 09:36 AM   #12
XSVNOYZ
XSVNOYZ's Avatar
Drives: 2008 Yaris hatchback silver
Thanks for the info on how to get at those rear speakers. after 1.5 years of constant.... I mean CONSTANT, head unit (ONLY) power ( 450x4 only running the 12" and the alpine components up front). the stock speakers my boys at Pacific Stereo (Woodland Hills, CA) left alone in the rear finally started chirping horribly!!! I NEED 2 disconnect them B4 I even leave my friends house..... THANK YOU SO MUCH!!!! If it's too loud...... UR 2 OLD!!!
XSVNOYZ is offline   Reply With Quote
Old 01-15-2011, 05:21 PM   #13
limey163
limey163's Avatar
Drives: 2010 Black 2D Hatch Yaris
Thanks alot W.A.S.P. Just installed some speakers thats been sitting in my room for some time thanks to your guide. All i need now is a rivet gun and maybe a drill to mount them.
limey163 is offline   Reply With Quote
Old 01-15-2011, 06:55 PM   #14
auxmike
auxmike's Avatar
You can use sheet metal screws or even nuts and bolts too.
I bought Pioneer 4 ways from Crutchfield and they came with an adapter patch cable eliminating the need to cut wires.
Old 09-14-2011, 01:41 PM   #15
TickleTimeTim
Free Mustache Rides
TickleTimeTim's Avatar
Drives: 2007 Yaris HB
This should help. Thanks.
Club SHIFT
Old 09-14-2011, 01:44 PM   #16
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
^ Did you mean front speakers?
Old 09-14-2011, 01:47 PM   #17
TickleTimeTim
Free Mustache Rides
What do you guys know about running these speakers to an amp?
Club SHIFT
Old 09-15-2011, 09:33 PM   #18
andruboz
boohachimono
Drives: 07 hb
Send a message via AIM to andruboz
what i recall from my dynamat installation...
all the clips on my panels were easy except the blue one at the bottom. i mangled the one on the drivers side and completely broke the one on the passenger side.
andruboz is offline   Reply With Quote
How to remove rear speaker panel on a Liftback? W.A.S.P In Car Entertainment + Electronics (audio / video / alarm) 7 11-25-2006 01:45 AM
-- Liftback Rear Speaker Removal? -- rarmogan In Car Entertainment + Electronics (audio / video / alarm) 2 09-25-2006 03:48 PM
