Old 04-12-2017, 02:49 AM   #1
Thaiyaris
Drives: Yaris 1.5
Ac problems
Hi guys,
So had my ac clutch changed about 6 months ago. It's now stopped working again. Different this time though.
Turn on the ac, revs go up theres current at the ac wire to the compressor.
Pull the fuse and the revs drop.
But the ac clutch doesnt move not even a millimetre.
Seems to me that the ac ecu is stopping the clutch from engaging .
So where should I start with diagnosing the problem. Please don't say go to Toyota the techinchians here in L. O. S are about as useful as a wet rag., a blunt knife or a a wife who no one longer puts out, cooks or cleans. 😂
Thanks for any help you can give.
Thaiyaris is offline   Reply With Quote
Old 04-12-2017, 07:15 PM   #2
esse10
Drives: 2009 yaris 2 door
clutch
so you put a Dc volt meter at the clutch's coil and there is power there? but the clutch does not move to engage ? if the answer is yes then the fix is easy, your clutch is bad because it's just a coil gone bad. Turn everything off and physically jumper the clutch coil with 12vdc and see if it moves or not.
If the computer is not sending 12vdc to the clutch coil then it could be other issues ,..like under pressure or over Freon pressure. Do you know how to hookup a set of manifold gauges to the low/high sides of the A/C system?
esse10 is offline   Reply With Quote
Old 04-12-2017, 07:29 PM   #3
tmontague
tmontague's Avatar
Also check your charge, if it below a certain threshold your clutch won't be activated
Car wash causing electronic problems? lamadoo DIY / Maintenance / Service 3 12-24-2013 11:47 AM
follow up on 2010 yaris problems + more problems heavenswaitin DIY / Maintenance / Service 18 09-03-2013 04:47 PM
WEIRD ISSUE WITH YARIS ! many problems at 1 time ! annn DIY / Maintenance / Service 7 06-27-2013 07:02 AM
A few problems drunkwithwords General Yaris / Vitz Discussion 1 04-01-2010 12:13 PM
