Old 06-26-2013, 03:32 PM   #1
annn
ヤリスワールド
annn's Avatar
Drives: 2008 HB
Unhappy WEIRD ISSUE WITH YARIS ! many problems at 1 time !
2008 yaris ,automatic.,60,000
All this came on very fast ! car was running great then started odd sluggish shifting and then downhill fast on multi problems ! very odd !
Threw a po335 code so changed the crank sensor ,no change in problem & code returned.
Problems... brake applied car dies, put in gear car dies,dash lights blink too- sometimes, power steering assist is cutting off & on too, very odd shifting issues,clunkling etc.
any clue ?
annn is offline   Reply With Quote
Old 06-26-2013, 04:30 PM   #2
annn
ヤリスワールド
annn's Avatar
Drives: 2008 HB
ok to add to the weirdness ! I was thinking short of some type due to the dash lights turning off when brake applied & dash going totally out when heater turned up and killing car sometimes.
So I started lookinh over wires etc and removeing anything I had installed ,well that led to the ultraguage so I unplugged it & it killed car right away ??? then it gets really weird a few lights on dash stay on like oil light when cars off & keys out of ignition ??? Then the heater fan starts runnning ?? so I think well one more reset by removeing negative batt cable wont hurt.
So i un hook cable and when re hooking it up a larger than normal spark happens ( i know this happens sometimes & normally thier is a tiny spark on resttachment) well i go back restart car and it semms fine WTF ? RE PLUG IN ultra guage and it all working again ??
I dont get it ?
Old 06-26-2013, 04:46 PM   #3
The large spark on reconnecting the battery indicates that something is drawing significant current. The dash lights staying on with the ignition off sounds like a relay's contacts are staying closed when they should not be.
Do you per chance have an aftermarket keyless entry, remote starter, or alarm?
Old 06-26-2013, 04:56 PM   #4
annn
ヤリスワールド
annn's Avatar
Drives: 2008 HB
No none of the above but its now trying to start when i attach the negative cable back up ?? no key in ignition ??
no recent mods of any type, has a amp ,fogs ,ultra guage thats about it for items i installed thats electrical ?
Strange that it went from shifting odd,to the po335 code , to major electric issues all in 2 days .man car has been great till yesterday ?
Old 06-26-2013, 06:55 PM   #5
That is quite odd. I would pop out the ST relay and give it a couple of solid taps to see if its contacts were stuck. If it still does it after that, I would check the ignition switch connector for damaged wires and after that I would pop the cover on the ECM to see if any moisture damage has occurred.
Old 06-26-2013, 07:54 PM   #6
annn
ヤリスワールド
annn's Avatar
Drives: 2008 HB
Your the man on this stuff , I am going through it all
Per your guide . Thank you !
Old 06-27-2013, 01:09 AM   #7
annn
ヤリスワールド
annn's Avatar
Drives: 2008 HB
Your a god ! The st relay was causing the starter issue & maybe more. Should I replace relay ? Pal says once their bad it can happen again ? Also do you think that the st being stuck could have caused so much electrical chaos ? Car seems to be fine now , I think the crank sensor caused the initial issues with shifting and some how in all this the st relay got stuck & really caused problems . Thanks for all the help ,it was truly a correct direction !!
Old 06-27-2013, 07:02 AM   #8
Definitely replace it, as once the contacts stick they will do so again. It is possible that it was the root of all evil.
2009 Yaris starting issue -need help cudchew DIY / Maintenance / Service 15 12-16-2011 03:24 AM
2007 Yaris Door Lock Issue bhola General Yaris / Vitz Discussion 7 10-05-2010 01:01 AM
