Old 03-05-2019, 11:18 AM   #1
mik23
Drives: yaris 2005
Yaris MAF cleaner
Hi All
Can anyone help what cleaner can be used to clean the MAF.
Is carbureter cleaner is suitable ?
Sent from my SM-G930F using Tapatalk
mik23 is offline   Reply With Quote
Old 03-05-2019, 01:07 PM   #2
2bz
Drives: 2008 Yaris 3DR Hatch MT
Nope. Use MAF specific cleaner or electrical contact cleaner. Brake/Carb cleaners can leave behind a film on the sensor which will cause codes.
https://www.crcindustries.com/produc...-oz-05110.html
https://www.crcindustries.com/produc...-oz-03070.html
2bz is offline   Reply With Quote
Old 03-05-2019, 03:59 PM   #3
mik23
Drives: yaris 2005
Thanks that's weird i have seen on youtube people recommending to use carb
Can we use below
https://www.halfords.com/motoring/en...-cleaner-500ml
Old 03-05-2019, 04:20 PM   #4
komichal
I would use only a cleaner that is specifically marked as "for MAFs". I do not want to take any risk. Therefore you should not user the suggested cleaner.
Old 03-05-2019, 05:38 PM   #5
2bz
Can we use below
Yes, electrical contact cleaner is fine.
Old 03-06-2019, 03:12 AM   #6
B.B._07
Drives: 07 5dr
While it's "not recommended" many mechanics have been using brake cleaner and carb cleaner for years with no problems. I've used brake cleaner on more than a couple vehicles with no issues. All the aerosol cleaners are very similar to each other with most being a mix of highly volatile solvents and a propellant.
Old 03-06-2019, 08:40 AM   #7
dogsridewith
Drives: 2007 2-door hatchback
Which brake cleaner are they using? (High VOC or low VOC)
Old 03-06-2019, 01:20 PM   #8
yarisbug
yarisbug's Avatar
Drives: 2010 1.4 d4d
I've used brake cleaner for years to clean MAF. The VOC is irrelevant, just use what you got and make sure it doesn't leave a residue.
yarisbug is offline   Reply With Quote
Old 03-06-2019, 03:59 PM   #9
dogsridewith
Doesn't the MAF sensor have to survive everything gaseous coming up from the crankcase and through under the valve cover?
Old 03-07-2019, 07:48 AM   #10
Mask Rider Blac
Drives: 2013 Yaris Sedan MT
We use the CRC MAF Sensor Cleaner. Although you can also use other brands of MAF Sensor cleaners, as well as, electrical contact cleaners.
Sent from my SM-G7102 using Tapatalk
Mask Rider Blac is offline   Reply With Quote
Old 03-07-2019, 08:55 AM   #11
2bz
No. The MAF is before the intersection where the crank case gases enter..
Old 03-07-2019, 08:57 AM   #12
2bz
Buy a cheap OBDII scanner to clear the codes that you will get from "just use what ya got".
Old 03-07-2019, 09:46 AM   #13
komichal
I still do not understand why someone would spray the brake cleaner on MAF sensor.
200ml MAF cleaner spray (by Liqui Moly) costs some 6 USD here, over the years I used it to clean 5 MAFs and one throttle body and there is still something remaining for further usage.
Which means it costs less than 1 USD to clean the MAF properly and risk-free.
Old 03-07-2019, 09:47 AM   #14
dogsridewith
Then what gets it dirty?
Old 03-07-2019, 12:47 PM   #15
There are still fine particulates that get through an air filter. This very slowly over time accumulates on the fine wire in the maf.
Old 03-07-2019, 05:27 PM   #16
2bz
Also, depending upon the MAF design one wire is heated, like a toaster element and can burn said particulates, which stick to it. This is why you don't want to clean the MAF with anything that leaves a residue. It will burn on too and give incorrect data.
Old 03-07-2019, 10:07 PM   #17
yarisbug
yarisbug's Avatar
To clarify, I meant use whatever brake cleaner you have as long as it doesn't leave a residue. It will not trigger codes.
Old 03-08-2019, 12:42 AM   #18
komichal
The residues are often not visible and can be even more problematic after heating up. You can trust the statement on the can that says "leaves no residue" but bear in mind that these statements are always related to the primary usage of the spray which for brake cleaner means "leaves no residue that would have negative impact on brakes".
DIY Cruise Control FAQ (2006-2010 Yaris) CTScott DIY / Maintenance / Service 468 11-19-2024 04:45 PM
2018 Yaris SE 5MT - T-Sport w/Valvematic! atomic_hoji Performance Modifications 130 02-23-2019 12:56 PM
06-10 Yaris Sedan cold air intake $40 kylevh21 Items for Sale by private party 2 04-01-2012 03:14 PM
