Old 03-04-2009, 09:52 AM   #1
hatchbackkid82
Drives: .
3rd Gear grind
I just started to develop a 3rd gear grind. I don't know if anyone else has experienced this. Shifting from 2nd to 3rd, it will never be hard to get into gear, but on occasion there is a slight grind. Has anyone else experienced this? The other thing is does anyone know if having an intake on there will void the entire warranty?
Old 03-04-2009, 10:10 AM   #2
hatchbackkid82
Drives: .
I don't rough shift. Always make sure the clutch is all the way down when shift. It's driving me nuts. Even if i shift slow at a certain speed it will grind. The grinding sound is faint but still audible, but i can feel it through the shifter. It's like something is spinning in there
Old 10-12-2010, 09:22 AM   #3
firemachine69
School'er of hard knocks
Drives: Silver Yaris 4dr. HB
Your synchronizer is likely pooched.
Go make an appointment with Toyota, I hope you have drivetrain warranty left!
firemachine69 is offline   Reply With Quote
Old 11-01-2010, 11:19 PM   #4
az_saguaro
What to Mod Next?
Drives: 2008 3Dr HB, Bayou Blue
Definitely know the synchro was gone, they also found 4th gear teeth chipped and some fried bearings. Took a lot of "discussion" on the phone, but did get it the VSA (extended warranty) to cover repairs. Whew!
az_saguaro is offline   Reply With Quote
Old 11-02-2010, 09:41 AM   #5
hatchbackkid82
Drives: .
Got it taken care of, ended up with a new transmission
Old 03-16-2012, 07:40 PM   #6
2o6
Drives: 2007 Liftback
Don't mean to be a super bump, but I have the same issue with 3rd.....
2o6 is offline   Reply With Quote
Old 04-24-2012, 04:25 PM   #7
yarisman1974
Drives: 2007 Toyota Yaris
My 2007 Toyota Yaris is doing the same thing
Well looks like evryone on here is experiencing the same thing as me, downshift from 3rd to 2nd gear, and unless I am under 40KM/h the gear will grind, meaning to me it's a synchro. Only problem is at 70K I had this problem last year and under powertrain warranty the synchro was replaced. Fast forward to this year and 13 months after the repair the very same issue is happening, and after speaking with the dealer and Toyota Canada because my PT warranty has expired, I do still have ECP warranty....however I got 2 calls today from Toyota, one saying that they would do a ONE time shot and waive the fee to have the dealer rip apart the transmisson, but an hour ago Toyota called back and NOW they won't honour that whatsoever and will only waive the fee if they cam prove that I didn't cause the issue as they claim that a synchro is wear and tear...I'm not happy at all with how Toyota is handling this, and may consider taking this up a notch. Any thoughts on this? I would appreciate that. Thanks.
yarisman1974 is offline   Reply With Quote
Old 03-04-2009, 10:13 AM   #8
hatchbackkid82
Drives: .
Well looks like i'm back under the hood tonight. Just put my intake on Sunday...this blows
Old 03-04-2009, 10:22 AM   #9
hatchbackkid82
Drives: .
I hope your right PK. I'm dreading having to shell out money. I'm out of the bumper to bumper warranty. Just have the powertrain warranty, i know they will tryto figure out a way to suck money out of me
Old 03-04-2009, 11:51 AM   #10
MUSKOKA800
MUSKOKA800's Avatar
Powertrain warranty should cover transmission problems.
Old 03-04-2009, 12:00 PM   #11
hatchbackkid82
Drives: .
Yeah just don't want to give them a leg to stand on. They see the intake and then some how they blame the tranny problem on that. you know they come up with any old thing to make money
Old 03-04-2009, 10:33 AM   #12
at3GG
at3GG's Avatar
Drives: 07 metmet LB
mine does the same downshifting from 2 to 3 sometimes, even with the clutch fully depressed and shifting sloowly, but only if i dont let the rpm drop. Fait but still there. Also, an intake will NOT void your entire warranty. If they KNOW that you installed an intake, it will void the stock airbox and intake system portion of the watrranty and nothing. This is straight from the mouth of my Toyota Dealer. Good Luck!
F5 CAI, MR axleback, MR Header, NST SSK.
Full Exhaust wrap, AT3 Custom SSK
Konig Heliums 15x6.5 Black
Tanabe Df210's
at3GG is offline   Reply With Quote
Old 03-04-2009, 10:45 AM   #13
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
ahh the old weak synchro problem..
what gear oil are you using?
Originally Posted by xnamerxx
you nailed it sir.
Old 03-04-2009, 10:49 AM   #14
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
I'd check your clutch hydraulics. If the slave has a slight leak or the fluid is old or you've somehow gotten a little air in the system, the clutch may not be releasing properly. What you describe is one of the first symptoms.
Old 03-04-2009, 11:00 AM   #15
hatchbackkid82
Drives: .
75w-90 Mobil 1 synthetic If i remember right. It's a grind for sure, doesn't happen all the time. It definitely happens at high rpm all the time. Shift from 1st to 2nd is fine, sfifting 2nd to 3rd, pressing clutch all the way still grinds. I can't shift from 2nd to 3rd in one smooth motion at high rpm without a grind. Actually have to wait for a second or so.
Old 03-04-2009, 11:01 AM   #16
Tamago
Tamago's Avatar
Drives: ZZW30
there's your problem
get rid of that mobil1
that's a synchro destroyer (ask me how i know)
you nailed it sir.
Old 02-15-2019, 06:07 PM   #17
cylaptor
Drives: Yaris 1.3 VVTi R&B
omg, I see that now. I have the same problem after putting in a Mobil1 75W-90 gear oil. It started to grinding and very difficult shifting.
cylaptor is offline   Reply With Quote
Old 03-04-2009, 11:06 AM   #18
hatchbackkid82
Drives: .
Ummmm....... lol.... so how do you know? You screwed your tranny up?
Yaris 2007- How to Restart Multimode gear? ronen DIY / Maintenance / Service 1 02-21-2009 06:09 PM
Auto 'extra' gear? drecian General Yaris / Vitz Discussion 2 08-25-2007 09:01 AM
High RPM's in 3rd. Need some opinions falkor_99 General Yaris / Vitz Discussion 3 05-16-2007 09:23 PM
2nd to 3rd gear shift (manual tranny) tekmoe General Yaris / Vitz Discussion 13 12-11-2006 07:27 PM
clicking into first gear tekmoe General Yaris / Vitz Discussion 9 11-01-2006 03:44 AM
