Old 09-27-2013, 12:20 PM   #1
Chuckie
Drives: 2011 Yaris Hatchback
Spoon Rigid Collars NCP91
Check this video out. Spoon makes collars for Vitz/Yaris now. I just installed RZCrew Garage Collars on my Yaris. They make a big differrnce. Theres also another European company selling rigid collars online, (rigidcollars.com) for our cars.
http://youtu.be/zWyUD6UXfog
Chuckie is offline   Reply With Quote
Old 09-27-2013, 01:25 PM   #2
catliektheif
catliektheif's Avatar
Drives: 2010 5 Door
wow thats awesome! interesting video
lol okay
Old 09-27-2013, 01:54 PM   #3
Jason@SportsCar
Does your car still have all the stock bushings? Hard to imagine any improvement being felt, or even measured, when you have massive rubber control arm and shock bushings in place - the upper shock mount alone has about a 1/2" of play in it. There is so much flex in the OE suspension, the subframe would be the last thing I would worry about. I also don't like the idea of lifting the body by placing a spacer between it and the subframe.
Interesting in the video... When they compare the two cars the blur on the "after" cars wheels seems to make it look like it was going faster when it hit the block, making the suspension instead of the chassis take the load - it would be easy to synch the videos in post production. Also the tire on the after car seem to deflect a lot more, another indicator of increased speed or lowered tire pressure.
Old 09-27-2013, 02:10 PM   #4
Why are there two threads about this?
Old 09-27-2013, 03:17 PM   #5
Chuckie
Sorry bout that. This is more about the Spoon one, so thought it was ok to open another thread.
Old 09-27-2013, 03:35 PM   #6
Chuckie
Yes im stock bushings all around still. My car is fairly new, 5k miles on it. I put the RZRCrew ones two weeks ago. Very obvious and noticeable difference even in my fairly new car. Tighter more solid feel immediately noticeable. Our roads here in the Philippines are sub par, alot of potholes and uneven surface conditions, worse than New Yor City, haha. I could really feel the difference when hitting these surfaces. I used to hear another sound other than just the rubber of the tires on the surfaces. Now, mostly all I hear is the rubber. I notice my car used to rock and wobble a bit just from these surfaces and jolts of acceleration. It doesnt do that anymore. Better handling and steering response. Prior to installation, My car was fully strutted on UR bars minus mid bar and rear upper. H&R springs on stock shocks.
Old 09-27-2013, 03:47 PM   #7
Chuckie
It definetely feels like a more expensive car. My father has an IS 300. Collars bring it closer to that feel. In more expensive cars they dont take as many manufacturing shorcuts. Oh, and ride height is unchanged.
Old 09-27-2013, 04:29 PM   #8
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Interesting in the video [...]. Also the tire on the after car seem to deflect a lot more, another indicator of increased speed or lowered tire pressure.
I did notice that the tire in the "after" shot looked under-inflated. I guess I'm not alone on this...
Old 09-27-2013, 09:52 PM   #9
Viperoni
Drives: 2005 Toyota Echo
QFT.
Echo's don't have this collar, but Jason's right on point - the factory suspension has way more flex than any positive effect this would ever have...
2006 Saturn Ion Redline
2005 Toyota Echo RS 4dr hatch - Cyl #3 bad - sold
2000 Toyota Echo 2dr coupe - The track car - rusty & scrapped
Viperoni is offline   Reply With Quote
Old 09-27-2013, 11:06 PM   #10
YarisSedan
Drives: 08 Yaris Sedan
Are you able to get these garm i went to the website they dont have shipping to us
Old 09-28-2013, 02:03 AM   #11
Chuckie
Originally Posted by Viperoni View Post
QFT.
True, but your'e dealing with two fairly independent systems. Like stated in the video, on race cars, these areas where the bolts are that connect the body to the subframe, these parts are actually welded. Its not really the suspension its working on but rather the connection of the engine, transmission and suspension to the subframe which is a rather lose and you can say primative connection on alot of non luxury or more expensive sports cars. The effect of play in the stock suspension is independent of of the effect of rigid collars since they are separate areas in a cars makeup. Thats like saying if you add a front upper strut bar, there would be no positive effect unless a rear strut bar were added as well.
Old 09-28-2013, 02:16 AM   #12
Chuckie
Note: I have the UR front lower 4 point stress bar. Apparently, these are four of the bolts that connect the body to the subframe. The collars go in first and strut bar slaps on after.
Old 09-28-2013, 04:01 AM   #13
Chuckie
Hope youre able to hook up with a set. Just FYI, this site in Europe is selling the rear collars online. Price is in Brittish pounds. Although there are six more that go in the front of the car. http://www.rigidcollar.com/index.php...cp91-rear.html
Also check RZRCrewgarage.com in Singapore. They make em too for many makes and models. Allthough they dont look as high tech and great as the Spoon.
Old 09-28-2013, 08:42 AM   #14
Mittelklasse
Problem, officer?
Mittelklasse's Avatar
Drives: '06 Yaris 5DLB 1.5
I have had a similar setup installed in Thailand.
They are made of aluminum, machined to replicate Spoon's.
Copper grease was also applied to prevent seizure.
I can confirm it has a noticeable effect on my Yaris.
The car feels 'heavier' -- 'more European-ish'
Front caster angles were also increased, due to change in subframe position.
I'll say it's pretty best bang for the buck mod.
I paid for just approx. US$80 here. (They have service life of 3 years, however.)
Mittelklasse is offline   Reply With Quote
Old 09-29-2013, 01:26 PM   #15
Sure, or we can make them.
Old 09-30-2013, 12:54 AM   #16
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
That play is how caster is corrected during an alignment, as the top of the strut is fixed in place and has no adjustment.
Old 09-30-2013, 06:16 AM   #17
Chuckie
This is how the rear collars look.
Old 09-30-2013, 06:24 AM   #18
Chuckie
I can confirm it has a noticeable effect on our Yaris.
I felt my car heavier too right after install. Its deceiving because they weigh close to nothing. ** The Spoon ones supposedly last forever.
FS: Full NCP91 KavinT Manseth Kit (Front Bumper has Damage) Treyz Items for Sale by private party 22 04-08-2014 07:17 PM
RZCrew Garage Rigid Collars Chuckie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 35 02-13-2014 01:34 AM
SilkRoad NCP91 Coilovers In-Stock! Penguin Garage Penguin Garage 28 07-12-2009 06:48 PM
