High beam indicator stopped working
I noticed the other day I was driving with my high beams on, turns out the blue indicator in the dash isn't lighting up anymore. Is this simple enough to replace? What part would I need to buy?
The garage I take my car into replaced my headlight bulbs with LEDs a few months back. I had a blown bulb and they asked if I'd like to swap them out for LED, so I figured why not. I'm not sure if this would contribute to it. I'm about 95% sure the high beam indicator was working since. |
Gen 3 > Gen 2
Drives: NCP131, F-150 Join Date: Jul 2019
As far as I know all of the indicator lights on the cluster are LED. I doubt the LED blew but you can pull the cluster out and check the circuit board on the back of it.
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2013 Rav4 LE AWD Autotragic - Wife's
![]() ![]() Drives: 07 AT & 08 MT Yaris HB 3dr Join Date: Nov 2021
Did you ever figure this out? I replaced my headlights with LED's as well and I'm experiencing the same problem.
Unfortunately no. I ultimately went back to the original non-LED bulbs. The LED lights had flicker in the DRL and were way too bright. Once I was back on the old bulbs the indicator worked again.
#5 | |
There are various ways to do this but this will work as a plug and play solution: https://www.superbrightleds.com/moto...-load-resistor |
#6 | |
Huh, that looks simple enough. I wouldn't go back to LEDs - the housing isn't designed for them so at night I was blinding oncoming traffic. I'm waiting for my Corolla Hybrid to come in, so will be saying good bye to Yaris after almost 15 years :) |
you dont even need a real resistor just 2 tiny 12v to 3v resistors paired up run from the LOW to ground on the bulb socket...its how i fixed my HID's and its been since dec with no issues
to be clear im talking aboutthe same resistors you get in a bulk pack of LED's i belive what i used was a pair of 1ohm
#8 | |
| Yaris Verso High beam problem | henry33 | DIY / Maintenance / Service | 1 | 09-21-2016 10:31 PM |
| rear axle beam compatitbility? | AndreS123 | Third Gen Yaris General Discussion | 3 | 08-25-2016 05:23 PM |
| Front wipers high speed not working properly | WildChild | DIY / Maintenance / Service | 1 | 07-30-2016 02:00 PM |
| Dimmed high beam as DRL? | Ot_tO | Cosmetic Modifications (Exterior/Interior) | 5 | 08-21-2012 01:34 AM |
| DIY - HID Retrofit | Violin | DIY / Maintenance / Service | 57 | 06-11-2007 07:17 PM |
