I drive a yarrrris
Drives: 07 Sedan Polar White Join Date: Sep 2006
Disable your seat belt alarm (on/off switch)*
What for:
If you want to disable your seatbelt alarm. I tend to do alot of work on/in my car and I hate the alarm when I turn the car on. So I wanted away to temp disable the alarm. Tools Needed: - Wire strippers/wire cutters - Drill bit (1/4inch) - Drill - Elec. tape (or shrink wrap) - 10mm socket (for removing center console) You need to buy/have: - switch (on/off) ($1 - $15 depends on your taste, mine was $3) - 2.2k ohm resisters ( $0.99 radioshack) (thanks -*03Z33) How you do it: 1. I removed the center console (check the service manual) 2. On the center side of your seat there is a small rubber "hose" with the seat-belt wire 3. Cut away some of the rubber hose, and expose the wire's 4. Seperate the wire into "2" then strip a bit of each (you could prob remove the seat and then tap into the wire alot easier... but taking the seat out sounds like a bitch) 5. Use a piece of wire (about 7inches) and attach the wire's together 6. I put a 2.2k ohm resister "in-line" on one side of the wire 7. Hook up the wire to a switch (i used a push-pull on off switch) 8. Tape all your splices (I would recommend you to use heat shrink) 9. Test, TEst, Test 10. I chose a location on my center console that was accessable but hidden (under my e-brake handle) 11. Drill hole, put switch in hole/place 12 . Put everything back together 13. Enjoy your new found ability of control over that 12sec chime.... *
![]() Docotrs say all the drikning has mesesd up my seplilng and radieng will work for parts |
![]() Drives: Yaris sedan Join Date: Aug 2006
i read somewhere in the manual that the dealer can disable this.....
![]() ![]() ![]() Drives: 2k3 Cavalier & 2k2 Echo Join Date: Aug 2006
Is it necessary to put a switch or just cutting the seatbelt sensor wire may be enought to disable it forever? It is a very annoying feature of the new Toyota (my mom also have it on her new Matrix), so I don't think people will want to re-enable it further... hehehe.
2003 Chevy Cavalier Ecotec - His car! 2002 Toyota Echo Sedan - Her car... FOR SALE! |
#4 | |
I drive a yarrrris
and I didnt really want to disable it; just temp. when I'm driving down to the garbage "dump" (its on the other end of my townhouse "block") and what not.
HardlyDangerous
Drives: 09 Yaris LE, H/B, auto Join Date: Jul 2006
What is the point of the resistor?
because you are adding a length of wire?
The early bird gets the worm, but the second mouse gets the cheese. |
Mr. 155 and climbing
nice DIY...that is what I would be looking for as well....just a temp solution when I am detailing or have my laptop backpack on the passenger's seat....I would like to be able to still have it on because I prefer to wear my belt, but would forget all the time without the chime.
#7 | |
I drive a yarrrris
![]() ![]() ![]() ![]() Drives: 2007 Yaris manual dark silver Join Date: May 2006
what wire did you put the resistor on or will any wire work
7 Color Tach Fujita Intake Momo pedals Shift knob and boot. Full TRD SSK. Blitz exhaust Megan Lowering Springs (Next is DC Header) |
where do you buy heat shrink
did you sodder the switch
i'm just wondering... can't you just get a used seatbelt buckle latch from the junkshop and plug it in your setbelt buckle to stop the chime?
#12 | ||||
I drive a yarrrris
how did you make the hole for your switch (what tool?)
#14 |
I drive a yarrrris
a cordless drill and a wood/metal bit (I just used what i had)... the hole size depends on what button you use/get.
#15 |
The LittleBastard
Drives: 2007 Yaris Liftback Join Date: Sep 2006
I just went to five different dealers, and no one will disable the dam alarm. They don't care what it says in the manuel they just won't do it. Liability issues they tell me. Any other way other then adding this switch? I'd just like to get rid of the alarm completely. Maybe a certain wire being cut?
Yaris Mods: 20% Tints Ground wires 2007 Toyota Yaris Liftback - Current 2004 Honda S2000 - Sold 1986 Toyota Corolla SR5 - Sold DIY: Groundwire Kit |
#16 | |
I drive a yarrrris
#17 |
![]() ![]() Drives: 2007 Yaris Join Date: Jun 2006
So theres no simple way of disabling the sound alarm (ie not cutting wires)? This seems like a huge pain in the ass for something so simple.
#18 | |
The LittleBastard
| DIY - Sparco Race Seat Install | Idjiit | DIY / Maintenance / Service | 16 | 08-14-2017 09:15 PM |
| Back Seat Removal... | Idjiit | DIY / Maintenance / Service | 87 | 02-08-2015 12:07 PM |
| Seat belt reminder warning Beep | Jord | DIY / Maintenance / Service | 28 | 04-09-2009 08:37 AM |
