![]() Drives: Yaris 2006 Join Date: Jun 2007
questions about my yaris(vitz)
ok i imported my vitz from japan, and the owner's manual is in japanese. It's the vitz 2005 model (yaris 2006)
Now since the owner's manual is in japanese there 2 things i can't understand. 1. my yaris is an automatic. It's gear sequence goes like this. first reverse (R) then neutral (N) then drive (D). It's fine till here. but after that i don't understand. Towards the right of (D) is an (S). What is this S? What does it do? How do you operate it? Then after (S), if you move the stick down there's a (B). What's the (B)? What does it do? I tried driving in B, but the car went slowly and made a lot of noise. Is it for mountains? What's the S? 2. What's teh thing on the inside of teh car roof. i know there's the door lights, but other than that there's a button with a fan drawn on it. What is this? What does it do? How do you operate it? Thanks a lot. |
YarVitz
Drives: 07' Yaris Liftback Join Date: Sep 2006
cough...PICS!
YarVitz
oh and welcome to the forums!
This is the gear box. i didn't take it myself, took it from the iternet. but my gear box/car model is exactly the same.
maybe similar to 3, 2, 1?
how to use it?
same as you would for those "3, 2, 1" gears? how fast were you driving on "B" it may have made a lot of noise because it's a lower gear. and if you were driving, say, 40 mph, then it would be in the upper range in rpm.
at abt 30 mph
what does the 321 gear do? |
der Zeck
I would only use "D" for driving forward Apples if you do not know what the others are for
that's what i'm doing till now. but now i want to find out what those two gears do.
![]() Drives: white yaris hatch Join Date: Jun 2007
all cars have other selections other then drive. the first thing you need to find out is if your car is a four speed or three speed automatic because if it is a three speed the s would be second gear and the b would be first gear and those gears are for when you have low traction and need to take off slower.
really? i thought that the lower gears have a shorter gear ratio, meaning more torque (?). so wouldn't you want to take off in a mid-range gear if you have low traction?
i.e. say a Viper. one is more likely to lose traction while taking off in 1st gear rather than 3rd gear. |
![]() ![]() ![]() Drives: None Join Date: Mar 2007
Usually if you lack traction, you take off in second, so yeah, you need a higher gear (lower torque, higher speed for given RPMs vs 1st). Really, the only reasons to use the gear limiters in auto are:
•Overtaking on a highway •City driving, where the car will go 3-4, 4-3, 3-4, 4-3, so by limiting it to 3rd, you will [ideally] save fuel from the transmission not having to shift so much •Hills To avoid slipping (in snow), some automatics have a winter/summer mode button. When you are in winter mode, the car starts in second and shifts earlier, to give you less torque (as it will be wasted by uncontrolled wheel spin anyway). |
so i was right...
Look mum no stars!!
the manual would tell u?? im guessing it will be kinda the same as 2 and L??
Parallel Parking Pro
I asked one of the local JDM Vitz owners and he said that B is just a low gear. The slot corresponds to L for a regular Yaris.
I would surmise that it is a towing/heavy load gear. It maxes out at 20kph and won't shift up according to him. We cannot however figure out why it is B instead of L. The thingy with a fan on your roof interior is probably an air ionizer gadget thingamajig. You might check eTimago's Toyota Thailand parts ordering thread to see if it looks the same. There is a roof-mounted ionizer in that menu of parts.
Leong's NCP91 Toyota Yaris E Hankook V12 Evo 195/55/15 on Buddy Club P1 replicas 15x7 ET +38 Stebel horns, Philips Silvervision turn indicator bulbs TTE Lowering Springs, Camber bolts TRD Blue brake pads Fujitsubo Super Wagolis axleback exhaust DC Sports header |
| Few questions | mystikdynasty03 | Cosmetic Modifications (Exterior/Interior) | 3 | 05-01-2007 08:42 PM |
| Lowering Springs - Questions ~ | jaspie | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 16 | 01-10-2007 09:21 AM |
| Questions on pricing | littlecarlove | New YARIS Purchase Forum | 17 | 10-29-2006 08:53 PM |
| Questions, questions... | littlecarlove | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 10-21-2006 02:42 PM |
| Newbie questions about the 2007 Yaris | urabus | General Yaris / Vitz Discussion | 11 | 07-06-2006 12:32 PM |
