Old 08-20-2006, 05:50 PM   #1
SamDaYarisMan
SamDaYarisMan's Avatar
Drives: meteorite liftback
MAINTENANCE REQUIRED!!!
Hey guys i got in my car today and the maintenance required light flashed about 10 times when i started up my car. I'm just wondering if something is wrong or if it's time for the first oil change. The odometer is a lil over 4500. I changed the oil at 3000 but i know toyota recommends every 5000. Is this just a reminder for the 5000 mile oil change? Thanks.
YARIS LIFTBACK: meteorite metallic, 5speed, debadged, 15" black rota gt-3's w/ 205/50/15's, tanabe df210's, colibri universal power window kit, glow shift 2" tach and twm shortshifter.
FUTURE MOD's: power door lock kit w/ keyless entry and new audio.
SamDaYarisMan is offline   Reply With Quote
Old 08-20-2006, 06:11 PM   #2
MacMaster761
Five-Star General
Drives: 07 Silver Streak Mica
Send a message via AIM to MacMaster761
look in your manual, there is a way to disable the light manually if you know that you dont need the oil change.
JWU '09 Baking and Pastry
MacMaster761 is offline   Reply With Quote
Old 08-20-2006, 07:19 PM   #3
SimmZ
Drives: 2k3 Cavalier & 2k2 Echo
Did the Yaris have a light especially to recall engine regular maintenance? Cause in my 2002 Echo, there's only one light and it's a "Service Engine Soon" light (Check Engine). And flashing "check engine" light is indicating a cylinder misfire problem.
I have this problem on my Echo because I have a cracked ignition coil on cylinder #2. I had to replace it cause the Echo is out of warranty (105,000 KM now). But part cost only 50$ and I replace it myself in 5 minutes.
2003 Chevy Cavalier Ecotec - His car!
2002 Toyota Echo Sedan - Her car... FOR SALE!
SimmZ is offline   Reply With Quote
Old 08-21-2006, 10:51 AM   #4
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
It starts flashing on startup at 4,500 miles to let you know an oil change is coming up. It stays on after 5,000 miles. I think it's a great feature.
To reset - with the odometer in "Trip A" mode turn the ignition off - hold down the trip odometer reset button and turn the key to the "on" position (not start) - keep the reset button depressed for at least 5 seconds - you'll see several little dashes counting down and disapearing then all zeros display indicating it is reset. You're done.
(The manual says it's not in Canadian versions.)
Old 08-21-2006, 11:07 PM   #5
SamDaYarisMan
Thanks a bunch violin!! thought something was wrong with my car.
Old 08-21-2006, 11:17 PM   #6
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Look on the back of your thick manuals guys... its the first "quick note" listed.
Old 08-22-2006, 12:30 AM   #7
johnnyfive
johnnyfive's Avatar
was flashing check engine light at me for a couple days now, and just tonite i was driving, and BAM, hit 5k miles, and maintnance req. light comes on :)
was afraid i was going to have to get out the manual, but no need now, thanks :)
johnnyfive is offline   Reply With Quote
Old 09-19-2006, 05:07 PM   #8
Racer X-8
Races Little Red Wagons
Racer X-8's Avatar
Drives: red '07 Yaris liftback auto.
Thanks Violin.
Racer X-8 is offline   Reply With Quote
Old 10-09-2006, 11:50 PM   #9
Buckethead
Sweet, mon frer!!!
I'm at 4630 right now. My car will not get its first oil change before 6000 miles.
Buckethead is offline   Reply With Quote
Old 10-10-2006, 09:38 AM   #10
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
at 12000 it start blinking again
will work for parts
vodkalush is offline   Reply With Quote
Old 10-10-2006, 01:00 PM   #11
xfatefailsx07
Lean Wit It. Rock Wit It.
xfatefailsx07's Avatar
Drives: 2007 Yaris Sedan - 5 Speed
hehe chris always gets frustrated when people dont read their owners manuals..
YARIS... enough said!
xfatefailsx07 is offline   Reply With Quote
Old 10-10-2006, 02:13 PM   #12
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
Yeap, also in European versions...Dammit!
Old 10-10-2006, 07:42 PM   #13
Chris07LB
Chris07LB's Avatar
Maintenance - Change Auto Trans Fluid Linkseal DIY / Maintenance / Service 1 08-15-2006 11:57 PM
