![]() ![]() ![]() Drives: yaris hatch 07 640K original m Join Date: Mar 2007
hatch door
the latch in my 07 hatch is stuck. totally. I tried spraying wd40 from both sides but still wont turn. How can I get it from the inside??? There must be a way..
Just pop the little rectangular cover directly behind it, on the inside of the hatch. Once you do you will see the lever that the latch pushes on. Simply push it to the side with you finger and the hatch will pop open.
how would you clean it so it doesnt do that again??
You can remove the one bolt on the inside of the hatch to remove the entire lock assembly to clean and lube it. If the latch assembly is the problem, you can remove that from the bottom edge of the hatch and do the same.
I see how it works now... but on mine the white plastic thing wont go in the unlock position.
I can leave it unlocked and lock it but the key just cant force it over to unlock .... I lubed it well with wd40 but still wont go... Would it be a big deal to replace the whole key drum and plastic thing with an aftermarket assembly that would fit in there??The drum seems to be held in my 2 bolts..not 1 |
#6 | |
http://www.yarisworld.com/forums/showthread.php?t=39677 Also, try a different key, if you have a spare, as it may be that your key has worn too much for the hatch lock.
| DIY: Replacing 2-Door Liftback Door Panel Fabric | redyaris | DIY / Maintenance / Service | 25 | 06-25-2024 01:24 AM |
| 3 door vs 5 door hatch | bentjazz | General Yaris / Vitz Discussion | 48 | 03-13-2014 05:17 PM |
| 2008 Yaris sedan ‘S’ sound deadening project. | Herbicidal | In Car Entertainment + Electronics (audio / video / alarm) | 155 | 09-04-2011 11:56 PM |
| rear hatch for 08 yaris 5 door | nb85351 | Willing to Buy by private party | 1 | 09-05-2010 07:12 PM |
| DIY: Changing Factory Door Handles and Lock Cover | redyaris | DIY / Maintenance / Service | 10 | 05-19-2007 05:55 PM |
