2007 "Red Yaris" RS Restoration
This thread will be dedicated to a major restoration I will be doing on a 2007 RS 3-door that I recently picked up.
The bad: The car failed inspection for a the following reasons: - Rotted rear subframe where the axle arms attach - rear brakes (both sides) - rear right side e-brake cable - right front axle torn boot (I have a good used axle, but will try to just swap the boots) There are a few other things that need fixing which include: - driver's side door catch is missing (I pulled one from a local junkyard) - driver's seat track is locked in position and will need fixing or replacement. - some bubbling around the rear fender wells where it looks like it was repaired before. The car will get complete bodywork and a full repaint. - missing springbolt on manifold-to-midpipe connection. - back hatch latch button sticking (remove from car, disassemble, clean, degrease, relubricate tumbler, reinstall). The good: - drives perfectly, smooth and no creaks or noises. - immaculate interior! I have never seen a car in such good shape for its age. The seats from this car are going in my 06 turbo Yaris. The ones in my turbo Yaris are in great shape, but these are immaculate. The interior trim pieces are also perfect and I'll be scavanging the center console bezel pieces for my '06 as well. - $1000.00 Canadian purchase price. Pics of the car on date of purchase: ![]() ![]() ![]() ![]() ![]()
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 08-29-2020 at 07:01 PM. |
Repairs begin
I can't guarantee that the sequence of repairs will be documented in a logical order as I may work a little bit on this job, then a little on that job. I will edit posts though, adding pictures of each job as I go. Car lifted on jackstands ![]() ![]()
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 08-29-2020 at 06:03 PM. |
Rear Brakes
I have one side done. I removed everything except the wheel cylinders, cleaned up the rust, sanded the nubs that the shoes sit/slide on, painted the backing plates and greased the nubs with silicone brake lube. I disassembled, cleaned and lubricated the star adjuster assembly, installed new shoes, hardware kit and drums. ![]() Drums were primed and painted with ceramic aluminum-colored paint ![]() E-brake Cable ![]() ![]() ![]() ![]() 01 Sept, 2020 Update: E-brake cable installed
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 09-01-2020 at 08:02 PM. |
I'll be watching with enthusiasm. I have a soft spot for a 2007 Red 2-door. Lots of good memories. Loved that car!
#5 | |
Subframe Rust Repair - Disclaimer - shocking images:
A 'design flaw' in these cars allows a lot of sand, dirt and debris to build up inside the cavity onto which the supports for the rear axle bushing are molded. Any water is absorbed by the crud and it sits there like a wet sponge. I've already seen several Yari that have failed inspection as a result. I expect that most of them will end up in the scrapyard well before the powertrain is ready to give up. Before I decided to buy this car, I spent some time under it with a pry bar, flash light and a small collection of tools. Thankfully, the seller was amenable to that. Because of the gaping holes, I was able to confirm my suspicion that Toyota used heavily reinforced steel at the axle mounts and thinner steel surrounding those areas. I have yet to determine all the locations that water, dirt and debris enters these cavities and sits there doing its insidious work, but I do know how to access these areas and saturate them with oil. I think I saved my '06 in the nick of time as I drenched all these rust-prone areas well as soon as I got the car and have done so a couple times a year. ![]() ![]() ![]() Getting these bolts out was a time-consuming process, but they came out intact. The threads above the captive nuts were very rusted. Lots of repeated doses of ReleasAll and wire brushing over a couple of days and lots of back and forth with the ratchet and they came out. I was prepared to use new bolts and weld new captive nuts in but it turned out to be unnecessary. The nuts were wire bushed, coated in antiseize and reinstalled. I notice that my rear axle bushings are cracked. They are solid in the main part of the bushing. I actually have 2 new ones in boxes that I bought a while back as they were on clearance. If I need to, I will remove the axle and take it somewhere and have those new bushings pressed in. But, for now, it's very tight and no noise. ![]() Body brace degreased, sanded and primed. Will paint this in satin black. ![]() ![]() Update 01 Sept, 2020: 2nd brace degreased, sanded and primed: The second brace bolts came out using the same procedure of wire brushing, multiple applications of penetrant and back and forth with the ratchet.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 09-01-2020 at 09:44 PM. |
It’s always distressing to see what Canadian winters due to cars!
![]() I grew up in upstate New York 80 miles from Lake Ontario so I have some experience with that problem. Now that I live in New Jersey cars fare much better. My wife’s 2005 Camry with 185,000 miles is like brand new underneath!
Door Check Install
The driver's side door check on this car was sheered off. To replace it, the door panel needs to be removed. Thanks to another post here on YW, I learned how to use a cloth to remove the window crank retaining clip. YARISWORLD MUST NOT DIE!!! So, it appears that I will need a new door gasket as it's swollen from rust proofing. A blessing in disguise as the doors are 100% rust free. I'll be hitting the U-Pull again, so I'll grab a door gasket, or, remove a section of this one and weld it back together. ![]() I got a lot of grey anti-seize on the door using the wrong rag, duh! It cleaned up pretty well though. Car will need a thorough detailing when I'm done for sure! ![]() ![]() Somebody was in here before. Painter's tape??? ![]() Junkyard door check, $10.00 at U-Pull. ![]() All re-sealed. I love Tuck Tape! ![]() Door back together:
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 09-02-2020 at 06:23 PM. |
I personally find a lot more attractive if somebody restores a "normal car" rather than some rare "piece of art" that needs to sit in a museum after the successful restoration.
I wish I had time, space, money and knowledge to do that as well. :) Nice work! |
Thank you, komichal! All of this is such a great learning experience. Some day, maybe in retirement, I will attempt the restoration of a more 'classic' automobile. Not like a true classic, but something interesting and sporty. That said, anything I fix up/restore, will get driven regularly. I agree. What's the point in putting in lots of effort and time if you can't enjoy it, other than staring at it? For the time being, my hope is to find more Yari that are seemingly destined for the scrapyard (aka, fail inspection due to the rear rust) or other minor issues, fix them up and put them back on the road. Who knows, maybe it could net me a little supplemental income in retirement.
Preparing to weld
Didn't get to go out to the car until almost dark tonight, so only had time to do a little poking around and plan my welding. I did discover more about the internal structure of the rear subframe/unibody area. The oblong plug just in front of the rear wheel on each size does provide access to the cavity that forms part of the rear axle support structure. Spraying oil into the oblong plug holes will not actually get oil/rustproofing into the larger inboard cavity. But...there are holes a few inches up into which a short wand could be placed. Possibly even the straw on a spray can of rustproofing could reach. A flexible wand would definitely work better. No matter how you access the inner cavity, I would load it with a very large amount of oil or rustproofing. When my repairs are done, I will be using a flexible wand and blast close to 1/2 a liter or more of stuff in there. I plan to use a thin product so that it will soak through any additional debris and stuff that accumulates in there. Here is the hole to access the inner cavity. ![]() Another look inside
#14 | |
![]() ![]() Drives: 06 Yaris RS MT Join Date: Jun 2018
Was telling my friends I feel like scrapping my Yaris because of the holes on the subframe, and they were laughing at me. I have to admit that I'd be spending as much or more time swapping the turbo setup into another Yaris than patching these holes... I'll be following this closely as I plan on doing this before the winter. |
#15 | |
#16 | |
Your thread is motivating! I had the same idea, if I can't fully patch the holes, I'll weld some braces at least. |
#17 |
Yes, I think some metal strips bridging the hole would provide a good foundation for fiberglass. I would use the mat material as it's very strong - almost like steel when the resin cures. The added advantages, of course, is that it doesn't rust, it's very easy to conform to any shape and primer and bedliner sticks to it like crazy. I might drill some holes in the metal strips to poke the fiberglass into. Then, maybe apply a second layer of fiberglass. Everything will ultimately be drenched in oil, so no further corrosion should occur. I did a quick bit of research as I was concerned that the oil rustproofing might destroy the bond between the fiberglass and metal. Apparently both the polyester and epoxy resins are tolerant of many fossil fuel based products. Now I just have to find some epoxy resin. Shouldn't be too hard as I live in a fishing community. LOL.
#18 |
![]() Drives: 2009 Toyota Yaris Hatchback Join Date: Aug 2020
Good to know, thank you for the new information! It would be nice if you could take a picture of the access hole as seen from the inside of the corroded cavity. I am thinking of feeding a thin vinyl tube into the access hole until it reaches the bottom of the cavity and spraying the rust inhibitor through the tube.
On the other hand, it might be unnecessary to use the tube if the rust inhibitor readily spreads over metal surfaces by itself (similarly to, say, kerosene or WD-40). |
| SiriusXM Tuner - 2007 Yaris | rjp123 | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 06-19-2012 10:16 AM |
| TSB's | WD-40 | General Yaris / Vitz Discussion | 27 | 06-06-2007 01:11 AM |
| 2007 Registration and Insurance | Vitz-to | General Yaris / Vitz Discussion | 21 | 03-28-2006 09:57 PM |
