Old 01-30-2009, 05:54 PM   #1
Cutie Pie #2
Drives: 2014 Honda CR-V LX
TPMS question
I just got new tires today and the TPMS/TPWS light flashed for about 1 minute, then just stayed on, I turn car off, turned it back on and still was on. I know there is a TSB for the TPMS.
But before I call dealer, did the tire shop do something wrong or is this the TSB. I checked tire pres. and it was good in all 4 tires.
Also is there a way to reset the light.
Cutie Pie #2 is offline   Reply With Quote
Old 01-30-2009, 05:59 PM   #2
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
1. did the wheels get the tpms monitors installed on them?
2. did the tpms monitors end up on the same corners of the car they came from?
Originally Posted by xnamerxx
you nailed it sir.
Old 01-30-2009, 06:02 PM   #3
Cutie Pie #2
They orignally came with the car.
Old 01-30-2009, 06:12 PM   #4
Tamago
Tamago's Avatar
Drives: ZZW30
yes but the new wheels... did your shop install the tpms sensors in them?
you nailed it sir.
Old 01-30-2009, 06:19 PM   #5
Cutie Pie #2
As far as I know yes, but...
I had gotten the wheels about a year ago, the light didn't come on then or when I have gotten the old tires rotated. They didn't replace the sensors they are the orignals that were on the car when I purchased the car.
Old 01-30-2009, 06:22 PM   #6
Tamago
Tamago's Avatar
Drives: ZZW30
maybe the shop damaged them..
also i believe you can reset the TPMS sensors. not sure if you can do it yourself. check your owners manual maybe?
you nailed it sir.
Old 01-30-2009, 06:57 PM   #7
Cutie Pie #2
Is there any way to reset the light. I just called the shop where I got the tires they said it may have to be reset.
Old 01-30-2009, 10:06 PM   #8
Saggio
Top Notch!
Saggio's Avatar
Drives: 2008
Give it a day of driving, it will reset itself.
Saggio is offline   Reply With Quote
Old 01-30-2009, 10:11 PM   #9
Cutie Pie #2
Thanks, I give that a try first.
Old 01-30-2009, 10:13 PM   #10
yarstar
Drives: 2008 Absolute Red HB
I think they may have damaged them. Look closely at your valve stems. If one is different than the others, that means a TPMS sensor is missing.
I used the same shop for both my wheel changes. If you don't know what your are doing when you break down the tire, you will crush the TPMS with the machine. You have to be careful and really know it's there and stay away from it.
I've rotated tires 3 times and changed wheels twice w/o a problem.
Sorry to hear about this. I hope it's not what I think it is.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB
yarstar is offline   Reply With Quote
Old 01-30-2009, 10:21 PM   #11
Cutie Pie #2
Just curious: If they were damaged, would of the light come on sooner, the warning light came on later when I had already driven about 20 miles.
All valves look ok.
Old 01-30-2009, 10:50 PM   #12
All valves look ok.
If one was damaged (or missing) it would take about 20 miles for the light to come on with system's tolerance of not hearing from one or more sensors.
Check out the following post - you can actually get the TPWS CPU to report what its issue is by flashes of the TPWS light:
http://www.yarisworld.com/forums/sho...8&postcount=11
Old 01-30-2009, 11:02 PM   #13
yarstar
I think what he said was right ^^^^
It may be that they cracked one on the changing machine and it took 20 miles for it to come apart. The valve stem you see looks to be made of metal. The part of the TPMS on the inside of the tire you can't see is made of plastic. Easily broken, plastic. It could have been cracked and then the spinning wheel caused it to break loose.
Damn shame. I really wish we didn't have these things to deal with on our cars.
Old 01-31-2009, 08:59 AM   #14
Cutie Pie #2
Probably going to end up taking it back to where I purchased the tires.
I have not look, but would my scan gauge pick up codes from tire sensors?
Old 01-31-2009, 09:51 AM   #15
No, the scangauge won't read it, as the TPWS ECU doesn't report codes to the main ecu.
Old 01-31-2009, 07:37 PM   #16
Cutie Pie #2
Well to make a long story short, I went back to the tire shop today, they reset it twice the light never went out, so I call a dealer to get a appointment they said if I could be there in 10 minutes they could take me today, so off the dealer, they fixed it under warranty, but they were not at first. I complained a little and then they did. So my problem is fixed now.
Old 01-31-2009, 07:44 PM   #17
PreciousPups4U
I really LOVE this car!!!
PreciousPups4U's Avatar
Drives: 08 Bayou Blue LB AT
So, does that mean the tire shop damaged something? Or maybe the dealer could not tell what happened?
Cindy
Old 01-31-2009, 07:48 PM   #18
Cutie Pie #2
They said it might of happened at the shop, or the problem just happened to happen. They replaced all of the sensors just in case they were all bad. They could not tell how it happened or from what cause it.
Transmission Question CMR General Yaris / Vitz Discussion 42 04-14-2010 01:38 PM
So question here abt hatchs in general Jem_hadar General Yaris / Vitz Discussion 12 01-06-2009 04:06 AM
15" TPMS friendly wheels for my '08. Ideas? auxmike Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 12-08-2008 09:01 PM
TPMS TinyGiant Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 10-22-2008 04:57 PM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 04:59 PM
