![]() ![]() Drives: 2008 Yaris LB 5 speed Join Date: Oct 2008
My Grill Block
Check it out guys... Whatcha think should I do the bottom aswell?
better than some I've seen, nice job
![]() ![]() ![]() ![]() Drives: Yaris Sedan 5MT Join Date: Oct 2008
Nice!...I just went with the cheap and easy and used black duct tape. Of course, the sedan's top opening isn't as large as the hatch's so it was easier to just use the tape.
Materials I used were as follows. This floor matt type thing that is foam like and plastic zip ties.. Had both at work. Free. So should I do the bottom opening aswell? I was thinking I'll wait till it gets really cold. See how it goes with this setup for now.
I wouldn't do the bottom unless you've got a scangauge so you can keep an eye on your engine temps. Wouldn't want to damage the car
3,441,567,453 posts BH (Before Hack) |
╚══════════RN
+1, are you running this currently? Keep an extra close eye on your temp.
#7 | |
I am using it currently. Just made it yesterday. It's been getting cold! |
i drove my yaris all winter last year with no block and had no problems at all. keep in mind that im in north central wisconsin. it gets pretty cold here and had no problems with it at all.
╚══════════RN
You shouldn't have any problems. The point of the grill block is to make the engine warm up faster and stay warmer. I'm sure BailOut can give you the numbers, but in theory it should help improve your fuel economy in the winter months.
![]() ![]() ![]() ![]() Drives: Soon to be LFA Join Date: Oct 2008
man if you would have found some way to tie it without the zips it would look pretty sick.
![]() Drives: Yaris Hatchback Join Date: Oct 2008
Looks Real Nice!
Great job, looks very professional.
Someone mentioned in a previous post, to loose the zip-ties. I used Velcro to fasten my block. Makes it real easy to remove in the summer or on the rare hot winter days....push-on & rip-off! |
~ ambient one ~
Drives: 2009 Bayou Yaris Liftback Join Date: Jan 2007
Hmmm .. but doesn't it block a bit more airflow to your intake which you want?
It's understandable in terms of warming up the engine, but I'd personally take airflow over warming your engine up quicker. Lol what, can't get a remote start or start your car 10 min before leaving?
AMBIENTLIFESTYLE
Tri-State Sport Compact EZine ambientlifestyle.com------------ambientlifestyle.ning.com ![]() Micro Image Store - Network - Online microimageonline.com------------microimage.ning.com Last edited by Treyz; 11-11-2008 at 10:57 AM. Reason: spelling and punctuation fixes |
#13 | |
╚══════════RN
Starting your car 10 minutes early would waste gas. You should read, too. This isn't a performance mod obviously, however I doubt it would make any noticeable difference in power.
As I said before, the grill block helps the engine warm up faster, and stay warmer for longer after you turn the car off in case you will be starting it again shortly. http://www.yarisworld.com/forums/showthread.php?t=8985 Quote:
#14 | |
This is a Fuel Economy Forum broseph.. |
#15 | |
╚══════════RN
Doing something like not idling for an excessive amount of time, or turning your car off at lights isn't ridiculous, it's really simple and easy to do. Bassically, if you don't want to do it, then don't and stop complaining about it. Or search before you post, so you actually know what you're saying.
I'll be making a winter front this weekend. My car JUST hits operating temp (86) as i role into the parking lot at work. (25min drive.)
![]() ![]() ![]() ![]() Drives: 06 yaris 5-dr le man Join Date: Mar 2006
hmm...might think about making one of these.
glad i read this, i was confused as to what the purpose of a grill block was. i thought it was for aerodynamics! duh |
╚══════════RN
So this whole conversation got way off topic...
I think I'm going to make a grill block myself, too. Whoever was using the velcro to hold it on, how's that hold up? You think a couple feet of snow and some highway speeds will take it off?
| DIY: Engine Grille Block | BailOut | DIY / Maintenance / Service | 39 | 11-11-2017 10:33 PM |
| Grille Thread.. | Blenjar | Cosmetic Modifications (Exterior/Interior) | 40 | 11-14-2010 04:26 AM |
| New grille or not | free297 | Cosmetic Modifications (Exterior/Interior) | 27 | 11-14-2010 04:21 AM |
| Need help, removing grill, adding new one | drbilal | DIY / Maintenance / Service | 4 | 10-29-2008 10:11 PM |
| DIY: Yaris Hatch grill block/air dam | yarswiss | DIY / Maintenance / Service | 0 | 10-26-2008 07:52 PM |
