Old 02-16-2010, 08:27 AM   #1
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
15" to 14" rims
I have a set of 14" rims from my last Echo with nearly new all seasons mounted,come spring i'm thinking of installing the 14's instead of the usual summer 15's,i cant think of any potential problems doing this other than some minor mileage and speed reading discrepencies from the instruments..Am i missing anything?
Its an 08 Yaris sedan..
Thanks
Old 02-16-2010, 09:20 AM   #2
BluYrs
ヴィッツ ドライバー
BluYrs's Avatar
Drives: 2006 3d 1.0 Linea Sol
If the brake calipers fit, you should be clear to go.
The blue one
Old 02-16-2010, 11:43 AM   #3
i run 14's in the winter...only difference is the rolling diameter might be smaller than your oem 15" tires....nothing you really need to worry about
Old 02-16-2010, 01:56 PM   #4
14s should fit fine.
Old 02-17-2010, 09:05 AM   #5
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
I run 14's. If they fit the echo they should fit the Yaris. Mine are 14x5.5 +35, and they fit fine.
Colin Chapman disciple
Old 02-17-2010, 10:37 AM   #6
kimona
kimona's Avatar
Drives: 2014 White VITZ
Of course they should fit fine. 14's are standard equipment on many Yaris models.
Old 02-17-2010, 10:46 AM   #7
not all 14's fit though. miata daisies don't fit because of the offset of the wheel....i think older toyota 14's won't work either because the offset is too high (>45)
Old 02-17-2010, 10:48 AM   #8
jambo101
jambo101's Avatar
As said before the rims came off an Echo,,guess i'll find out come springtime..
Old 02-17-2010, 11:51 AM   #9
*MAD DOG*
*MAD DOG*'s Avatar
I had 15" inch alloy mag rims on my Yaris, I purchased a set of 14" stock steelies from a member on here who had them on his 09 Yaris. I've since put them on my car. I've found that by going from 15" to 14" has caused by speedo to be incorrect. My speedo says i'm going faster than what I really am.
e.g.
To go 100km/h i need to travel at 108km/h on the dash speedo
To go 90km/h i need to travel at 99km/h on the dash speedo
To go 80km/h I need to travel at 88km/h on the dash speedo
So you won't get into trouble for speeding if you follow the dash, but you will wonder why the whole world is passing you. Of course the other bummer is if the car thinks it's going faster than it actually is it is also putting more km on my dash display than necessary and also means I have to service sooner to keep my warranty.
Old 02-17-2010, 01:21 PM   #10
e.g.
should have bought tires that match your oem sizing...thats not the wheels' fault
Old 02-17-2010, 02:03 PM   #11
*MAD DOG*
*MAD DOG*'s Avatar
Unhappy
Both 15" and 14" are oem if you bothered to read my post.
Old 02-17-2010, 02:23 PM   #12
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
Yes, but you are not running correct rubber, meaning the OD is smaller. Yarii do come with both 14 and 15 wheels oem, but they run similar OD tires to match the speedo calibration.
Old 02-17-2010, 03:16 PM   #13
i did bother, but if you knew to size your 14" tires to match your 185-60-15 tire size, you wouldnt be 3.5% off in YOUR oem rotating diameter running 175-65-14's. its simple math to figure out they arent the same diameter. since 185-60-14 =~ 175-65-14, you're actually 1/2" LESS rubber on your sidewall, and thus 1" shorter overall.
its a post i've made before since my car came with 14's and i mentioned that the speedo seems off according to gps (again confirmed this weekend going up north)
i think all yaris speedo's are set to 185-60-15 sizing, not 175-65-14.
Old 02-18-2010, 12:47 PM   #14
Mouse
Drives: 2007 MX5
Will 14x7 with a 19 offset fit?
Mouse is offline   Reply With Quote
Old 02-18-2010, 01:18 PM   #15
MUSKOKA800
MUSKOKA800's Avatar
I run 14" Echo steelies with 175/65/14 snows (the stock Echo size) on my '08 sedan.
No clearance issues. They look puny but fit perfectly.
When doing 100 kph on the GPS my speedo reads 102 kph. So, 2% over.
Benefits compared to my 15" factory alloys are slightly increased acceleration but most noticable is an incredible braking improvement. It nearly puts me through the windshield the first stop after installing the winter boots each fall. Of course this could be partly due to the almost non-existant dry traction of the OEM Goodyear LS three-seasons but more than likely due to the fact that the 14" steelie/snow tire combo is noticably lighter than the OEM 15" alloy set-up.
Old 02-25-2010, 06:01 PM   #16
B789
B789
Drives: Toyota Yaris
Well I have 185/60R15 on my 07 Yaris Sedan and 175/65R14 on my 02 Corolla. Both are stock sizes for both cars respectively and both show about 3 kms MORE than the speed shown by the GPS. Yes, GPS takes a while to calculate the speed but I compared at steady speed without any speed changes 5 minutes before and after the reading.
I noticed same offset when compared with multiple curb side speed detectors on the highways. Now which instrument is more accurate GPS or speedometer ?
B789 is offline   Reply With Quote
WTB: 4 15" alloy rims _Bravo_ Willing to Buy by private party 2 02-19-2010 06:39 PM
15" Chopper Rims for sale 33lam Australia 12 10-11-2009 01:01 AM
Does Toyota reset the speedo for the Yaris that have 14" and 15" rims? detroiter General Yaris / Vitz Discussion 19 05-17-2009 08:46 AM
Can I use stock tires on these 15" rims? songa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 02-18-2009 07:11 AM
