'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
I need a simple answer for a router question
I have what apparently is a pretty generic router Linksys WRT54G2.
FACTS: I use it primarily for my PS3. The PS3 is connected wirelessly to the router. The signal is between 60-80% usually with spikes in either direction. Signal passes through maybe 2-3 walls; about 12-20' from the PS3 in a direct line. I have read online the PS3 has a g card in it. Would anything change as far as gameplay/response is concerned if I upgraded to an 'N' router? I played two games of deathmatch in Mw2 tonight and total between the two was 3 kills and 28 deaths. it seemed like the gameplay was choppy (not iceskating) but like you could see a refresh rate kind of thing happening to the screen. the signal status on the game said i had 4 of 4 bars.... I don't know if it's the router, my ISP, or if I just suck that bad anymore lol..... |
ekodrvr
Drives: 2002 white subaru impreza wrx Join Date: Feb 2009
with gaming, your symptom is called lag... conceivably, removing lag could improve gameplay and kill vs death ratio... the best way to solve lag is to run a hardline, ie some category 5 cable from router to ps3... this is an advisement that i have been giving for years and the technology involved has not changed enough to invalidate this advice... this is my two cents on that point... on the other, upgrading to an n rated router will make extremely minimal if any improvement to the problem...
if you want to see my plans for this car, check out here... http://www.cardomain.com/ride/3154316 i like this smiley...
Mr. 155 and climbing
Copper is always the best option...wireless really should only be considered when copper is not possible. as PK stated you can only connect as fast as the lowest speed component can connect so without an N adapter for your PS3 you are limited to G. Another tidbit on N is that in order to get the best out of your N link you need to be as close as possible. N speeds drop dramatically even after the first 10 to 15 ft.
#1 Lemming
Drives: Light Blue '08 Yaris Join Date: Mar 2010
Also consider setting up some sort of port forwarding/QoS rule. You should be able to set on the router to have your PS3 be the most "important" device on your network, and provide better, more consistent traffic to it, whether it be by MAC address, or by specific ports that are used by your system/games. You may notice a slight improvement doing this over wireless, but as everyone else has already stated, you're not going to beat wired speeds.
Does the PS3 have a Gigabit NIC? If so, if you upgraded to a router with Gigabit ports, you'd have almost no lag on the transmission of data over the line between the PS3 and the router, though it won't fix or increase your Internet speeds.
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
1) I have what apparently is a pretty generic router Linksys WRT54G2.
OK 2) FACTS:I use it primarily for my PS3. whatever 3) The PS3 is connected wirelessly to the router. ok 4) The signal is between 60-80% usually with spikes in either direction. 55% and below is where packet degradation starts. someone turns on a microwave within 50 feet of it, signal will degrade/drop out. if it really never drops below 60% then wireless is not the problem 5) Signal passes through maybe 2-3 walls; about 12-20' from the PS3 in a direct line. doesn't matter. if it is 55% or higher the speed is fine 6) I have read online the PS3 has a g card in it. ok 7)Would anything change as far as gameplay/response is concerned if I upgraded to an 'N' router? nope, but your wallet will be lighter 8)I played two games of deathmatch in Mw2 tonight and total between the two was 3 kills and 28 deaths. it seemed like the gameplay was choppy (not iceskating) but like you could see a refresh rate kind of thing happening to the screen. the signal status on the game said i had 4 of 4 bars.... I don't know if it's the router, my ISP, or if I just suck that bad anymore lol..... ok ----------------FIX (as others have stated) A) connect your ps3 direct to the router with ethernet cable, this will eliminate emi and take all guesswork out of the issue B) search google for your router QOS settings and tweaks specific to your game, and try to optimize it. this will take some time to fine tune, play, see the results (or non-results) and tweak again. there may be optimal MTU size or QOS settings for your game and internet provider connection you may need (should do, I mean) to load DD-WRT firmware on your linksys, and get rid of the factory image, then you will have the doors open to really fine tune the linksys and control how it operates. dd-wrt is FAR better than the original linksys firmware. time to step up the game http://www.dd-wrt.com/site/index C) could be the ISP that sucks. most do to some extent |
#6 | |
#1 Lemming
*NOTE* Flashing the firmware on a router, while giving good benefits, can lead to a bricked router if not done properly. Be sure to read the documentation and above all else, TAKE YOUR TIME!
#7 | |
Drives: 07 sedan Join Date: Mar 2010
Or, as others have said, get a cable - no loss under 100 feet(even up to 150 you should be good). |
Audio Junky
fawk.... I got all excited, though you were talking about wood working.
![]() ![]() Drives: 07 5 door Hatchback Join Date: Jul 2007
As other have said, wire is the best option.
Going to a 'N' router will not improve your speed if your PS3 has a G card. However, I've noticed that N routers' signals is better. It may ensure that your signal quality remains above 60%. |
I'm not reading the rest of the responses so this is already posted, but the PS3 doesn't have N compatibility.
Secondly, buy this: http://www.bestbuy.com/site/Motorola...reme&cp=1&lp=1 Just adding that to my setup DOUBLED my average speed tests from 20 Mbps, to 40+Mbps.
Toyota Moving Forward ...even when you don't want it to. Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
I bought a 50' Belkin ethernet cable for $5.88 so I'll see what happens when it gets here....
#13 | |
#1 Lemming
Also, when using 10/100/1000 ports, be sure to take full advantage of it by using a CAT-6 cable, as CAT-5 and CAT-5e aren't as capable of supporting the higher speed.
#14 |
hmm.. just 2 points here....
1) cat5e supports up to 1gigabit 2) wifi signal strength ≠ signal quality. So even if your system says reception is 4/4 bars, doesn't mean you'll get all the speed needed. |
#15 |
#1 Lemming
While cat5e supports 1gbps, cat6 was designed with this specifically in mind. cat5e is just a "better" cat5.
#16 | |
http://www.dd-wrt.com/phpBB2/viewtopic.php?t=40142 HTH
--[ FORUM RULES ]--[ SEARCHING TIPS ]--[ EYELIDS PICS ]--[ RBK SPOILER ]--[ BEST/WORST INVESTMENTS ]--
#17 |
well i got my FastCat 5e cable for 5.88 + .97 shipped 50 foot belkin cable.....
and yep no mo' lagging...so nice I'm actually getting more 'registered hits/kills' and actually keeping up.... |
| Simple question regarding Hatchback vs Sedan axles | wholenizz | General Yaris / Vitz Discussion | 4 | 03-27-2010 06:31 AM |
| Simple quick question | toyota | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 07-30-2009 11:13 PM |
| quick simple question | Aothachos | Forced Induction Forum | 4 | 06-15-2009 08:41 PM |
| simple question about bodykits | BokChoi | Cosmetic Modifications (Exterior/Interior) | 7 | 10-07-2006 06:57 PM |
| Simple Question...Head Unit...(Dont flame me!! :P) | hasher22 | In Car Entertainment + Electronics (audio / video / alarm) | 2 | 09-06-2006 02:35 PM |
