![]() ![]() ![]() ![]() Drives: '07 Yaris HB Join Date: Apr 2006
Tie rods?
So I am having some trouble with my steering. I just had an alignment done at Toyota and I'm still getting some wonkiness.
You would think Toyota would have checked my tie rods when doing the alignment but it doesn't surprise me they didn't ... Anyways, what's happening is it seems my tires will get "stuck" and kind of veer off to the right randomly, and there is play when turning right. Turning left is still tight like it should be. I'm just wondering if this could be outer or inner tie rods. I am going to do the 9-3 test on the wheel tonight to see if there is any movement in the rod end but just wanted to get someone with more mechanical experience's opinion. |
Toyota should have checked for wear in the end links. I've seen some pretty thrased ones. How many miles?
We have upgrade replacement end links that are adjustable, FYI
#3 | |
And yeah Toyota *should* have checked - I have ~232,000km or ~144,000 miles. Our roads here are GARBAGE, pot holes galore. |
They are used to tune the suspension, you can add pre-load to your front sway bar, for example. The Heim joints alone are an upgrade from the stock joints, so if yours are indeed shot (likely at that mileage with rubber parts under the car), now is a good time.
#5 | |
Way better than stock.
By the way I am talking about tie rod ends ... are you sure yours are the same? lol
I am just wondering one more thing. I jacked the car up and tried to look for wheel play ... passenger side there was none, everything was super solid. Drivers side would move a bit at 3 and 9 o'clock and I could see the boot for the ball joint moving a bit. What I don't understand is when I'm driving it seems like the issue is with the passenger side. Do tie rod ends affect the opposite side of the car? Any way I am bringing it to a garage to have someone check on it. It doesn't surprise me with our roads this has happened haha
Shut your fricken suck!!!
How much do those go for???
| Are the Prius connecting rods good for turbo application?? | monchyxb | Forced Induction Forum | 6 | 12-10-2014 05:00 PM |
| how do you tie down a yaris | cherry tomato | General Yaris / Vitz Discussion | 7 | 01-15-2011 05:26 PM |
| Con rods and Pistons | leinadeb | Performance Modifications | 4 | 05-23-2010 08:30 PM |
| How To Remove Trunk Torsion Rods? | Kaotic Lazagna | DIY / Maintenance / Service | 3 | 09-29-2009 01:09 PM |
| GI: 1NZ-FE Forged Rods | Nexus1155 | Forced Induction Forum | 41 | 03-21-2009 04:29 AM |
