![]() Drives: 2006 Yaris T1 Join Date: Jun 2010
4AGZE Modification
Alright, here's the deal... I want to drop Toyota's 4AGZE engine into my Yaris. Does anybody have any idea how much different the mounts are? Also, some advice on a gearbox would be appreciated. I'm not too fussed about management etc because I'm going third party there. The only difficulty here is to get all the information to the heads up display. Will I have to change the dials from digital to analogue or is it possible to leave the sensors and what not where they are and just use the stock computer? I have a fair knowledge of programming, so if any is needed, with some research, time and patience, I can work it out. I just want to know where to start.
Shotalot!
Mr. 155 and climbing
I think that there has been someone in Greece that did a Toyota 3S-GTE too. Your best bet is to do a search in the forum for either motor swap or engine swap. With that search you will find a few threads that you should find very useful.
Thanks! I just got some info from another guy here in South Africa and he says that the 1ZZ-FE is probably the best way to go...
Any other ideas?
the time's coming! i will do some research and see if the 2zrfe is available in sa! thanks guys!
Definitely going to go with the 4AGZE engine due to the fact that I'm going to turbo the engine come the end of the year! Thanks guys!
Post count means nothing.
Drives: AW11, NCP91, Old Motorcycles Join Date: Jul 2006
Why not just swap in a 2zz or 1zz? The mounting points are virtually the same as that of a 4ag (Requires a slight elongation of the holes for the motor mount on one of the sides...can't remember which right now). Newer motor that will build way more power than a 4ag ever will.
I saw one in a local magazine some time ago.... though they did change for a turbo setup rather than supercharged. No idea of how much fabrication was involved, though.
#9 | |
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
if you're goin that far, why not throw in a ls7 or ls9 in there??? tunnel the center for a driveshaft and use the corvett or porsche trans/diff in the rear....with independant suspension. it's feasible.
or, throw in the turbo mr-2 engine in there? or, throw in the b-20 honda engine. |
Bathroom + Laptop = <3
or why not some RX-8 rotary engine I remember being talked about in a previous thread
![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Oct 2008
Frame rail modification is required. I have a thread in the forced induction section. There should be a link to the build photos. Just drop in an ls9 motor and call it a day ;).
Project Slowtop - Twin Engine 4AGE Blacktop Vitz - Twin Turbo - 503hp 1987 Nissan Maxima - 40,000 original miles - Slammed 1991 Isuzu Impulse RS AWD Turbo - approx 250hp - Winter Beater 1989 Isuzu Imark RS - Mint Condition - 0 rust - 100% factory :) - Summer Cruiser - 100% restored 1986 VW Jetta Wolfsburg - 120,000km - Mint condition. TDI swap in progress |
I have a 2006 model Yaris though, so do you have any idea what's gonna happen there?
#14 | |
![]() ![]() ![]() ![]() Drives: 3-door hatch Join Date: Oct 2010
2zz and 1zz require frame rails to be cut as the engine/transmission together is wider
would a 4agze still be a 4agze w/o the s/c? lol a friend of mine has a s/c'd mr2 (subsequently a 4agze is in it). the s/c went kaput, so he turbo'd it. it already has the strong internals meant for boost, so its an ideal candidate to be turbo'd rather than supercharged...
#16 | |
main reason for going with the 4AGZE is the internals... here, it would put another 20 to 30000 onto the modifications... i can pick a 4AGZE up with the supercharger for 7500... i will turbo it later so instead of spending 60000 to turbo, i'm only looking at 25000 to 30000....
for now i can change the supercharger pulleys and pull about 0.7 bar (10psi) boost of the supercharger which should put me at about 170kW (+- 230 hp)...
| Front seat modification. Increase thigh support. | PetersRedYaris | DIY / Maintenance / Service | 36 | 08-22-2018 01:37 PM |
| Factory Miata wheels fit without modification? | evan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 22 | 07-02-2015 08:01 PM |
| Automatic headlight modification to add taillights | Snowy | DIY / Maintenance / Service | 8 | 09-18-2010 10:47 AM |
| Bigfoot modification and Weathertech floor mats | bitz767 | DIY / Maintenance / Service | 5 | 02-10-2010 09:31 AM |
| Simple modification yielded 4 mpg | Bob_VT | Fuel Economy Forum | 9 | 03-25-2009 08:35 AM |
