![]() Drives: 2007 Yaris Join Date: Jul 2016
Replaced alternator --> Electrics now broken
Thanks guys it turned out to be the alternator.
Now I've replaced that and it seems ok but now I have another new, worse issue! When I put the car to on (just before starting it) I don't have the following: -radio -engine light is on -power windows don't work Also the car starts ok but I have: - No Reponse from the accelerator - Power steering is gone - Engine light stuck on FFS! Any ideas? I've started checking fuses and they appear ok. |
Did you check the big 120A fuse inline with the positive battery terminal. There are 2 fuses there, one 120A and one 60A.
If you foolishly didn't disconnect the battery before replacing the alt, you could have very well blown one of the 'Main' fuses.
#3 | |
Can you replace just the fuse or do you have to do the entire fuse block that includes the 60A? |
the fuse block comes as one so you get both 120/60 and price is 24$ plus tax at toyota .
#5 | |
definitely the 120 is blown from the problem described...and its 24$ bucks from Toyota , location is on top of the positive terminal . |
THanks guys.. I'll replace this next.
The joy continues.. One of my power windows is stuck half way down and it's about to rain.
I tried applying some pressure between hands and lifting it up but it aint budging. Is there a manual way to lift it up that doesn't involve me tearing the interior of the door apart? |
#8 | |
| WTH, man? Broken off antennas | Kar98 | Third Gen Yaris General Discussion | 2 | 05-15-2015 07:04 AM |
| Broken broken aircon pump pulley + dual mass crank pulley | Bluecatcottage | DIY / Maintenance / Service | 1 | 03-31-2013 08:55 AM |
| How to replace a broken wheel stud | Rami yaris | DIY / Maintenance / Service | 4 | 06-28-2012 06:34 PM |
| Altenator Belt Broken After Replaced by Toyota | Yaris_guy | DIY / Maintenance / Service | 12 | 01-18-2011 10:14 PM |
| Broken 40/60 Back / Rear Split Seat Handle / Lever | alex_melodymaker | DIY / Maintenance / Service | 9 | 10-31-2009 05:55 AM |
