![]() ![]() Drives: 2006 Yaris HB 5DR Join Date: Oct 2008
driver side A/C vent blowing hot air
Sirs,
I know somebody here already had same problem with one A/C vent blowing hot air (side vents on the dashboard, infront of cup holder). I tried searching but no luck. Probably using the wrong keywords ![]() In case you know the thread, please post the link, otherwise, kindly advise. The problem: My driver side A/C vent recently started blowing hot air while the center and passenger side vents are blowing cold air. It occurs when the temperature knob is set from halfway the cold setting (blue colored) up to the start of hot setting (red/orange colored). When set on the warm settings, all vents are blowing warm/hot air. when set on halfway down to full cold settings, all vents blowing cold air. Appreciate all your replies. Thanks! |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 06 Polar White 5dr, 13 Soul 4u Join Date: Oct 2008
Sounds like a different issue through. It sounds like the OP's blower mix door is not straight in the airbox or maybe is binding on one side, since it is fine all the way open and all the way closed.
#4 | ||
#5 | ||
| DIY Cabin Air Filter | BailOut | DIY / Maintenance / Service | 105 | 06-20-2019 01:59 PM |
| Anyone here trim off the sides of the weathertech vent visors? | marlondog | Cosmetic Modifications (Exterior/Interior) | 9 | 02-11-2010 12:36 PM |
| Driver side Seat Belt | gwasabi | DIY / Maintenance / Service | 13 | 05-09-2009 07:45 AM |
| Side impact air bags... do I have them? | chumpster | Cosmetic Modifications (Exterior/Interior) | 6 | 04-27-2009 08:04 AM |
| Driver side foglight trim | gwasabi | Willing to Buy by private party | 3 | 03-03-2009 04:11 AM |
