Old 01-13-2011, 11:29 AM   #1
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Post Stock/Built Motor - Boost and Durability
As the title suggest this is where I hope to gather all the information for our motor with regards to boost and durability. I think this would provide useful information for members looking to boost the 1NZ.
We would state either stock or built motor, what type of forced induction, SC or turbo, psi, Whp, management, Fuel or ignition upgrades,miles driven while boosted, length of time driven on boost and driving style. Feel free to add any additional information.
I will use myself as an example
Engine: Stock
F/I: Custom turbo kit T25
Boost: 6.5 psi
WHP: N/A
Management: None right now. Aem FIC being shipped.
Fuel upgrade: 1zz injectors only.
Miles on Boost: ~2k miles
Length of time: 1 Month
Driving style: Eh I rarely floor it maybe 3 times out of the week.
^^^That's just a sample it can be anyway you want to write it. Just some info so we can track what our little engines can put up with for how long.
It is assumed that everything is in working order until you update your post stating any failures that may have occurred.
Any and all ideas how we can make this thread better is welcomed
Old 01-13-2011, 01:12 PM   #2
^ Just curious, unless someone has a failure to report, how does the information shed light on the subject of durability? We should just report stuff that breaks and when.
I'll play anyway, though. I included the grade of gas I use.
Engine: Built (bore/sleeved/rods/pistons/springs/head work)
F/I: Custom turbo kit T28
Boost: 14-24
WHP: 357
Management: AEM EMS
Fuel upgrade: 632cc injectors, Walbro pump, return line, modified Perrin rail, water/meth
Fuel: Pump gas (91)
Length of time: 6 months
Driving style: I hammer it several times a week and race 1-2 times a month.
MISC: rev limit 7300
Old 01-13-2011, 01:31 PM   #3
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
This thread is entirely useless unless you know why the motor failed. Its nice to say say my stock motor blew up with 200hp but go into no detail as to why that happened. If my stock engine runs leans and seizes or burns a piston it wasn't the engines fault that it happened but say a bad injector or fuel pump or if I toss a rod from running to low on oil but happen to make 160 hp with a turbo its not the turbos fault I ran low on oil so a failure diagnosis is more important than yeah I upped the power and now its dead.
Old 01-13-2011, 01:44 PM   #4
Yoda
Yoda's Avatar
I dont think its entirely useless. It covers pretty much questions that people ask often. How much boost,how long you running at that boost, what did you upgrade to run this n that safely. Maybe i thought it was implied that if something breaks that the poster would state what broke and after how many miles n such. Maybe I should up date my first post. Thanks for the input.
Old 01-13-2011, 03:57 PM   #5
xnamerxx
0-60 in slow
xnamerxx's Avatar
Im not trying to be negative but I could run a 50k miles stock and blow the motor because I never changed the oil and complain how unreliable the car is. I don't like this mileage indicator as a result of failure.
Ive seen failure pictures of other users on this board and most of them are pretty easily traced to something else that isn't a direct result of the modification installed.
I mean its simple if your house gets hit by an earthquake and burns down 2 days later it doesn't mean those 2 actions are related. Ive seen lots of examples of people modding theirs cars and doing no correct tuning to go with it and mix that with a very large community of "tooners" who don't know what their doing and a customer unable to tell the difference and you get inaccurate results. I'm not trying to rain on your parade because it would be nice to know I just have a hard time believing that anything useful will come of this thread.
To use myself as an example my car has 75k of extremely hard driving but Ive had no failures to date on the car because there are things I know not to do. As long as you don't let the car run on empty, run on the rev limiter, or run it out of oil your engine should last as long as it was designed to.
Running the car low on gas and driving hard introduces fuel starvation which makes the motor run lean which causes the pistons to get to hot or detonate and in tern either seize or throw a rod because it cant handle the stress being put on it.
Running it on the rev limit causes the fuel system to cut out which can cause the cylinders to run lean and cause detonation.
Oil is self explanatory run low and good by rod bearings. I mean low as in less than full not lower then the indicated line.
Old 01-13-2011, 01:35 PM   #6
Yoda
Yoda's Avatar
We always get questions about how much boost can be run on stock engine and how long it will last and so on and so on. This is just to paint a picture of what every1 has done to there car and how long it has been running under those conditions safely. Each of our setups are a bit different so as a new person I would be able browse and gain an idea of how long at very least I can run a specific setup on my engine before I enter the gray area.
Your idea is also good but then we would have no one posting anytime soon I would hope that if something breaks further down the line that the poster would update his post.
Old 01-13-2011, 07:02 PM   #7
Yoda
Yoda's Avatar
The examples you gave are very poor. If you are not comportment enough to know that you need to change your oil then you should not even be driving. In addition the are warning lights for low oil, gas, and the sort. I never intended to use the miles as an idicator of failure. It's simple states how long before you had your first problem while boosted. You seem educated on F/I so you know what problems that can happen.
"Ive seen failure pictures of other users on this board and most of them are pretty easily traced to something else that isn't a direct result of the modification installed. "
^^ that's what you said. So if the problem can be traced to something else then why would blame the modification? You would then exclude that and not report it. This whole thread is mainly focused on the engine. There are only a few things that will ever go wrong with it if not modified or boosted. Toyota made this car pretty much stupid proof.
"To use myself as an example my car has 75k of extremely hard driving but Ive had no failures to date on the car because there are things I know not to do. As long as you don't let the car run on empty, run on the rev limiter, or run it out of oil your engine should last as long as it was designed to. "
^^^ My question to this is are you boosted? You give people here little credit. Most members here if not all know what's good and bad for a F/I car.
Example as if I were to update my post with my first failure
Current miles while boosted: 8k
Failure: dang my engine crapped out on me. Inpected it only to find metal shavings from the side wall. Not sure what happened gonna look into some more.
Maybe a weak example but hope you get my point. So as a reader if I were to see this I would kno that I would have to look out for something like that possibly happening around that time and set in motions to prevent that.
Let me remind you everything starts with data logging. How do we know that we need an oil change like every 3k miles, how do we kno that we need to change our timing belt at xmiles. People have tested and logged all this info. The same concept applies here.
Sent from iPhone.
Old 01-13-2011, 07:34 PM   #8
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
ohhhhhhhh man, I have to set aside some time but i will post up my motor failures .
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 01-13-2011, 08:51 PM   #9
Yoda
Yoda's Avatar
Looking forward to your contribution
Old 01-14-2011, 01:36 AM   #10
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
I agree with Yoda ... people need info on this engine since we are boosting without knowing where is the limit.
I am sure not every yaris owner has the cash to build a complete engine (excluding XBG :) )... so if we assure these people that with a set of pistons and rods you are safe until X Boost on an X turbo revving above X RPM, damn that would made my life better from this moment!
- Engine: Built (rods/pistons/) Complete Stock Head including bolts and springs
-F/I: Custom turbo kit T28
-Boost: 9psi till now
-WHP: Need to dyno before
-Management: Haltech Pro Sport 1000
-Fuel upgrade: 630cc injectors, Walbro pump, return line, modified custom rail, upgraded fuel regulator
-Fuel: Pump gas (91)
Miles on Boost: ~1k miles
Length of time: 2 years ( driven occassionally )
Driving style: Today I occasionally push it because I am still tuning on it
MISC: rev limit 5500 till now
Wait we forgot ignition!
-Ignition : 4 LS2 Dedicated Haltech Truck Coils with Silkolene HighTension Leads / Denso Iridium IK22 Spark Plugs (Step colder)
My main fears are the valve springs and head bolts. I am risking much on this ... I really need assurance I am safe until Xboost - XRpm
Parmas is offline   Reply With Quote
Old 01-14-2011, 10:52 AM   #11
cdydjded
Drives: Yaris LB Turbo
-Engine: Complete Stock
-Boost: 5-6psi
-WHP: 155 (@ 4psi)
-Management: AEM FIC
-Fuel upgrade: 1ZZ injectors
-Fuel: 93
Miles on Boost: +/-10000 miles
Length of time: +/- 1 years
Driving style: Drive it everyday to & from work, avg -/+400 miles a week
Old 01-14-2011, 10:58 AM   #12
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
-F/I: Zage turbo kit
-Boost: 8 psi
-WHP: 175
-Management: Greddy Emanage Ultimate
-Fuel upgrade: 1ZZ injectors, Water/Meth
-Fuel: 92
Miles on Boost: +/- 500 miles
Length of time: 2 months
Driving style: Only drive it on weekends, if that. I go WOT at least 3x when I drive it.
* I am throwing a CEL that is saying my 2nd o2 sensor isn't reading correctly.
EDIT:
Forgot to mention, before the current turbo setup, I have been running the Blitz Supercharger for around a year. Not sure how many miles I did while having it, but it had to have been over a couple thousand. I was running 8 PSI with that too, at 140whp (same dyno that I dynod the zage kit on).
Old 01-15-2011, 08:51 PM   #13
Focus_Sh1ft
Focus_Sh1ft's Avatar
Engine: Stock
F/I: Zage Kit
Boost: 7 psi
WHP: N/A
Management: AEM FIC - open loop tuning
Fuel upgrade: None. Meth soon.
Fuel: 93 octane
Miles on Boost: 4k miles
Length of time: 4 months
Driving style: Never go WOT or even exceed 4k RPMs during daily driving.
Currently have no issues to really report, although I suspect I have a boost leak still. But that only limits max performance, the car drives great otherwise.
Old 01-17-2011, 01:26 PM   #14
johnny_vitz
Drives: 2005 Toyota Echo
Engine: Stock
F/I: Greddy s/c kit
Boost: 8.5 PSI
WHP: 133
Management: E-manage Blue
Fuel upgrade: 1ZZ Injectors
Fuel: Pump gas (94)
Miles on Boost: 25,000 miles
Driving style: I hammer it several times a week and race 2-4 times a year
05' Echo Hatch - Greddy Supercharger - rear disc
johnny_vitz is offline   Reply With Quote
Old 01-17-2011, 10:06 PM   #15
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
engine: stock
induction: custom T25 w/intercooler
Boost: 8 psi
injectors: stock
piggy back: AEM FIC open loop tuning
Fuel pump: stock 93octane
WHP: ?
5 months boosted about 6K miles
I drive it like I stole it. Floored several times a day.
pimp my yaris is offline   Reply With Quote
Old 01-17-2011, 10:17 PM   #16
Yoda
Yoda's Avatar
^^^^lol pimp. Whats even sweeter is that it starts to spool for me at 1700rpm......
Old 01-19-2011, 12:06 PM   #17
schragen
Onyx Edition
schragen's Avatar
Drives: Yaris 3DR Onyx Edition
-Boost: 4psi (break-in baseline tune)
-WHP: ~125-130
-Fuel upgrade: 2AZ injectors
-Fuel: 91 V-POWAAAA
Miles on Boost: <1k
Length of time: 1 month
Driving style: daily driven, try to keep it under 4k rpm for the rest of the break in period
* I am throwing a CEL that is saying my 1st o2 sensor is running lean AND rich, that will most likely change when i go performance tune
schragen is offline   Reply With Quote
Old 01-19-2011, 12:42 PM   #18
Parmas
Parmas's Avatar
Thanks for the persons who posted a clean answer and of course for participating
Cheers and lets keep the little one boosted :)
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 03:41 AM
OEM Shock Durability darkmoon87 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 04-06-2010 01:38 PM
Yaris engine durability?? Hakan General Yaris / Vitz Discussion 42 11-15-2009 10:06 PM
lightweight rim durability fat like reflexes Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 09-25-2007 09:07 AM
yaris durability stuffy General Yaris / Vitz Discussion 3 05-05-2006 07:16 PM
