Old 02-04-2013, 12:59 PM   #1
DeathBeard
DeathBeard's Avatar
Drives: 2010 Yaris S
anyone currently running two sets of camber bolts?
Hey all,
I ordered another set of Toyota OEM camber bolts today I plan on using two of them per strut (top and bottom hole) to maximize my neg camber..do you guys feel this is safe?
"In his heart a man plans his course, but the Lord determines his steps."
Proverbs 16:9
DeathBeard is offline   Reply With Quote
Old 02-04-2013, 02:02 PM   #2
vten
I have one set up front and its adjustable up to 3 degree together with oem adjustment .
I set it on 2.8 , for about 2 months daily driving about 250-300miles per week , my inside front tires are already show some wears ...
Imagine them with 2 set, more negative camber , Unless you don't mind to spend some $$ changing some tires often, then go for it .
Old 02-04-2013, 02:23 PM   #3
Jason@SportsCar
I have been running two sets the last last couple of years. But I am not using the stock bolts, I think its a mismatched set of Ingalls and SPC.
Our B-Spec car has two sets of the Toyota bolts, but it has seen so little actual use its hard to say how good they hold over time.
Old 02-04-2013, 02:58 PM   #4
DeathBeard
DeathBeard's Avatar
What are your toe settings? Car I had before this was a 04 civic Si hatchback running -5 deg and my tires lasted 20k miles..
Proverbs 16:9
Old 02-04-2013, 02:28 PM   #5
DeathBeard
DeathBeard's Avatar
So running two sets of the OEM ones should be safe on the street? If I use 2 sets per strut -3 is a realistic expectation
Proverbs 16:9
Old 02-04-2013, 02:30 PM   #6
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
I have one set and my alignment shop said it maxed out at -1.15 I want more neg camber up front too
Old 02-05-2013, 09:39 AM   #7
DeathBeard
DeathBeard's Avatar
You cam always slot your top strut hole as well, I know this adds a ton of negative camber
Proverbs 16:9
Old 02-05-2013, 12:25 PM   #8
Every time you post that, I'm going to post that they are idiots and many, many cars are running more camber with a single bolt - including me.
Old 02-05-2013, 01:28 PM   #9
1.5
Form>Function
1.5's Avatar
yeah i completely believe you and understand but it still doesnt help since they are the only alignment shop around that is willing to do work with camber unless I go to orlando.
Also I tried doing it myself but I didnt have enough hands to hold the spindle at a greater angle while tightening the bolt and haven't been able to find a buddy with time to help me. So until then all I can do is rant lol
Old 02-05-2013, 07:56 PM   #10
Jason@SportsCar
With the car in the air (via jack stands or a lift) with the wheels off, put a couple of lug nuts back on, then put a jack under the edge of the brake rotor. With just a little pressure it will hold the spindle assembly back, making it easy to install the bolts.
Old 02-05-2013, 06:46 PM   #11
^ maybe it's time to cultivate more friendships.
I'd come over, but I never get invited.
Old 02-05-2013, 07:04 PM   #12
1.5
Form>Function
1.5's Avatar
Actually I am trying to get more friends in the scene so hopefully someone will come lol
Idk how you feel about Tampa but if you're game then absolutely you're invited lol
Old 02-05-2013, 08:13 PM   #13
1.5
Form>Function
1.5's Avatar
^ nice tip thanks. What do you need the lugs back on for? Or are you using the Jack to push the lug nuts which would move the spindle?
Old 02-05-2013, 09:31 PM   #14
Jason@SportsCar
The lugs keep the rotor from moving around inside the caliper, and prevents any threads from getting damaged on the wheel studs.
Old 02-05-2013, 09:51 PM   #15
1.5
Form>Function
1.5's Avatar
Got it thanks.
Back to topic
Old 02-06-2013, 01:37 AM   #16
mr_miles
Drives: 2013 Yaris
I'm running two sets of bolts :) I say go for it.
adjustable camber bolts? b20vteg Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-22-2012 10:08 AM
Adjustable Camber Bolts Kendrik Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 07-16-2012 04:05 PM
Adjustable Camber Bolts cali yaris Micro Image 30 12-11-2009 09:38 AM
Are camber bolts needed after installing springs? CtrlAltDefeat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 02-01-2009 12:19 AM
