PEEWEE1
Drives: 2009 yaris s sedan Join Date: Apr 2013
PCV valve over tight
My pcv valve is sooooo tight i'm afraid I'm going to "tear" or damage it when trying to remove it. All I've tried is the 3/8 ratchet and socket. I thought the engine was going to be pulled out when I tried to loosen the valve. Could I use maybe some penetrating oil, or "heat" from a torch? This s.o.b. is !!!! Thanks for any ideas.......
Proud Toyota Owner
Drives: 2008 Yaris HB Join Date: Mar 2013
I just changed mine as well, At first I used a 3/8 ratchet and it felt like it was welded on. Step it up to a 1/2 ratchet with a deep wall socket and it'll be easier.
PEEWEE1
pcv
I took your advise with 1/2 inch ratchet,Plus a nice steel pipe as a breaker bar, I heard a nice snap and it loosened up. Cleaned it out with gunk and reinstalled it. Thanks for the help.
![]() ![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris sedan auto / Fit auto Join Date: Oct 2009
Checked it for the sedan . Had oil in it . Still hear the rattle from within , so placed it back in . Should it be cleaned or recheck later ?
PEEWEE1
pcv
While you have it out why not clean it with a little Gunk.
Don't have any .
#7 | |
![]() ![]() ![]() Drives: 08Yaris2D, 88LandCruiser. Join Date: Jan 2013
Give a man a fish, and he'll eat for a day. Sell a man a fish, and you'll both eat for a day.
![]() ![]() ![]() ![]() Drives: toyota yaris yrs Join Date: Jun 2007
Mine came off easier than i thought. I checked it and didn't see any build up at all.Did the shake test and it was rattling fine inside.But decided to give it clean up with carb cleaner. I also did the throttle body.
Maybe your turning it the wrong way? |
![]() ![]() ![]() Drives: 2009 yaris 2 door Join Date: Feb 2013
anti sieze lube
Since you have it off now put some anti-sieze on the threads for next time. Not too much just a little dib on the threads and I guarantee it'll come out real easy a year from now.
| PCV Valve | SonicGuppy | DIY / Maintenance / Service | 4 | 11-12-2014 09:03 AM |
| PCV valve question | window_lee | DIY / Maintenance / Service | 31 | 10-22-2014 04:05 PM |
| PCV Valve Replacement | devinlamothe | DIY / Maintenance / Service | 27 | 03-16-2013 11:06 PM |
| Two different PCV valve Part#s for Yaris? | auxmike | DIY / Maintenance / Service | 6 | 03-18-2011 08:55 AM |
