#1 | |||
Tiny Giant Clothing
Drives: 2008 Blazing Blue Yaris 3D LB Join Date: Oct 2008
DIY: Debadge/Black out Emblems
There was a Request for this today on the forum so i Figured i would make up a quick diy
Here is what I did.. 1. park the car in the hot sun for a couple hours. Or Get a heat gun and heat the emblems up (be careful not to melt paint or something.) 2. Spray the emblems with wd40. let the wd40 saturate the sticky foam tape that holds the emblems on there. 3. Get pulling. For me.. i was able to just pull it off slowly with just my hands, leaving no residue. Some people use finishing line or fishing line and slowly and carfully saw it off the car (slip the line under one side and slowly lift the line up and down while you are separating the emblem from the car. 4. Use some soap and water and clean the back of all the wd40. so that you have a nice clean slate. Painting: 1. Lightly sand the emblems with some 300 grit sand paper.. Try to get the whole emblem looking sanded.. not just the flat surface. 2. Use 2-3 Coats of Adhesion Promoter (helps the paint stick) 3. use 2-3 coats of Primer (get stuff that specifically states it can be used on metal or plastic) 4. Use 3-4 coats of Base Coat. I used a flat black for mine. 5. let the suckers dry for a couple hours. Rebadging: 1. Get some 3m body tape (dont use anything but.. other stuff will be too thick and will look really crappy. 2. put the tap on the back of the emblem. I laid the tape horizontally along the back of the emblem so it covered the whole back. then I carefully razored the excess off so it looked like it was supposed to be there. Also make sure when its flipped over you cant see any tape.. if you can razor a little so the excess is gone. 3. Put it back on! Front Badge Removal: Reach your fingers in the fron at about 4 O'clock on the emblem and you should feel a little tab.. push it so that it releases.. there are two other tabs too.. if you get two out.. it usually just pops out .. you might have to borrow a girl or a kid if your fingers are husky. if anyone has pictures of the process post them and i will put them in this post The End Result ![]() ![]() ![]() ![]() Husky Fingers Approach: (glad i have skinny fingers :) ) Quote:
Sold the yaris... rocking an 89 vw cabriolet now :) Last edited by TinyGiant; 06-22-2010 at 05:36 PM. |
Nice and very detailed....sticky for this one
![]() Drives: YARIS HB Blazin' Blue Join Date: Oct 2008
Thanks for helping me and for the awesome details!
Tiny Giant Clothing
any time :)
Sold the yaris... rocking an 89 vw cabriolet now :) |
![]() ![]() ![]() Drives: Scion xA Join Date: Oct 2008
to take off the emblems you can also use dental floss :)
#6 | |
Compulsive Washer
![]() ![]() ![]() ![]() Drives: 2008 Yaris RS 4-Door LB Join Date: Oct 2008
Most helpful post TinyGiant!
Any tip[s on the removal of the rear badge (center one)? TIA. |
Tiny Giant Clothing
do the same as the yaris and toyota emblems.. same exact process :)
![]() ![]() ![]() Drives: 2007 Yaris Liftback Join Date: Oct 2008
A hair dryer is just as good, not as much heat as a heat gun, so you don't have to worry about the paint bubblin'
B
Visualize whirled peas. Peace, Love and Good Smoke! --Tommy Chong
#10 | |
Tiny Giant Clothing
parking in the sun works just as good too :)
![]() ![]() ![]() ![]() ![]() Drives: 2008 Toyota Yaris Liftback Join Date: Oct 2008
except now it is getting cold so I choose hair dryer for now. :)
やりすぎだ~
Is it possible to remove the Toyota LOGO emblem (in center of hatch) or will it leave holes after removal?
![]() ![]() Drives: 0x Yaris Hatchback Join Date: Nov 2008
From the OP - it sounds like there are some tabs that hold it in. I would imagine that means there are some little holes / slots in the body.
Tiny Giant Clothing
there are two tiny holes that allow for proper alignment so there would be two tiny holes
-YaRiS OwNeR-
Drives: YRS Sedan Join Date: Oct 2008
nice information....
╚══════════RN
I can't find this body tape. Can someone provide a link from wamart or something? I'm not even sure what it looks like.
All I can find is this.... http://www.walmart.com/catalog/produ...uct_id=7678862
![]() Drives: 2008 Liftback Join Date: Nov 2008
Debadging / black-out emblems doesn't affect the car warranty, does it?
Tiny Giant Clothing
I dont think they would cover the finish on the emblems..lol but who cares..
shoudn't affect anything. for them to void a warranty they have to directly relate the problem to the modification.. i dont forsee any ill affects from debadging
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 04:45 PM |
| DIY (08' USDM LB): Interior Light Color Change | revnull | DIY / Maintenance / Service | 37 | 05-21-2016 01:59 PM |
| DIY Change Your Interior Light Grey Panels to Black | KCALB SIRAY | DIY / Maintenance / Service | 64 | 01-22-2015 02:25 PM |
| DIY: LED side mirror installation | eTiMaGo | DIY / Maintenance / Service | 85 | 06-24-2011 12:48 PM |
| revamping the DIY section | supmet | Suggestions - Feedback - Questions | 7 | 03-23-2009 03:01 AM |
