Old 09-21-2014, 03:09 PM   #1
Adam2050
Drives: Toyota Yaris 1.3SR 2001
Noise from Belt Area
Hello,
New so go easy, have a 2001 Toyota Yaris 1.3SR with what has been a noise for about a year (I'm a novice so thought it was just an aux belt) so we changed that belt and the noise hasn't gone away. An ex Toyota Mechanic suggested it was a bearing on the timing setup. I'm unsure as to whether this is true, as I can't see any videos or forum posts whining about this, the guy suggested it was a common fault.
It's a whirring noise from some parts, If I posted a video would someone be able to give us a push in the right direction?
Also has anyone heard of this before, from what I'm reading I'm being pushed towards bearing's on the pulleys?
Adam2050 is offline   Reply With Quote
Old 09-21-2014, 03:25 PM   #2
Definitely post a video. On our US 1.5L Yaris, that kind of noise is typically due to a bad water pump.
Old 09-21-2014, 04:24 PM   #3
Adam2050
Thanks for the quick reply, it's night time here in the UK so I will post a video tomorrow.
What would I need to replace, or is it as simple as just the water pump if that appears to the problem?
Seems quite cheap the part over here, it's around £30 would it require a ramp to do due to space?
Old 09-21-2014, 05:08 PM   #4
Procedure for a NA spec 1.5 http://www.yarisworld.com/forums/showthread.php?t=12727
Probably very much the same, or at least give you a general idea about what would be involved for your 1.3
Belt noise after MI pulley? Captain Slow Performance Modifications 33 07-31-2013 03:11 PM
Squealing Belt Noise Toyota3000 DIY / Maintenance / Service 3 07-23-2013 04:06 PM
grinding noise from engine area, bearing maybe?? trx680 General Yaris / Vitz Discussion 10 01-31-2013 12:22 AM
2005 Yaris noise in engine area dwoodpub General Yaris / Vitz Discussion 5 12-27-2010 07:41 PM
Belt noise? Cutie Pie #2 DIY / Maintenance / Service 20 05-22-2009 02:51 PM
