![]() Drives: 2007 Toyota Yaris Sedan Join Date: Dec 2014
Valvoline Maxlife ATF
anyone using or have any experience with this? The bottle says compatible with Toyota ATF WS. I'm thinking of using it in my 2007 Yaris.
thanks! |
![]() ![]() Drives: Jeep Cherokee XJ 1996 Join Date: Jul 2009
Valvoline ATFs are good but, nothing beats the ATF WS by Toyota - I'd use the valvoline only incase I'm unable to find the Toyota ATF WS
![]() ![]() Drives: Yaris Sedan Join Date: Apr 2012
I used this ATF. I bought my 2007 Yaris with 80k mi when I swapped the OEM ATF-WS with this Valvoline Maxlife. I tried to not mix them together, to do that, I did the following...
I dropped the trans-pan, changed the filter, unhooked one of the cooler lines and ran the engine to flush out the remaining fluid while putting in the new Valvoline. Works just fine. The car is driven 100mi a day in 60% city and 40% highway. It's been there for 2 years and changed every 50k miles. It was better than the fluid it replaced. |
Thanks. I ended up getting WS from a local dealer. WS was $7 a litre and Maxlife ATF was just over $6. Also picked up two 4 litre jugs of Super Longlife Coolant for $17 each.
Sent from my Asus MeMO Pad using Tapatalk |
| FYI VOA: Toyota ATF Type-WS | craigq | DIY / Maintenance / Service | 10 | 06-24-2014 11:53 AM |
| Replaced my ATF | markitect | DIY / Maintenance / Service | 6 | 01-02-2014 11:10 PM |
| ATF Drain and Fill | DMZ | DIY / Maintenance / Service | 7 | 05-31-2013 12:01 AM |
| Valvoline 300,000 Mile Engine Guarantee | PolarWhite | DIY / Maintenance / Service | 30 | 06-24-2009 09:51 AM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 09:16 PM |
