Old 04-06-2015, 04:25 AM   #1
DJYojimbo
Drives: 2012 Grey Toyota Yaris SE
MI Crank Pulley
I was just wondering, i have the MI crank pulley and i believe i've had it on for about 3 years running now. It runs great but how long do you guys think it was last? I pretty much drive the car normally but i do get on the car every once in awhile haha. I wonder if i should get another one before garm runs out of them.
Upgrades: AFE SRI. Tanabe Touring Medalion Axleback exhaust. Micro Image OEM Sized Lightweight Pulley. DC Sports header.
DJYojimbo is offline   Reply With Quote
Old 04-06-2015, 10:04 AM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
It should last forever.
Old 04-06-2015, 02:20 PM   #3
DJYojimbo
awesome! Garm does make quality parts!
Old 04-06-2015, 11:21 PM   #4
We made that pretty beefy, I haven't heard of one breaking yet (unless Jason killed one)
Old 04-06-2015, 11:57 PM   #5
DJYojimbo
Awesome Garm! It's not like I race my car either but I do get on the pedal here and there haha! The product is still awesome! I'm still a happy customer! Thank You Again!
Old 05-31-2015, 07:43 PM   #6
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I just installed one to replace the broken NST pulley. I've been running with the stock pulley for about 3 weeks now, so I could really feel the difference. I went to pull out of the shop this afternoon and chirped the tires (yes, both of them) on accident. Pulls like a dream once again, so I'm a happy customer.
Old 05-31-2015, 11:27 PM   #7
WorkTL
WorkTL's Avatar
Drives: 2013 Yaris LE
^ +1.
I ♥ mine.
WorkTL is offline   Reply With Quote
Old 06-02-2015, 12:55 AM   #8
Thebigwicks
Drives: 2008 lowered yaris on 17's
What does this mod really do for the car?
Thebigwicks is offline   Reply With Quote
Old 06-02-2015, 09:15 AM   #9
Lighter load on the crank, car revs up quicker.
Old 06-02-2015, 09:28 AM   #10
CrankyOldMan
What Wee said, but a few additional notes:
  • Increased drivetrain efficiency from reduced rotating mass--does not add horsepower to your engine, just reduces the amount spent turning the pulley, making a net gain in wheel hp (not brake hp)
  • Faster RPM drop when off-throttle
  • Additional noise/vibration/harshness (NVH) from removal of rubber insert on OEM pulley, your results may vary
This is probably documented elsewhere on the site/web, but it doesn't hurt to put it in the thread since the question comes up frequently.
Old 06-02-2015, 02:57 PM   #11
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
Another myth some people believe is that you will gain hp because of weight reduction. In reality the difference in weight is only 38 oz (aprox. 1kg). It's really nowhere near enough to create a significant performance difference.
What you will get however is a faster climb towards the engine's peak power curve alowing for higher acceleration due to less torque being required to drive the engine accesories.
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog
invader166 is offline   Reply With Quote
Old 06-02-2015, 03:01 PM   #12
Jason@SportsCar
Didn't kill one, but I think I only had it on there one weekend. Call me gun-shy after two previous issues. I know the OE one is good to 7500rpm.
Old 06-03-2015, 03:22 AM   #13
Freestylin
Freestylin's Avatar
Drives: 09 Blizzard Pearl RS LB
Just curious, what issues did you have with these lightweight crank pulleys?
“On a given day, a given circumstance, you think you have a limit. And you then go for this limit and you touch this limit, and you think, 'Okay, this is the limit'. And so you touch this limit, something happens and you suddenly can go a little bit further. With your mind power, your determination, your instinct, and the experience as well, you can fly very high.” ― Ayrton Senna
Freestylin is offline   Reply With Quote
Old 06-03-2015, 02:31 PM   #14
Jason@SportsCar
Shortly after upgrading our ECU, allowing us to rev past 6500rpm, they started failing.
The NST one split in two around 7000rpm. The BeatRush unit had some weird harmonics and beat up the crank pin. Just was not willing to risk a third.
This was about six months old, less than 1000 miles, I think the second time was ran the car with the higher rev limiter.
Old 06-03-2015, 06:31 PM   #15
Freestylin
Freestylin's Avatar
Thanks for the info! If you were to keep it at stock rev limiter then I assume these crank pulleys should last for a while.
Old 06-04-2015, 12:22 AM   #16
2009Toyotoad
Drives: 2009 Yaris 3dr
With little experience I have (one week and 300 miles) I'll say on my 5spd its a subtle but noticeable change. Much less throttle input is needed for the 3rd to 4th to 5th changes.
The best example is matching speeds of traffic for freeway onramps. You are up to 65 to 70 MPH before you realize it.
2009Toyotoad is offline   Reply With Quote
Old 06-04-2015, 05:02 AM   #17
tk-421
tk-421's Avatar
Drives: 5D-07-LB
All I can say is that I've had the entire NST pulley set on for ~8 years and it's been nothing short of amazing.
Old 11-21-2015, 11:18 AM   #18
20104dr
CLIFF
20104dr's Avatar
Drives: 2010 4dr
Is there a how to install it here? I have one but haven't tried installing it yet.
"who the cap fit let them wear it"
20104dr is offline   Reply With Quote
DC header, AEM cai and MI lightweight crank pulley install aspro Performance Modifications 7 09-02-2014 07:57 AM
Installing MI Crank Pulley? oliveskate DIY / Maintenance / Service 6 09-25-2013 01:19 PM
NST Crank Pulley Swap/Trade The Architect Items for Sale by private party 2 11-16-2010 02:11 PM
Feeler: NST 10% Underdrive Crank Pulley - Gray Black Yaris Items for Sale by private party 10 04-29-2009 12:24 PM
NEW GROUP BUY: NST WP-Lite & ALT-Lite Pulley Kit (NonStopTuning) NonStopTuning NonStopTuning 266 09-29-2007 03:51 AM
